Uneven bumper?
Discussion in '2.5 Gen Tundras (2014-2021)' started by redryder, Jul 20, 2024.
  1. Jul 20, 2024 at 6:35 PM
    redryder
    redryder [OP] New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    So I did the DIY shims(some nuts). Does anyone have any idea why my driver side looks pushed forward while my passenger side looks like it hasn't moved at all?
    [/QUOTE]
  2. Jul 20, 2024 at 6:40 PM
    Retired...finally
    Silly question alert: Which side did you put the shims?
  3. Jul 20, 2024 at 6:45 PM
    redryder
    Ryder
    Louisiana
    I put the nuts in between the two pieces of metal so it pushes the front forward. Did the sane for passenger and driver side
  4. Jul 20, 2024 at 7:03 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Sub'd. I may do the same thing
    :popcorn:
  5. Jul 20, 2024 at 9:03 PM
    TacomaTRD4x402
    Southern California
    Did you use 4 spacers(nuts) on each side? Or just the 3 that are visible in your pictures?
  6. Jul 21, 2024 at 6:02 AM
    redryder
    Ryder
    Louisiana
    I used 4 on each side
  7. Jul 21, 2024 at 6:56 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Doesnt look like you even need the bumper shims with those tires.
    Maybe the bumper is bent. You may need to shim only the passenger side to make it look straight.
    User170512 likes this.
  8. Jul 21, 2024 at 7:14 AM
    redryder
    Ryder
    Louisiana
    I have bigger tires on order. I wish I would have checked to see if they were uneven before I started.
  9. Jul 21, 2024 at 8:50 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    That may have been best. Have you tried measuring the areas meant to crumple behind the front bumper beam?IMG_8637.jpg
  10. Jul 21, 2024 at 10:59 AM
    User170512
    User170512 The Hen that laid the Golden Legos
    Macon, GA
    2021 Tundra 1794 TRD 4x4
    Air bags, hard tonneau cover, swing-away tool boxes
    In to hear more.
  11. Jul 21, 2024 at 11:45 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you ever hit anything with the passenger side corner? Looks bent in.
