2012 tundra button underneath passenger side?
Discussion in '2nd Gen Tundras (2007-2013)' started by RiggsGCC, Jul 18, 2024.
  1. Jul 18, 2024 at 12:39 PM
    RiggsGCC
    RiggsGCC [OP] New Member
    Looking at a 2012. Wasn't sure what this button type bolt is. Anyone know? Had a cotter pin wedged in it but not correctly placed. 20240718_133957.jpg Messenger_creation_70a2395d-f412-4740-839f-45007aa860d6.jpg
  2. Jul 18, 2024 at 2:06 PM
    Great White Polar Bear
    Great White Polar Bear New Member
    Jesse
    2010 Tundra 5.7L Double Cab
    More to come.
    Is it near the transmission? Looks like the thermostat bypass for the transmission. You push it in and put a pin in it to bypass the thermostat during a transmission fluid change.
    6:36 minutes.
    https://youtu.be/cNu3feOLXxI?si=PfRhnI_K34nZ1mFG
    RiggsGCC[OP] likes this.
  3. Jul 18, 2024 at 2:32 PM
    RiggsGCC
    Does look to be so. I think the previous owner must of just left a cotter pin slightly inserted for some reason, maybe to avoid using a new one? Thanks.
  4. Jul 19, 2024 at 9:41 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably forgot that B in there... This is the main reason I take a 2nd look once I'm done with any maintenance, for stuff like this... When you're done with the world, and you're ready to set it ablaze, lol... :rofl:
  5. Jul 20, 2024 at 4:57 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Some people pin the transmission thermostat open for "extra cooling" while towing.
    Personally believe it would only serve to warm the fluid more slowly, but would not prevent it from reaching the same peak temps. :notsure:
    Probably doesn't make much difference
  6. Jul 20, 2024 at 5:00 AM
    COTundie
    Trey
    Pretty things
    There is also not a specific cotter pin. One just bends a paperclip.
  7. Jul 20, 2024 at 1:20 PM
    Dr_Al
    Dr_Al New Member
    Al
    That's a spring clip from the brake pads.
  8. Jul 21, 2024 at 6:37 AM
    COTundie
    Trey
    Pretty things
    Haha. It sure looks like it!
    ...maybe I'm the only one who still has/uses paperclips
