  1. Jul 20, 2024 at 2:03 PM
    centex
    centex New Member
    Geez. Last time I bought one was admittedly almost 20yrs ago and it was $80.
  2. Jul 20, 2024 at 3:26 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Yeah, I honestly didn't expect that to happen.
    Oh well, the wife and I are at Hole-in-the-Wall BBQ in Springfield, OR after dropping some coin at Lithia Toyota.
  3. Jul 20, 2024 at 3:35 PM
    koditten
    Kirk
    Midland of the Mitten
    I've been rebuilding Toyota trucks for years. When the air bag blows, it often trashed the clock spring.
    I've bought OEM and I've bought eBay versions. I can't tell the difference. I'm sure they come from the same factory.
    I'd spend the $55 and get one coning from eBay.
  4. Jul 20, 2024 at 3:48 PM
    Cthulhu
    Reinstalled undercarriage armor after removing it for the gear and locker install. I have a Warn VR EVO winch, and if anyone else has one they know the wireless control can eventually shit the bed; Warn has a recall notice and will replace it, but I just decided to install their Hub Bluetooth control. Works pretty good. Also added a little “bling” while I had everything torn apart…
  5. Jul 20, 2024 at 4:01 PM
    Mirg
    Mirg New Member
    2021 Tundra Limited TRD OR
    Did my first oil change after breaking up with the stealership (who charged $130 for the last change, $60 of which was labor), not too bad. Installed a fumoto F133N so it will be a lot less messy next time. I put in 8.5 quarts but it was reading high on the dip stick so I pulled about 20oz out and was really glad I had the fumoto on there for that.
    Also used the motivx tool for the filter housing (which was super hard to remove due the the dealership over tightening) and for draining the filter. Truck is stock right now so it was a little tight under there so I'll probably build some wood rams before my next change at 50k miles.
  6. Jul 20, 2024 at 4:01 PM
    FireFinder44
    Albany, OR
    I have a new OEM because I can't wait to have one shipped.
    Tripleconpanna likes this.
  7. Jul 20, 2024 at 4:07 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    Very tight under there
    Usually drive it up on blocks, but once decided to go without.
  8. Jul 20, 2024 at 4:26 PM
    Mirg
    Mirg New Member
    No kidding! After driving it for 5 miles and then checking the oil level I about melted my face off putting the skid plate back on and draining half a quart out of it.
  9. Jul 20, 2024 at 9:51 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I will say that the upgrade looks really nice, and I hope you get it resolved quickly w/o too much cost/issue :thumbsup:
    I love making things my own and adding a twist to the original design, but it always feels like I'm the guy who's gonna damage more shit than I improve...
    Is it possible if you were to rent or use a puller that you could possibly hit a pick n pull or other wrecking yard and grab that part for a lot cheaper???
    bulldog93 likes this.
  10. Jul 20, 2024 at 9:55 PM
    Tripleconpanna
    I may have missed it, but what did you end up with??? If I remember you were talking 5.29s w/locker, right???
    reywcms likes this.
  11. Jul 21, 2024 at 6:06 AM
    Cthulhu
    Yes. Finished the break-in and gave it a little juice yesterday…
  12. Jul 21, 2024 at 6:07 AM
    FireFinder44
    Albany, OR
    I could have gotten one from a clock spring specialist company in CT for $160 or so. I have a puller now (Harbor Freight, $18). Seems the 2019 Tundras OEM part has that sensor on the back that all the videos tell you to swap from the old to the new.
    It is something that might be available from a pick/pull place, but doubtful it would be intact if the airbag deployed. I don't know how I would manage to keep it intact/centered on removal.
  13. Jul 21, 2024 at 6:12 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I drove it out to Flagstaff to OVRLND campers to get my new camper.
    PXL_20240718_211835377.PORTRAIT.ORIGINAL.jpg PXL_20240719_001730857.PORTRAIT.jpg
    Major, Wallygator, DPF88130 and 32 others like this.
  14. Jul 21, 2024 at 6:19 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went for a rip at my test loop
  15. Jul 21, 2024 at 6:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks great!! It's all starting to come together nicely!
    FISHN43 and Tripleconpanna like this.
  16. Jul 21, 2024 at 6:29 AM
    STravis
    Travis
    Ruidoso, NM
    Thanks man, I love it. The camper is super boxy compared to the old AT, but the space and sleeping area is awesome. I parked it next to @Jonnynewton909 with his Atlas to compare the profile and it's wild looking.
    PXL_20240719_182601287.PORTRAIT.jpg PXL_20240719_182549731.PORTRAIT.jpg PXL_20240719_182632101.PORTRAIT.jpg
  17. Jul 21, 2024 at 7:24 AM
    Tripleconpanna
    Awesome...
    Once I move to larger tires, this is the direction I'll be going as well. Glad you're enjoying it!!!
  18. Jul 21, 2024 at 7:27 AM
    Tripleconpanna
    Makes sense; plus I posted my question before scrolling down and reading your other post. Sounds like you guys made the most of it. Nothing wrong w/a short road trip and little BBQ to soften the unexpected expense :thumbsup:
    FireFinder44[QUOTED] likes this.
  19. Jul 21, 2024 at 8:50 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    So awesome
    STravis[QUOTED] likes this.
  20. Jul 21, 2024 at 12:37 PM
    FireFinder44
    Albany, OR
    Took the Century/LEER fiberglass tonneau off the truck last night after fixing the airbag clock spring.
    Installed the Lomax Stance by Agricover today.
  21. Jul 21, 2024 at 12:53 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Looks great! Head room when opened up? 6’ish?
  22. Jul 21, 2024 at 1:27 PM
    STravis
    Travis
    Ruidoso, NM
    It's about 6' 8" or so.
  23. Jul 21, 2024 at 2:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Changed the oil.
    Going to run 5-30 in it for a cycle just for giggles.
  24. Jul 21, 2024 at 5:36 PM
    mtkey
    mtkey New Member
    2019 Voodoo Blue TRD Pro
    I got mine ceramic tinted late last week, picked it up Friday afternoon. 30% over rear doors and rear window, 15% on front two doors, and 55% on the windshield. I don't know how people can drive around with no tint on any windows, it's like a fishbowl! Granted, my eyesight is still quite good, so the darker windows don't bother me at night. But the heat block alone is worth it to me in the summer here in Alabama.
    Also installed a set of Amazon auto up/down window switches this afternoon on all 4 doors, but the tint needs to cure for a couple more days before I can try them out. The safety stop/reverse is not a concern for me, but I'm aware the aftermarket switches don't have that function. Glad someone made the awareness post about it.
  25. Jul 21, 2024 at 11:16 PM
    Tripleconpanna
    If you get a chance and don't mind posting it, I'd like to see the inside of that beast...
    HulkSmurf14 and ATV25 like this.
  26. Jul 22, 2024 at 2:28 AM
    STravis
    Travis
    Ruidoso, NM
    I'll definitely be posting some pictures as we finish the interior out.
  27. Jul 22, 2024 at 4:00 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    I was driving Bayshore blvd in Tampa the other day. My cruising speed was around 35 mph. My avr. MPG showed around 20 mpg. Is it possible? Or some kind of mistake?
    bulldog93 and koditten like this.
  28. Jul 22, 2024 at 4:55 AM
    koditten
    Kirk
    It's easily doable, just not sustainable.
    Low rpms, flat ground, no wind resistance equals good mpg. Just no one has those conditions for very long.
  29. Jul 22, 2024 at 5:21 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    If I keep mine at 55 of lower and stay off the skinny pedal I can do 20 average. But that is not real life.
    Lassie and bulldog93 like this.
  30. Jul 22, 2024 at 5:28 AM
    centex
    centex New Member
    I can idle down hill at 25mph from the gas station to my house and still only get 12.
