285/75/R17s
Discussion in '3rd Gen Tundras (2022+)' started by jgoliath, Jan 22, 2022.
  1. Jan 22, 2022 at 12:53 PM
    jgoliath
    jgoliath [OP] Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Just put on my wheels from my old Tacoma.
    Wheels: Relation Race Wheels (RRW) RR4-Vs. 17x9. 0 offset. 5.00” Backspacing. Tires: Falken Wildpeak A/T3W LT285/75R17. 34” tires.
    Found out these tundras have M14x1.50 lugs (tacomas had M12x1.50) so I had to pick up new lugs.
    They fit like Toyota was planning for people to be stuffing larger tires in there. Had to remove the front mudflaps and tuck back the wheel well Liners.
  2. Jan 22, 2022 at 2:45 PM
    Summit72
    Summit72 New Member
    Summit
    2018 Tacoma TRD OR LB
    Right on looks good. I got the rr7 and it’s -12 offset may poke a bit too much for my liking. But I guess we will see need to get the damn truck first 4th in line for a allocation for a white limited.
    jgoliath[OP] likes this.
  3. Jan 22, 2022 at 3:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Interesting it's a 6x5.5
    Looks good!
  4. Jan 22, 2022 at 4:12 PM
    usfdrohead
    usfdrohead New Member
    Those chrome inserts on the bumper annoy the hell out of me. I don’t understand Toyota.
    Tundrastruck91 and jgoliath[OP] like this.
  5. Jan 22, 2022 at 4:59 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    The chrome inserts are annoying. I have the SR5 TRD OR so it has the chrome hulk hogan mustache. I plan on wrapping it in gloss black to match the other black accents, like the mirrors and door handles.
  6. Jan 22, 2022 at 11:50 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I love RRW wheels but hoping for a less aggressive offset offering from them.
    I am thinking your modification had to do with no level/lift and the 0 offset?
    …saying so because my 295/70/18’s on stock suspension and factory OR 18” wheels allowed me to keep my mudflaps and no liner pinning (no rubbing whatsoever)
  7. Jan 23, 2022 at 5:56 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Hmmm….. I like it on 17”s.
  8. Jan 23, 2022 at 6:14 AM
    jgoliath
    Rubbing happened at fully pinning the wheel left/right or in reverse. So ya the rrw wheel played a big part in effecting that.
    the other thing I’m not seeing people talk about is coilover compression. These tires fill that wheel well so I’m sure bigger bumps will make it rub the inside of the wheel well more as the suspension cycles.
  9. Jan 23, 2022 at 6:24 AM
    jgoliath
    It’s very tight on the rotors. Like I mean millimeters of clearance. If someone’s not paying attention and throwing on 17s with wheel weights in the wrong spot, they’d get jammed on the caliper.
  10. Jan 23, 2022 at 6:39 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Good news is the back ones are easy to pop off and since its in with the black rear bumper, will be easy to sand and paint. I'd go with a flat black :)
  11. Jan 29, 2022 at 9:12 AM
    jgoliath
    Well I guess the full size tire fits under the truck as a spare. Very tight and had to do some maneuvering to get it up there.
  12. Jan 29, 2022 at 9:26 AM
    jgoliath
    Also a shot I took to see if that piece of the suspension would rub the spare when cycling.
    DesmoDoe, Jpd0144, Bob_Loblaw and 4 others like this.
  13. Feb 8, 2022 at 9:51 AM
    randomquickness
    randomquickness New Member
    awesome, looks like my 315/70/17 should fit just fine based on your testing.
  14. Aug 6, 2022 at 6:11 PM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    Does the OEM spare steel wheel have a tpms sensor in it? @jgoliath
  15. Aug 6, 2022 at 6:22 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Those look really good. Im surprised that in some pics they seem sucked in on 9" wheels. Same tires on my 8.5's don't look that way to me. Maybe just camera angle.
  16. Aug 6, 2022 at 6:32 PM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Those have a lot of poke but looks good! Surprised you had to take off the mud flaps. I stuffed full 35x13.5s on my Pro and they barely touched the flaps at full lock. The Pro is an inch higher in the front but I didn’t think it made that much difference. I guess I was wrong.
  17. Aug 6, 2022 at 6:53 PM
    jgoliath
    No.
    benca1[QUOTED] likes this.
  18. Aug 6, 2022 at 7:05 PM
    benca1
    benca1 New Member
    Thank you so much
  19. Jul 21, 2024 at 12:18 AM
    overl4nd
    overl4nd New Member
    How is it holding up? Thinking of fitting a 35" spare to match the tires I got for mine.
