Long trip reflections - mostly good but then...
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Nov 26, 2023.
  1. Nov 26, 2023 at 4:17 PM
    JohnWhicker
    JohnWhicker [OP] New Member
    So I put about 2000 miles this week on my brand new old 21 Tundra. Drove it to Big Bend and all over Texas for that matter. Man this truck is absolutely beautiful and it drives like butter? silk? so effing smooth and it needs nothing, literally. I was thinking about switching to 20" and BFG KO2 like I have my 2013 but after this trip I am like, why screw such a smooth ride? So I will stay with the 18" and the Michelin's
    The negatives, one that is not Toyota related, my BAKFlip MX4 cover is leaking somewhere in the middle, really disappointed. I already had a bad experience with BAK on my 2013 and here we go again. I think I am just gonna return this focker and never buy BAK again, Brand new cover.
    But here it is now, the Toyota bad. My driver seat is absolutely effing and clearly uncomfortable as hell. It broke my fat arse after 3 hours of drive. Tried everything, but I never got comfortable and my arse was numb after few hours. What am I missing here? I just now researched and read several reviews about this issue. Is the cushion, the material, the design? I am about to swap to Katzkins seat covers and I will ask my guy to add some extra cushion to the diver seat. I hope this is gonna fix. If not, what other options do I have? Can I just upgrade just the driver seat to a Platinum or or 1794? Will it be plug and play from a SR5 Off Road?
    I just hit 2400 miles on it, can you believe it :)
    Black@Blue19, Henry1jg and texasrho83 like this.
  2. Nov 26, 2023 at 4:26 PM
    My 14 Limited seats were like yours. Uncomfortable on long trips. My 07 cloth seats were quite comfy in comparison. Cheaper seat but a pleasure on long trips. I guess adding some extra padding is the way to go. Can't hurt.
    JohnWhicker[OP] likes this.
  3. Nov 26, 2023 at 4:38 PM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Love Big Bend, been that way several times, it's either there or Key West this January depending on the weather. One of my wife and I's favorite areas.
    As for the seats. One of the main reasons that I keep my '18 Platinum is that they are so darn comfortable. We do looonnng cross country road trips. I find the Platinum seats amazingly comfortable as does my wife.
  4. Nov 26, 2023 at 4:41 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Had a Bakflip on my 2014. It leaked too.
    I've never felt uncomfortable in Tundra seats. We have a Sequoia with leather and it's not uncomfortable either. Comfort levels are subjective, of course.
  5. Nov 27, 2023 at 2:32 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    A lot of people on here swear by seat jackers. Maybe snag a set and try it out? Worth a try before dropping the coin for Katskins or a platinum/1794 seat. Good luck!
  6. Nov 27, 2023 at 2:41 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  7. Nov 27, 2023 at 3:28 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Our truck makes a few 12 to 15 hr straight trips every year. It's a limited package with leather.
    I added seat jackers and this helped me. It helped more with my lower back than making the seat more plush. Those seats seam to take quite awhile to somewhat break in. The seat jackers will raise the front of the seat and you will gain some leg support.
    The only downside we have had with the seat jackers is my wife is only 5'2", she has trouble reaching the pedals and has to have the seat real close to the steering wheel to be able to drive.
  8. Nov 27, 2023 at 7:12 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Interesting, while not the most comfortable ever, my SR5 seats I feel are great! We do 20+ hour jaunts a few times a year and I'm not fatigued at all. Can't say the same for the Ford's we had before.
    I do want to try the jackers though.
    Metro14536 and JohnWhicker[OP] like this.
  9. Nov 27, 2023 at 7:50 AM
    Warreng
    Warreng New Member
    I milled my seat jackers down a bit, think it was a 1/4 or 1/2”? Made it just perfect for us.
  10. Nov 27, 2023 at 7:53 AM
    Burdturger
    Burdturger New Member
    Anyone try a 3rd gen seat in a 2nd gen swap yet?
    HulkSmurf14 likes this.
  11. Nov 27, 2023 at 8:01 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm not sure it's the seat jackers as much as the seat itself is just stiff and no side support. I don't have seat jackers but I can raise the thigh part with the power seats.
  12. Nov 27, 2023 at 8:13 AM
    PermaFrostTRD
    Northern NY
    This. These will change the angles and remove that numbing issue for you.
    Adding Katskinz, Clazzio, or other aftermarket leather (as long as it is decent stuff) will improve the cushioning aspect of your seat (going from the Sr5 cloth upholstery).
    I cant speak for the plug n play-ability of the limited or platinum seats, but 2.5 Gen limited leather seats are pretty notorious around here for being tough and uncomfortable. Obviously the frame mounts etc will be universal for swapping seats, but functionality of the higher trim (heated/cooled) might require a little more than just clipping into some existing harnesses.
  13. Nov 27, 2023 at 9:03 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you added the Katzkins leather they have added a thin foam pad that the cloth never had and makes the seat more pillow like and I don't have any comfort problems on long trips but every a$$ is different.
  14. Nov 27, 2023 at 12:28 PM
    Chip_Tundra
    Chip_Tundra New Member
    I use a rugged liner HC3. I used to have a bakflip, but I wasn't a fan of someone using a wirehanger to defeat the locking mechanism while the cover was locked. With the HC3, water also doesn't get in when it's raining.
  15. Nov 28, 2023 at 8:13 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I had a 2014 DC with cloth seats that was very comfortable with no issues. I now have a 2020 CM and the seats are not as comfortable as my 2014 cloth seats were, they were stiffer. I had a 2021 Nissan Titan with the most comfortable leather seats I have ever sat in and drove that thing to FL and back and they were awesome. Nissan calls them zero gravity. I had gone back to the 2020 Tundra from the 21 Titan and wished I could have those seats in my Tundra.
  16. Nov 28, 2023 at 10:03 PM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Nice. Road trippin’ in the new 2021 Tundy.
    We just did a 3,000 mile trip seeing fall colors in our limited 2021.
    Agreed, the truck is so nice, smooth, powerful and perfect in the stock form. Don’t think I’ll ever mod it.
    During long hours in the seat, I found it a big help to simply adjust the seat position. About every 30 minutes or so, or when I remembered. Use all the adjustments. Adjust, to unusual positions, and mix it up. Make the seat too low, then too high, raise up the front of the seat, then lower it.
    Point is to change the pressure points. Big help and can be fun. I’ll never go back to a constant position for long drives.
    The limited seats have lots of adjustments. Not sure what you have.
    Coming out of a 97 Taco with no seat adjustment, these limited seats were an unexpected, pleasant surprise.
    Metro14536, szabo101 and RPO 579C like this.
  17. Nov 29, 2023 at 8:37 AM
    PRNDS
    PRNDS New Member
    FL
    2021 Black Limited 4x4
    Coming from the F-150 world, I initially thought the seats on my '21 Limited were going to be less comfortable than my old' 14 F-150. F-150 seats are softer, more bucket, and feels like you're sitting in them. Tundra seat more stiff and felt like I was sitting on top of it.
    Took a 1200 mile trip I've done many times, in the Tundra, and can say it was probably the most comfortable I have ever been at the end of the trip. Wasn't in pain and aching to get out like I have been in past. This includes other makes/models of Honda, Lexus, and Ford's I've done the trip in the past with. I usually run the tank to empty before stopping and driving for 6-7 hour stretches for 500+ miles were no problem.
    I'm a tall guy and think it is the height of the seat in the Tundra may have played a role. Doesn't go as low to the floor like F-150 did which keeps knees bent and straightens up back.
    szabo101 and fallen0 like this.
  18. Nov 30, 2023 at 2:02 AM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I have BFG KO2 on my 2017 Tundra mounted on TRD Rock Warrior Wheels. After about 20,000 miles they went square, like really out of balance. If I get right on the highway they vibrate like the wheels are loose. After they get warmed up they are fine. I left on a 10 hour drive and almost turned around after 15 minutes. I had my mechanic check the truck and as soon as he saw it he said get rid of those BFG's and come back and see me. I found a set of 20" factory take offs and the ride is supper smooth. My co worker had the same experience with BFG, he siad go for the Nittos.
    So stay away from the BFGs
    The seats, I had a 2017 4Runner TRD Off Road with Softex. I couldn't sit in it without a cushion . The seats were hard as hell. My Tundra SR5 is pretty comfortable.
  19. Nov 30, 2023 at 4:37 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Another vote for Seat Jackers! We felt like we were sliding out of our seats to the front, and it put more pressure on my legs, caused me sciatic pain on longer trips. Seat Jackers reclined us both a bit...MUCH more comfortable, and I can do 10-11 hours with just the regular stops for gas and Diet Mountain Dew, now.
  20. Nov 30, 2023 at 5:29 AM
    JohnWhicker
    That is weird, I am on my second set of BFG KO2 /20" on my other 2013 Tundra and they run perfect. I got 80K from the first set. I am waiting on the KO3's and give these a try later. So my experience with BFG is the opposite.
    I don't plan to upgrade my 18's or swap my rubber on this 2021. It runs so so smooth, like almost butter. Why screw something that runs perfect, right?
  21. Jul 20, 2024 at 9:12 AM
    Jon96cobra
    Jon96cobra New Member
    Jon
    2018 Blazing Blue Tundra Crew Max
    My 2018 limited leather seats have the same hard feel. I took suffer from being numb after long drives. My girlfriend's tundra the seats are cloth but soft and comfortable.
    Does anyone recommend where to get the cushion material replaced in the seats would make them softer? It's like sitting on a wood park bench with lumbar. I started looking for just Sequoia or cloth seats to swap in the truck.
  22. Jul 20, 2024 at 10:55 AM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    My '16 limited leather seats are too firm as well - pretty stark difference from the cloth bench seats in my '03 Tundra.
    For years I always thought these were tacky looking ... until I tried them and use them on my motorcycle too: look into sheepskin seat pads, Costco has a set for $80/pair. Added bonus they'll be cooler in the summer when the sun bakes your leather seats and you sit down wearing shorts.
    https://www.costco.com/sideless-sheepskin-seat-cover.product.100002831.html
  23. Jul 20, 2024 at 1:37 PM
    JohnWhicker
    So when I had the Katskinz put in I asked the guy to add some extra cushion. I can feel the difference. I yet have to make another long trip to tell if is really working.
