  1. Jul 19, 2024 at 8:22 AM
    #6841
    Lucky0402
    Lucky0402 New Member
    Dane
    3/2 Lift Gear Double Pump rims 295/70r18 Nitto Terra Grappler G2s
    Did you have to buy the red axles from a dealership for the Westcott TRD lift to work?
    Sisu87TRDOR likes this.
  2. Jul 19, 2024 at 10:16 AM
    #6842
    Sisu87TRDOR
    Sisu87TRDOR New Member
    Kirk
    2024 Ice cap Tundra TRD OR SR5
    Finally brought the truck in to get the front windows tinted 20%.
  3. Jul 19, 2024 at 5:43 PM
    #6843
    JMitch
    JMitch New Member
    James
    2023 Tundra Limited 4x4 Hybrid
    Added a 2” Front and rear lift to my 2023 Limited Hybrid Crew with rear load leveling. Now on 34” Nitto Recon Grapplers. Used the Readylift SST 2” lift for the rear, but replaced the shock rather than using shock extensions with an N3 from Rough Country. Added the N3 strut from Rough Country up front. Everything is an even 2” higher and has about 1” of rake. Rides same as factory as far as I can tell. I think it’s a nice proportion for these trucks.
    tonyusmc, Rockgate, CV60 and 3 others like this.
  4. Jul 20, 2024 at 9:18 AM
    #6844
    Itowcars
    Itowcars New Member
    Sioux Falls, SD
    2022 TUNDRA TRD PRO LUNAR
    I went up to a 35” 12.5 r18. No lift no rub.
    kumho at52. Great bang for the buck, and very nice tire. They are underrated. I would compare them to Toyo for sure. Quiet, great in all weather, and $1300 installed. Pics don’t do it justice!
    Have a bumper and lights being installed. And she looks bad a$$!! Also have viair compressor bad tank under left rear passenger floor for when I get loaded down. Have an extra bumper $1800! Will meet half way will to travel up to 250 miles from Sioux Falls, SD.
    tonyusmc likes this.
  5. Jul 20, 2024 at 10:39 AM
    #6845
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Cleaned wheels and tires…after washing otherwise. Goes in for more ppf and some tint corrections Monday.
  6. Jul 20, 2024 at 10:49 AM
    #6846
    produxnguy
    produxnguy New Member
    vernon
    I am putting my new front seat spacer design back on the shelf for a while. Haven't had any luck getting the dimensions I need to complete my prototypes. For now just continue to pay double my planned price for the "jackers" and I will focus on another project.
  7. Jul 20, 2024 at 10:51 AM
    #6847
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Finally got the rear Icon shocks and coils installed, also got Lassfit bed liner and floor liners installed. Got console tray Leather from MacGregors Leather. Rear springs brought the back up, need to lower the fron 3/8’’ then she will be level.
  8. Jul 20, 2024 at 11:38 AM
    #6848
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Is your flag going the wrong way or am I trippin? I mean I can understand if you are saying the country is going in the wrong direction.
  9. Jul 20, 2024 at 11:53 AM
    #6849
    machd08
    machd08 New Member
    CLARENCE
    Good catch, I didn’t notice, just put them on, thanks for the catch
    tundznoff and NashvilleBulldawg like this.
  10. Jul 20, 2024 at 12:00 PM
    #6850
    GilFavor
    GilFavor New Member
    Welcome! :)
  11. Jul 20, 2024 at 6:45 PM
    #6851
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Second oil and filter change today at 5601 miles. (First was a few ticks over 1K)
    First one was pre-recall notice, so I wasn't looking at anything too closely.
    Dump, change, carry on.
    Used gen-yoo-wine Toyo (Exxon Mobil) oil and Toyo filter.
    Other than the typical realization that 0W-20 oil has the consistency of water, nothing to report.
    This time around I:
    1) had the drain stream going through coffee filters before going into the pan
    2) cut the oil filter and pulled the filter media completely out, spread out and inspected in between all the pleats
    3) pulled a sample for Blackstone
    4) refilled with Pennzoil Ultra Platinum (and another Toyo filter)
    Results from numbers 1 and 2:
    Zero visible glitter, absolutely nothing caught in the coffee filters.
    A little more to be seen in the filter pleats: you'll have to zoom in
    (Knife blade on right pointing to shiny speck)
    This was the next "biggest" chunk I could find (allen key pointing)
    And finally, micro-mini non-forbidden glitter:
    So.... I'm no Lake Speed tribologist, but based on visuals alone, I'd say my engine is healthy.
    As far as stuff on the microscopic level, I'll leave that to Blackstone and report in that thread when I have results.
    75tranzam and Tundrastruck91 like this.
  12. Jul 20, 2024 at 6:58 PM
    #6852
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    mine is due soon for 5k oil change. I plan to inspect this filter as well. Did you pull the sample for blackstone pre coffee filter?
  13. Jul 20, 2024 at 7:06 PM
    #6853
    BlackNBlu
    Rich
    MN
    Yep.
    Coffee filters sitting in the drain container over the drain holes. Held the sample jar right in the oil stream before it got there.
  14. Jul 21, 2024 at 7:57 AM
    #6854
    SilveradoSwap
    I noticed how cheap the floor mats are, at least in the 1794 edition…
    6,500 miles and its going to have a hole before it hits 10k, sorry, thats just pathetic. IMG_2530.jpg
    ziznack likes this.
  15. Jul 21, 2024 at 8:24 AM
    #6855
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    For me… oem floor mats are always the first thing I toss and get some good all weather mats.
  16. Jul 21, 2024 at 8:37 AM
    #6856
    SilveradoSwap
    I see why. The quality of those floor mats is worse than junk. I drive a lot for work, 1.5 to 2hr trips, and i typically kick my shoes off and just have socks on my feet, makes longer trips so much more comfortable.
  17. Jul 21, 2024 at 9:27 AM
    #6857
    TRD_TUNDRA
    TRD_TUNDRA New Member
    2024 Tundra TRD Off Road and 2024 Sequoia TRD Pro
    Had Katzkin “OEM Match” leather installed.
    Also wrapped some trim pieces in VViViD Stealth Medium black camo vinyl. The shift console and door inserts came precut from a company called The OCD Plug. The rest I wrapped with a roll of the same vinyl. The climate control area and the area around the parking break are actually matte black overlays that I bought off of Amazon and wrapped before installing. The dash center part was removed and wrapped, then reinstalled.
    Other interior bits are AJT Designs matte black door handle covers and a matte black steering wheel emblem overlay from a store on Etsy. Also, Husky Liner floor mats with TRD Offroad custom emblems, the emblems also came from a store on Etsy.
    I’m really happy with how the interior came out. I wasn’t really a fan of the silver, but I think the black and gray camo pattern ties the black and silver interior together really well.
  18. Jul 21, 2024 at 9:59 AM
    #6858
    dreamcatcherxo
    dreamcatcherxo New Member
    just stumbled upon this last night and was curious. have you noticed any results? especially with having the stock filters in?
    Gonefishingdave likes this.
  19. Jul 21, 2024 at 12:15 PM
    #6859
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I did pull the sound bags but haven’t driven the truck since . I’ll ask my guy driving the truck in the morning if he’s noticed anything different . He was out of town when I pulled them so he has no idea lol . I’m curious too !!
  20. Jul 21, 2024 at 12:22 PM
    #6860
    Yotaholic4life
    24 TRD Lift
    I don’t understand why they took away the pocket on the passenger side on the limited ? I liked that on the sr5 ‍♂️
  21. Jul 21, 2024 at 12:59 PM
    #6861
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    Tire/wheel swap today
    j-utah, Henry C, WingedHussar and 2 others like this.
  22. Jul 21, 2024 at 1:47 PM
    #6862
    freaksavior
    freaksavior New Member
    Richmond, Tx
    '22 AG 1794
    Dechromed
    Or why there are no pockets by the transmission tunnel. Toyota made some strange design choices.
  23. Jul 22, 2024 at 4:35 AM
    #6863
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    Got the westcott on. Toya at3 295/65-20
    The ride is almost the same. I’m happy with it
    wxman91, Momcar160, Henry C and 7 others like this.
  24. Jul 22, 2024 at 5:32 AM
    #6864
    NashvilleBulldawg
    NashvilleBulldawg New Member
    Beat me to it. I also like the humor. I’d have given you a laugh instead of a like if it were possible.
  25. Jul 22, 2024 at 5:53 AM
    #6865
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
    This looks nice. I've been really debating on wheels or just bigger tires since my tires are going to need to be replaced within the next six months. I'd love to run 17x9 with a higher et to be more flush with the fenders but can't find anything that's not -10/0/10, or 1200+ per wheel for what I like (rotiform roc-h/bradley v TAKUMI)
    Edit: Can you dm/post the exact kit you bought
    edit again. This one? https://westcottdesigns.net/product/2022-toyota-tundra-preload-collar-lift-kit-new/
  26. Jul 22, 2024 at 6:33 AM
    #6866
    Desertdogs
    Desertdogs New Member
    Arizona
    2024 Tundra 1794 LE #1348
    I want one of these for my 1348/1500. How did you get it?
    nevermind. I found it and ordered one.
  27. Jul 22, 2024 at 8:44 AM
    #6867
    Toyondra
    Toyondra New Member
    Timothy
    24 Tundra HV Crewmax Limited TRD
    Installed GoRhino RB 30s
  28. Jul 22, 2024 at 1:44 PM
    #6868
    Coronerrpm
    Bob
    22 tundra red sport
    Non yet
    That’s the kit. Had to pick mine for the sport that sits lower in the front.
    freaksavior[QUOTED] likes this.
  29. Jul 22, 2024 at 8:53 PM
    #6869
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Cleaned TRD air filters
    tundznoff, Team_Toyota, Yaboy and 2 others like this.
  30. Jul 23, 2024 at 2:12 PM
    #6870
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks again man, I appreciate it! If I can help with anything else just let me know!
