Darkmint's Suspension Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Jul 9, 2024.
  1. Jul 9, 2024 at 12:02 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    For my own future reference.
  2. Jul 9, 2024 at 12:06 AM
    DarkMint
    Ben
    Above: old Diver side vs new
    Below: pics of old Pass side
    IMG_20240707_104043765.jpg IMG_20240707_104052440.jpg IMG_20240707_104105858.jpg
    Screwdriver pry bar broke a couple more times after this.
    Old vs new hardware. Husky HD ubolts are marked Dayton. Shackle bolts&nut remain 19mm, all new Husky hardware uses 7/8".IMG_20240707_113012318.jpg IMG_20240707_113051359_HDR.jpg
  3. Jul 11, 2024 at 6:29 AM
    Great work sir! Although the difference in the full kit price front and rear for Monroe quick struts and Bilstein 5100’s is only about $150 or so. The Billies do require you to reuse your factory spring (which you appear to be missing).
  4. Jul 11, 2024 at 4:54 PM
    DarkMint
    Ben
    I don't have the confidence to use an at home portable spring compressor and reuse the dubious old Monroe spring (wasn't OEM to begin with) so I didn't really look into buying individual front struts at all. Gotta go with the cheapest, simplest job for now (especially with apartment workers on the prowl! Car repairs in the apartment lot are a no-no ;))
  5. Jul 18, 2024 at 7:25 PM
    DarkMint
    Ben
    Replaced old unknown manufacturer rear shocks with KYB gas-a-just. Old top nut was a bitch to remove, had to use nut splitter from Amazon. Was unable to break the nut off fully due to how it clamps but splitting part of it released enough nut pressure. After that, parrot nose pliers with a 14mm wrench hammered onto the bulged/split top nut allowed me to unscrew it.
    The old shock didn't have an Allen head slot, but rather a janky "rectangle" to hold on to. Pliers mangled that tiny rectangle head so it was worthless trying to unbolt that way.
    Both sides used parrot nose pliers to clamp on the shaft of shock (cut away the shock cover with pocketknife).
    Deep 7/8" socket to torque the U Bolts. I originally found 80 ft/lbs for all bolts but based on @KNABORES thread and pic, I used those torque values. I had not torqued down the leafs until now.
    Can't really torque down the new top nut because KYB shocks also have that stupid rectangle at the top and spinning the nut just spins the shock shaft.
    Screenshot_20240718-201034.png Screenshot_20240718-201101.png Screenshot_20240718-201224.png IMG_20240718_142811091_HDR.jpg IMG_20240718_143618005.jpg IMG_20240718_143643254.jpg IMG_20240718_143737107.jpg IMG_20240718_153348144.jpg IMG_20240718_154502033.jpg IMG_20240718_142825208_HDR~2.jpg IMG_0641.jpg
    KNABORES and Hutcheson like this.
