  1. Jul 17, 2024 at 9:39 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Sylvania Silverstar used to be the go-to before all these modern 'systems', but the life span was never great. Good output w/o melting wires.
    I've heard Phillips Crystal Vision is a better choice, but I have no personal experience.
  2. Jul 17, 2024 at 9:50 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    better than my color matched adhesive haha.
  3. Jul 17, 2024 at 10:38 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    It could be
    shifty`[QUOTED] likes this.
  4. Jul 17, 2024 at 11:06 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Had some time this evening, figured I’d start on my LBJ’s & Bilstein 5100’s. Didn’t expect to need a 24 mm socket so I didn’t get too far with the LBJ, excuse to buy more tools I guess. Shock is in, bolts just need to be torqued.
    Extended sway bar end links on the way, should have one side buttoned up by tomorrow.
    George kept me company.
  5. Jul 18, 2024 at 6:48 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Yeah. I won't deny a gun makes me feel safer, but I know the statistics. Bear spray is more effective. Doesn't hurt to double-up though. :)
    455h0le_dachshund and oscardog86 like this.
  6. Jul 18, 2024 at 8:03 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Pray and spray makes sense with either tool!
  7. Jul 18, 2024 at 8:33 AM
    If that's legitimately adhesive and not some kind of hardened glue, 3-in-1 oil will safely take it off w/o impacting the paint. Some sticker removers from the store will soften clearcoats, 3-in-1 won't, and it works quickly. Throw a towel in the seam between tailgate and bumper. Squirt a little 3-in-1 on a couple of letters to wet it, then rub the 3-in-1 into it so it can start working at the adhesive. The adhesive, if it's the typical soft adhesive used with stickers/badges, will start balling up. Keep going until it's nothing but BALLS, then wipe with a clean paper towel. Repeat until gone. Rub out with a little buffing compound after, then wax the whole tailgate.
    It won't repair the scratches I'm seeing under the "OTA", but the buffing compount may at least cut that down a little bit.
  8. Jul 18, 2024 at 8:38 AM
    This stuff specifically, it will absolutely (and safely) obliterate adhesive in small quantities. Works incredibly well. Sitting on a 2x4 for scale.
    oscardog86 likes this.
  9. Jul 18, 2024 at 8:42 AM
    I’m a fan of WD40 for this procedure
    455h0le_dachshund likes this.
  10. Jul 18, 2024 at 8:49 AM
    MT-Tundra
    Montana
    Well...:D
    Especially with a grizzly, shooting and missing is one thing. And how many gun owners are well trained to shoot a hand gun accurately, especially under pressure (like a bear charging you)? None of us really know how cool we'll be under life & death pressure unless we're unfortunate enough to be tested. But the real problem is hitting it, but not killing it. Bear spray is a true deterrent. Being shot but not killed means you've got an injured, extremely pissed off bear. Bear spray allows a bear, in it's natural habitat, that was surprised by you, to go on living. Most bear encounters are people hiking/hunting, surprising a bear. It's defensive/territorial. In that case, I want to the bear to live, having learned a lesson that charging a person means a blast of pepper spray. But if a bear is coming in my tent/truck/camper specifically for me, unprovoked, it's another story.
    dirtnsmores, oscardog86 and Kimosabe like this.
  11. Jul 18, 2024 at 8:49 AM
    He's not talking about that kind of rubbing out! Ah shit, wrong reply...
    WD40 works, but 3in1 seems to get it don 3x-4x faster for me. WD40 works better (it's slipperier) at taking things off with plastic flat razors, which everyone should have in their toolbox. Box of 50 - 100 is dirt cheap on scAmazon. They're pretty much single use, to you'll go through a couple on a job like what he's up against, but WD40 helps them slide thru adhesive without scratching paint nicely. As long as you keep the razor near-flat to the surface.
  12. Jul 18, 2024 at 11:26 AM
    Went by my local dealership to get the part number on the LBJ recall kit. They couldn’t tell me if it came with bolt/dust shields or not. Figured it was worth ordering to find out as the price is the same if you ordered separately.
    The Black Mamba, BroHon and shifty` like this.
  13. Jul 18, 2024 at 12:54 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Previous owner had it painted so adhesive is underneath the paint. I’ve even buffed this.
    I use 3M adhesive remover and it’s amazing for this stuff.
  14. Jul 18, 2024 at 1:04 PM
    Wtf? So basically the only option is wetsand and buff, eh?
  15. Jul 18, 2024 at 1:22 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Want to test your cool under pressure?
    Here's how we simulated adrenaline in the police academy:
    100yd dash in your boots and your utility belt, into the gun range with almost no lighting on, and moving targets (both of good guys, don't shoot, and bad guys, shoot. Also a few hostage situations.
    I did pretty well til I got cocky and took a shot I had no business taking and shot a hostage in the arm.
  16. Jul 18, 2024 at 1:34 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    color change after fiberglass :thumbsup:
  17. Jul 18, 2024 at 3:50 PM
    RealTruck
    RealTruck New Member Vendor
    Underneath?! So it's not coming off without a sand, is it? Yikes! That's unfortunate. Plan to cover it up with a new badge?
  18. Jul 18, 2024 at 3:53 PM
    MT-Tundra
    Montana
    That sounds great. Or drink way too much coffee and invite a bunch of people to watch and judge. Works for public speaking...
    But yeah. Most of us think we'll be a hero. Some percentage of those heroes will simply freeze, or completely fall apart during a life-or-death situation. Can be trained to some extent, but I think a large part of it is innate, and most of us will never know.
  19. Jul 18, 2024 at 3:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    We had an audience too.
    Definitely was an experience I'll always cherish.
    oscardog86 and The Black Mamba like this.
  20. Jul 18, 2024 at 4:10 PM
    VR6T
    You know I am/ was a certified USCCA firearms instructor, and one in the Navy as well. You want to test your under pressure skills...... Well I shot 2 gun for 4 years and know how to design brutality stages for 2GAM Matches. Can't legally call them brutality matches as it's copy righted by Russell Fagon and his 2 Gun Match company. But I'll fuck with ya
  21. Jul 18, 2024 at 5:08 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    No doubt you have some neat tips and tricks. My buddy Cory and his wife do competition shooting. Looks fun.
    We didn't get to do the 12hr SWAT training because the instructor had like a brain aneurysm or something and it got cancelled.
    VR6T[QUOTED] likes this.
  22. Jul 18, 2024 at 5:15 PM
    VR6T
    Jesus that's serious man.
  23. Jul 18, 2024 at 5:20 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah that was a decade ago now. I graduated and passed the TCOLE back in May of 2014. Got a trophy for being the best shot in my class. The Top Gun.
    My favorite part of the academy?
    The driving course.
    :burnrubber:
  24. Jul 18, 2024 at 5:28 PM
    Azblue
    The Dirty T ( ^_^)_且
    So, why didn't you become a cop? If that's too personal, just call me an asshole and I'll mind my own business, I'm used to it.
  25. Jul 18, 2024 at 5:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Hindsight being 20/20, I should've trained just a hair harder to drop another 30lbs, I should've applied to Houston PD, as well as the state trooper academy. Seemed at the time all the smaller PD's around Houston were only hiring 1-2 officers at a time and the testing groups were always like 50 applicants. I was always in the top 10, sometimes the top 3. I also think none of the smaller PD's wanted to hire a rookie with a bachelor's in CJ, meaning they'd have to pay me about what a sergeant made.
    Also one of the sheriff's offices I applied for twice, had a recruiter that was holding his dick til he retired. The application process is a bitch.
    2 years went by and my peace officer license expired.
    The political climate had changed.
    I spiralled into a deep depression and put on a metric fuck ton of weight.
    I was no longer interested. I gave it my best shot and it didn't work out.
  26. Jul 18, 2024 at 6:01 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Also @Ezlube you're an asshole. :D
    But I'm working on bettering myself now.
    I've lost 100lbs in the last year.
    Been thinking about going back to community college for a change in career.
  27. Jul 18, 2024 at 6:03 PM
    Azblue
    Shit, I get it. I was close to getting in as a fireman but never got the final call so I took the offer from the post office when they called and ended up being a mailman for 20 years. Oh, and yeah, I get the weight thing, I've always been a fat ass and it's a bitch to get rid of the lbs.
  28. Jul 18, 2024 at 6:04 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yup underneath. The whole truck is going to get a new color eventually. Low on the list of concerns for me lol.
    RealTruck[QUOTED] likes this.
  29. Jul 18, 2024 at 6:04 PM
    Azblue
    Thank you, I pride myself on it. :fistbump:
  30. Jul 18, 2024 at 6:04 PM
    VR6T
    Mmmmm crash cars and get paid for it lol
