Can I run 285 or 295 without a lift?
Discussion in 'Wheels & Tires' started by Johnkentzel, Sep 26, 2017.
  1. Sep 26, 2017 at 5:37 AM
    Johnkentzel
    Johnkentzel [OP] New Member
    Biloxi
    17 Toyota Tundra Limited
    None.... Yet
    Ok so I'm looking to get some AT for my truck. My current size is 275/55r20... Would I be able to run a 285 or a 295? Without lift?
  2. Sep 26, 2017 at 5:44 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    you can run a 295/55/20 without a lift, but you may need to remove or trim the mud flaps. However, if you have the 20x8 +60mm offset wheels that come on the limited's, then a 285 might be the widest tire you can run.
    Bob and Johnkentzel[QUOTED][OP] like this.
  3. Sep 26, 2017 at 5:58 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    This has to be the most posted about topic. Use the search bar guys.
  4. Sep 26, 2017 at 6:19 AM
    Netmonkey
    Georgetown, TX
    yeah... its funny... I asked my wife what she thought were the most asked questions on this site. after a few moments, she answered, "what lift should I get?" and "what tires will fit?" i literally laughed. she doesn't even view this site and she was spot on :)
    EDIT:
    although, I do have to say, most of the information on this site about tire sizes are for those with 2-3" lifts. when I was going through the tire selection process, I could not find definitive information about small lifts and slightly larger tires for my application.
    So, I don't mind answering these questions :)
  5. Sep 26, 2017 at 8:19 AM
    Johnkentzel
    Biloxi
    None.... Yet
    Thank you
    Netmonkey[QUOTED] likes this.
  6. Sep 26, 2017 at 12:53 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    I'm running 285/55r20 bfg's. No lift and it's a 2wd. They are close, but absolutely zero rubbing at any time.
  7. Sep 29, 2017 at 5:02 AM
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    I have 295/55/20 Ridge Grappler's on my stock Platinum with ZERO rubbing anywhere. And, the mudflap does not need to be removed. Ironically, my speedo is dead on perfect with this size.
  8. Sep 29, 2017 at 6:00 AM
    Netmonkey
    Georgetown, TX
    +1
    I have the same tire, but on texas edition wheels (lower offset) so I had to remove the front mud flap. however, I did see that my speedometer is exact as well :)
    how close to the UCA is that tire with the platinum wheels?
