2023 Fluids
Discussion in '3rd Gen Tundras (2022+)' started by Mrfritz44, Jul 17, 2024.
  1. Jul 17, 2024 at 6:04 AM
    Mrfritz44
    Mrfritz44 [OP] New Member
    I'm getting different answers online when referencing fluid change guidelines.
    What are you seeing as the recommended fluid change frequencies for front and rear differentials, as well as the transmission for the new Tundra?
    Based on your personal experience, what frequency do you recommend and why?
    Fred
  2. Jul 17, 2024 at 6:44 AM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Not sure but did my rear diff at 31k this weekend and the fluid looked terrible. Multiple metal chunks on magnet in addition to the fine shavings. Looking at the oil, I likely should have done it much sooner
  3. Jul 17, 2024 at 7:03 AM
    sudobash
    sudobash New Member
    These have been discussed, at length, in the past.
    You can also look at the Toyota provided Warranty & Maintenance Guide that was included with your vehicle.
  4. Jul 17, 2024 at 7:49 AM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    Did your differential sound okay, any whine coming from it??
    Tundrastruck91 likes this.
  5. Jul 17, 2024 at 8:34 AM
    AZxp
    AZxp New Member
    No presenting issues whatsoever. Quiet and smooth. But the chunks were actual chunks which was a little unnerving.
  6. Jul 17, 2024 at 8:39 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    30k for diffs/t-case...Im doing trans fluid at 50k. Always have, never hurt anything. If in doubt, just follow the "severe" or "towing" schedule in your owner's manual
  7. Jul 17, 2024 at 9:04 AM
    CHESSIEMAN
    STEVE
    PA
    Was just curious, my truck has a slight whine to it. Kind of crawls up my ass at times.
  8. Jul 17, 2024 at 1:04 PM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Would you be interested in documenting this for the community? Will you be pulling the whole pan or just drain and refill?
  9. Jul 17, 2024 at 2:43 PM
    eddiefromcali
    Eddie
    100% Stock
    I pump fluid out the cooler and refill...no need to do a pan drop, just drain...fill...pump out and add back in. I can document it
  10. Jul 18, 2024 at 8:44 PM
    devron11
    devron11 New Member
    Ron
    Denver
    Can you kindly document the details? Thank you.
