3rd Gen Headlight beam adjustment?
Discussion in 'Lighting' started by opfor, Jul 15, 2024.
  1. Jul 15, 2024 at 6:56 PM
    opfor
    opfor [OP] New Member
    2024 Hybrid Limited TRD Off Road
    Just replaced my front shocks in order to level my Tundra and going to need to lower where my head lights are hitting now. Does anyone have a video link or short description on where to do this on the 3rd gen tundras?
  2. Jul 16, 2024 at 3:55 AM
    opfor
    Many speak of having a dial button lower left section of buttons off from the steering wheel, unfortunately my limited does not have.
  3. Jul 16, 2024 at 4:02 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    I’m not completely sure, but you should have the upgraded premium headlights which I believe are auto adjusting
  4. Jul 16, 2024 at 4:04 AM
    opfor
    Thanks for the note. From what I understand the auto adjusting work by recognizing the bed sagging, if this is true they will not adjust since my bed stayed the same and my front raised up by 2"
    Soupbean77[QUOTED] likes this.
  5. Jul 16, 2024 at 4:48 PM
    opfor
    Well I finally tracked it down and thought I would post here just in case anyone else decides to look for it. This is looking down at my left head light and you can see the arrow pointing to the white wheel. Put an 8mm socket on it and turn clockwise to lower, counter to raise ;)
    Soupbean77, chavey2 and kirkb like this.
  6. Jul 17, 2024 at 4:48 AM
    chavey2
    chavey2 Stormtrooper in Training.
    Christopher
    Austin, TX
    2024 Tundra SR5 Double Cab Std Bed 4x4.
    Just starting
    Thanks for the info. I have the exact opposite problem - my headlight is too low. The below pic was taken a couple weeks ago and I've since leveled the truck, but the headlight still needs to come up. BTW, that's a cul-de-sac in front of me and houses all across.
    Soupbean77 likes this.
  7. Jul 17, 2024 at 4:55 AM
    opfor
    Wow.... you are Low and Dark. Its a super easy adjustment once you know where to find.
    chavey2 likes this.
