2.5” Foam Cell Pro Suspension from Ironman 4x4
Discussion in 'Suspension' started by 2020Platinum, Jul 16, 2024.
  1. Jul 16, 2024 at 4:42 PM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Installed this lift kit a couple weeks ago, had it off the road a couple times already and couldn’t be happier! Install isn’t that bad if you want to do it yourself, definitely worth saving a chunk of money!
    Ironman 4x4 Foam Cell Pro Lift Kit Install on a 3rd Gen Tundra. 2022 Toyota Tundra TRD Pro.
    https://youtu.be/GlwQHf3Wte0
  2. Jul 16, 2024 at 4:51 PM
    luxury4play
    luxury4play New Member
  3. Jul 17, 2024 at 3:57 AM
    2020Platinum
    Patrick
    Northeast PA
    Thank you sir!
  4. Jul 21, 2024 at 9:17 PM
    battleon3
    battleon3 New Member
    Great video! How is it on-road vs your old pro suspension and did you have to modify the TRD skid plate? Thinking of getting these too!
  5. Jul 23, 2024 at 2:08 PM
    2020Platinum
    Patrick
    Northeast PA
    thank you! Literally feels identical to the stock fox suspension on the TRD Pro. No better, but definitely no worse. Other than the extra height and travel, I would never know the suspension was changed!
    jachal and battleon3[QUOTED] like this.
  6. Oct 28, 2024 at 7:29 PM
    slcsez2000
    slcsez2000 New Member
    Any regrets with this lift? How has it been?
    I have been pondering the 3” lift version for weeks
  7. Nov 13, 2024 at 4:18 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    Did your front shocks come packaged like this? I hope it’s a test of their durability just wrapped in foam paper. Boxes have patch holes in them with scuff marks on the springs. :facepalm:
  8. Nov 13, 2024 at 4:55 PM
    Jla14
    Jla14 New Member
    2014 White 1794
    Mine arrived the same way, I ended up having rubbing issues. However that was for the previous gen.
  9. Nov 13, 2024 at 6:27 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    Any other issues other than rubbing? My first experience with them and their emails are beating around the bush and non specific.
  10. Nov 13, 2024 at 6:43 PM
    Jla14
    Jla14 New Member
    2014 White 1794
    They said they will send me a replacement. However they're out of stock and can't tell me when I'll be able to get a replacement. They said they could be in stock tomorrow or it could be a month. Nothing specific. My coil got the top edge of the shock body and it appears to have oil residue. It only rubbed once the weight of the truck compressed the suspension.
  11. Nov 13, 2024 at 7:43 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    good that they’ll replace it when it becomes available. I’m gonna try and get mine installed next week and see how it goes.
    @2020Platinum how’s your lift holding up? Did you need a sway bar drop kit?
  12. Jan 8, 2025 at 6:51 PM
    slcsez2000
    Went with the 3” kit with heavy duty springs.
    So far so good. Hope to actually have time to do the rear in the next couple days.
    I am wondering if I need a sway bar drop bracket too. I was about to order one just in case. No rubbing of it but does look a little wack.
    Rodtheviking likes this.
  13. Jan 8, 2025 at 6:53 PM
    slcsez2000
    you get yours installed? Add a sway drop?
  14. Jan 8, 2025 at 7:08 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    yes and yes. All the other brands included it so I added it. When I asked Ironman they said you don’t need it unless you wanted to get the most out of your shock. So why not add it. You might need spacers if you have a skid plate.
  15. Jan 8, 2025 at 7:46 PM
    slcsez2000
    Cool I was looking at them tonight
    Think I will add one too.
    how you liking the lift/ride so far?
    Thanks!
  16. Jan 8, 2025 at 7:57 PM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    so far so good. I have a steep curb to my driveway and it soaks it up a lot smoother than my icon stage 3 for Tacoma and 4Runner. Time will tell but I’m excited to not have to rebuild these as often. Looks complete now with my 35s. Gas mileage… not so much haha
  17. Jan 9, 2025 at 8:09 AM
    slcsez2000
    nice, rebuild ease and longevity VS the icons I had on the taco was my deciding factor too.
  18. Jan 9, 2025 at 8:25 AM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    @slcsez2000 with your heavy springs what kind of weight you got on now or planning?
  19. Jan 23, 2025 at 6:41 PM
    slcsez2000
    sorry never saw this
    figured at some point I would toss a full bumper and winch like I had on my Tacoma.
    Currently I am just stock up front.
    so I let things settle and remeasured after driving for a couple weeks.
    Looks like my 3” lift is actually settled at 2.5. Guess I’ll call tomorrow and make sure they actually sent me the correct setup
  20. May 12, 2025 at 5:15 PM
    centralky_tundra
    centralky_tundra New Member
    2023 Black Platinum
    3.5" ReadyLift, 20x9 Fuel Assault, 35x11.5.20 Toyo OpenCountry AT3
    Did you just go with the Foam Cell Pro coilover kit? I already have a 3.5" ReadyLift on my 2023 Tundra and 35x11.5.20 Toyo AT3's. I am just looking to improve articulation a little and improve ride quality. TIA!
  21. May 20, 2025 at 11:39 AM
    slcsez2000
