Power steering lines??????
Discussion in '1st Gen Tundras (2000-2006)' started by Sbct, Jul 15, 2024.
  1. Jul 15, 2024 at 6:49 AM
    Sbct
    Sbct [OP] New Member
    Dave
    2002 Tundra 4.7L. 4x4.
    None
    Have to replace both power steering lines that run from rack up to reservoir and the pump that has that sensor thing.
    looking on Rock Auto, none of the photos seem to look like what I have. Should I just take them to auto parts store and order?
    one line runs to reservoir and one goes to pump. Just two. Thanks.
  2. Jul 15, 2024 at 7:07 AM
    High pressure line goes to pump. Return line (low pressure) goes to reservoir. You could just use a 3/8” hose to replace the rotted return line from the hard line to the reservoir. Only issue is getting the 3/8” over the reservoir connection which takes a little bit of lubrication to do. Hydraulic hose can be picked up at Autozone or any parts chain store.
    However, if you’re going to replace the send line to the pump, you want to buy the whole line assembly to do both instead.
    Someone else can chime in on Rockauto who’s ordered one from them. I think the diagrams aren’t accurate but I can’t be sure.
  3. Jul 15, 2024 at 7:11 AM
    Sbct
    Dave
    None
    I unfortunately need to replace everything. All the metal tubing is shot and rotted through and the hoses as well or dry rotted to a certain extent.
    I’m putting in a new rack. I may as well just do everything while I’m in there.
  4. Jul 15, 2024 at 7:19 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    When I did mine, I bought the SunSong pressure and return lines from Rock Auto. They worked for my truck. I know others on here have used SunSong as well.
    What's different about your lines and the ones you've seen in pictures?
    Jack McCarthy likes this.
  5. Jul 15, 2024 at 7:24 AM
    Sbct
    Dave
    None
    I have another question the sensor thing that goes to the top of the power steering pump. It is tighter than hell I have pushed and pulled, but I don’t want to break it. Am I able to soak that with penetrating spray?
    I just wanna be sure since it’s some sort of sensor
  6. Jul 15, 2024 at 7:34 AM
    Are you talking about the power steering air control valve, that has two vacuum hoses attached? If so, it's just a valve. It should have threaded neck on it, on the other side of the bulge from the hose bibs.
  7. Jul 15, 2024 at 7:37 AM
    kentuckyMarksman
    Based on your picture in your other thread, disconnect the 2 hoses and use a wrench to loosen the air control valve, then use a socket and loosen the bolt on the top. It took some force to loosen them on my truck, but nothing out of the ordinary. I don't see why you couldn't use penetrating oil first, no harm in trying.
  8. Jul 15, 2024 at 7:39 AM
    Sbct
    Dave
    None
    yeah, I can’t for the life of me get it to break loose. I pulled so damn hard. I thought I was gonna round off one of the edges so I stopped. I put a little bit of penetrating spray just a tiny amount, but it is not moving.
  9. Jul 15, 2024 at 7:42 AM
    It's safe to use penetrant on that. The valve itself looks like this when removed, and it's not a sensor, it's an air valve that redirects vacuum when engaged.
    Some of them come with threadlock pre-applied on the threaded shaft. As long as you stay on the metal threaded part with your tools, you likely won't break anything, but this is not a part you want to break. Even the Dorman replacement is something like $70. Leverage is your friend.
    Sbct[QUOTED][OP] likes this.
  10. Jul 15, 2024 at 8:27 AM
    Sbct
    Dave
    None
    Finally broke loose / knuckle buster.
    shifty`[QUOTED] likes this.
  11. Jul 17, 2024 at 8:25 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    this was inducing my mechanic rage just reading it lol
