  1. Jul 13, 2024 at 2:28 PM
    oscardog86, DarkMint, NUDRAT and 10 others like this.
  2. Jul 13, 2024 at 2:31 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    LOL! Right... But if you knew what I went through to get them off and change those fluids when I first bought it :bananadead: you'd know that some surface paint isn't even a factor.
    I actually have thought about welding a nut on them to just make it easy peasy.
  3. Jul 13, 2024 at 2:58 PM
    Ordered some tires for my daughter's tree. That counts, right?
  4. Jul 13, 2024 at 4:13 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Running same tires on my Ferd. Worth every penny. Found a discount code on eBay for the discount tire store and saved a few bucks. My shipped total was $661.30.
  5. Jul 13, 2024 at 5:14 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I had those tires in 265/75r16 on my Tacomas with the FJ Trail Teams wheels.
    Good tires.
    bmf4069[QUOTED] likes this.
  6. Jul 13, 2024 at 5:17 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Good to know, since my black one also needs paint some day
  7. Jul 14, 2024 at 4:32 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Jul 14, 2024 at 4:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Jul 14, 2024 at 7:03 AM
    Who knew Crackie could babysit?!
    TX-TRD1stGEN, Tundra2 and bmf4069 like this.
  10. Jul 14, 2024 at 7:10 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    propane to add bubbles to the lemonade?
  11. Jul 14, 2024 at 7:15 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Little Dude be saying - Dah, bumper already. Bottle jack & scrap lumber. This aint the 'Virus.
    I can see it on his face.
  12. Jul 14, 2024 at 7:22 AM
    Don’t ever sell Crackie. Little boys love trucks up until they grow out of them (never).
    Tundra2[QUOTED] and BroHon like this.
  13. Jul 14, 2024 at 10:43 AM
    Decided to change my PCV valve. A lot of carbon, but still good after blowing through it. Only one way as expected.
  14. Jul 14, 2024 at 11:02 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Good man. I'd replace mine but I'm poor
  15. Jul 14, 2024 at 11:09 AM
    Yeah, they’re spendy
    Tlar25, bmf4069, oscardog86 and 5 others like this.
  16. Jul 14, 2024 at 11:18 AM
    In all the time I’ve worked on my vehicle and others, I’ve never seen one go bad; knock on wood.
    KNABORES and FrenchToasty like this.
  17. Jul 14, 2024 at 11:18 AM
    You could send him your old one?
  18. Jul 14, 2024 at 11:19 AM
    Sure why not? I’ve got this one and the one from 2019. :rofl:
  19. Jul 14, 2024 at 11:22 AM
    VR6T
    One thank you for the thought, 2 not needed I'm poor cause I'm about to buy a 800 dollar clutch for my GLI lol. And I cleaned mine out, and it's still working fine. I'll replace it when the P0171 comes back lol
  20. Jul 14, 2024 at 11:23 AM
    VR6T
    Today's work
    bmf4069, oscardog86, BroHon and 8 others like this.
  21. Jul 14, 2024 at 11:25 AM
    Those are fun. If the bed bolts come out I’d suggest to loosen them all and remove them on each side your doing one side at a time to give you plenty of clearance.
  22. Jul 14, 2024 at 11:25 AM
    Looping back with my idle for posterity. Both at cold start, and after 2 miles and warming it up. Basically idle is at 1,300rpm for me, both before and after SAIP completes its 3-second run, then drops to around 700rpm after warming up a little bit.
    Interesting the left-half of the gauges are pointed roughly identical before and after. I'm sure it's by design, but ...
  23. Jul 14, 2024 at 11:44 AM
    VR6T
    Danger Will Robinson, Danger!!
    Tundra2, bmf4069, oscardog86 and 7 others like this.
  24. Jul 14, 2024 at 11:44 AM
    Make sure you use and impact to tighten it because we all know how that ends. (Badly)
  25. Jul 14, 2024 at 11:53 AM
    VR6T
    IMG20240714135140.jpg rOuGH cOunTrYs aRE qUaLiTy sUsPeNsIoNs..... About 23xxx on these, won't even come up
  26. Jul 14, 2024 at 11:54 AM
    VR6T
    Well that's how it came apart that's how it's gonna get put back together lol
  27. Jul 14, 2024 at 11:56 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Reset your lca bushings to compensate for the lift.
  28. Jul 14, 2024 at 11:57 AM
    VR6T
    How?
  29. Jul 14, 2024 at 12:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Mark cam alignment, loosen nuts, jiggle, realign with weight, tighten.
  30. Jul 14, 2024 at 12:00 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You ever notice our trucks don't like to shift out of second on cold starts, unless you go over 40mph or the coolant reaches 127°-130°F?
    At least that's how it is for the A340.
    I haven't driven my A750 enough in the last year to accurately tell you it's preferences, but I want to say they're about the same.
