Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Jul 12, 2024 at 10:52 AM
    #61
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Nice. I remember that job. I had pulled engines and transmissions, years ago. But after 10+ years of only doing oil changes, CVs, starters, radiators etc., doing the leaf springs was a big job. Have the whole rear axle just dangling...
    Pretty satisfying when it's all back together though. Like pulling a transmission, it's not that it's complicated, it's just big, heavy, dirty, and a very major part of the truck. A similar pack to what you bought is somewhere in my future.
  2. Jul 12, 2024 at 6:18 PM
    #62
    KNABORES [OP] Sarcasm incoming
    Some more bits. Maybe springs tomorrow. Hoping for an inch or two of lift.
    BroHon, des2mtn and 455h0le_dachshund like this.
  3. Jul 13, 2024 at 7:11 AM
    #63
    Let the sketch begin
  4. Jul 13, 2024 at 7:17 AM
    #64
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Following as my rear is sagging a bit with all the truck things we do.
    Curious about the alignment method in regard to the axle and leaf packs; haven't looked into it yet...
  5. Jul 13, 2024 at 8:58 AM
    #65
    There’s a center pin on the leaf packs that aligns the axle to the leaf’s. Zero magic involved.
  6. Jul 13, 2024 at 8:59 AM
    #66
    All done. It’s hot so it was a sweat fest, but overall not too bad. Leafs are heavy and awkward, but still a one man job if necessary. gained one inch of lift over the factory ones that may have been wore out, so not much really.
    Bmktw2, Eddie's XSP X, BroHon and 3 others like this.
  7. Jul 13, 2024 at 9:05 AM
    #67
    Before and after
    Weagle, Bmktw2, Eddie's XSP X and 3 others like this.
  8. Jul 13, 2024 at 9:06 AM
    #68
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    That was fast.
  9. Jul 13, 2024 at 9:19 AM
    #69
    Almost dead-nuts 1". Huh. Makes me wonder if those are actually the same as ATS springs. Where'd they ship from, out of curiousity, or do you not have the label anymore?
  10. Jul 13, 2024 at 9:27 AM
    #70
    Zero sag with the 16’ trailer now. Yay.
  11. Jul 13, 2024 at 9:28 AM
    #71
    Minneapolis
  12. Jul 13, 2024 at 9:38 AM
    #72
    Hmmm. ATS is in PA. Let me see where the extra they sent me shipped from....
    EDIT: Nope, mine shipped from 1069 S. County Line Road in Souderton, PA.
  13. Jul 13, 2024 at 1:37 PM
    #73
    The cliffs notes write up for the spring swap:
    lift the truck and support the frame and rear axle with jack stands
    Remove the wheels
    Remove the nuts from the front axle hanger bolt and the rear lower shackle hanger bolt
    Remove the nuts from the U bolts holding the axle to leafs with the axle plate
    remove the lower shock bolt to give the axle enough down travel for removal
    Remove the bolts from the leaf spring hangers freeing the leaf spring. May have to hammer the leaf a bit to loosen the center pin
    Lay it out next to the new one and get the orientation correct. swap the shackle over to the new one
    Installation is pretty much reverse of removal. I put the rear shackle hanger bolt in first and then installed the U bolts and axle plate after centering the pin. Then lowered the truck until the front eye lined up to install the front spring hanger bolt.
    Everything snugged but not torqued yet.
    used this opportunity to fix my shock boots with new lower zip ties.
    Reinstalled the wheels and put er back on the ground
    Then I torqued all of the connections to spec
    the new U bolts are 9/16” and required 131ft/lbs per the provided labeling.
    will retorque after 500 miles or so.
  14. Jul 13, 2024 at 2:24 PM
    #74
    You didn't need to pop off the lower shock mount? Granted, I did mine one side at a time, so diagonal travel was an issue. But I also didn't want to overextend the shock, or blow out the upper bushings.
  15. Jul 13, 2024 at 2:24 PM
    #75
    I did, it’s in the write up
  16. Jul 13, 2024 at 2:27 PM
    #76
    Ah, missed it under the photo. :thumbsup:
    KNABORES[QUOTED][OP] likes this.
  17. Jul 13, 2024 at 2:29 PM
    #77
    I did one side at a time as well. Took about 1.5 hours total for both. Not much to it.
  18. Jul 13, 2024 at 2:32 PM
    #78
    I was about to say what I meant, but I'd need to dig back in this thread to remember how I did mine. I know I jacked up at the diff, and supported the frame, and used the jack to lift/drop the diff for sliding springs in/out, and use the bottle jack to help lift up either side of the axle to help with finagling, but I can't remember if I took off both wheels and worked on one side at a time, or if I took off one wheel at a time and worked on that side.
    Your way looks a lot better than what I remember. I don't have two floor jacks.
  19. Jul 13, 2024 at 2:38 PM
    #79
    Unless you put them in backwards like me and Casey.
  20. Jul 14, 2024 at 11:36 AM
    #80
    A little touch up work. Tired of the peeling drivers window trim and missing Yota emblem. Both getting addressed. Gonna dip ‘em. Window trim may get replaced at a later date. Emblem will get painted red like before the accident.
  21. Jul 14, 2024 at 12:03 PM
    #81
    Prep
    done. Better, but not great. At least it’s all black now. Will refinish later or replace.
    Just needs to dry / cure
    BroHon, bmf4069, FiatRunner and 2 others like this.
  22. Jul 14, 2024 at 1:23 PM
    #82
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    PM me. I'll send you a new OEM emblem.
    I'll even cover shipping or you can come hang out next time you're in town.
    Edit: you already got an emblem NVM
  23. Jul 14, 2024 at 1:50 PM
    #83
    appreciate it
  24. Jul 14, 2024 at 3:17 PM
    #84
    Emblem turned out, well, red. May need to get a slightly darker hue than the cherry I had on hand. Works for now though.
    Weagle, BroHon, bmf4069 and 2 others like this.
  25. Jul 14, 2024 at 3:28 PM
    #85
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    All red accessories fade to pink in my experience anyways. Enjoy the cherry crisp redness and it'll eventually get to the shade you intended
  26. Jul 14, 2024 at 3:56 PM
    #86
    My last one held up well for many years
  27. Jul 14, 2024 at 5:22 PM
    #87
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I dipped my window trim too. So far it’s holding up well. No noticeable fading after a year and a half of being parked outside.
    BroHon and KNABORES[QUOTED][OP] like this.
  28. Jul 14, 2024 at 5:24 PM
    #88
    Nice, my truck has been parked outside for 19 years. Hope it holds up.
    FiatRunner[QUOTED] likes this.
  29. Jul 15, 2024 at 11:33 AM
    #89
    This is a heavy ass commercial mower. It usually puts a hurting on the rear suspension with the old leafs. New ones don’t seem to care. Mission accomplished.
  30. Jul 15, 2024 at 12:05 PM
    #90
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I have a hustler like that too :thumbsup:
    Yours is bigger though.
