What PSI should 35x12.50x17 BGFs Ko2, truck weighs 7000lbs
Discussion in 'Wheels & Tires' started by brkncly, Jul 12, 2024.
  1. Jul 12, 2024 at 6:19 PM
    brkncly
    brkncly [OP] New Member
    Oregon
    Just got some new 35x12.50x17 BFGs Ko2. Thought I would stop by a weigh station to see how much the truck weighs over all. With my 2020 CM and nobody sitting in it, it says it weighs 6,550lbs. With 2 adults it weighs in at 7,000lbs. I have a Leer canopy, AMP Research Power Steps and DECKED truck bed organizer that's 3/4 loaded with tools etc. How many PSIs should I be airing my tires to, same all the way around or more in the back than the front? Any advice or suggestions for the PSIs for the best wear, even wear and longevity would greatly be appreciated. Thanks!
  2. Jul 12, 2024 at 8:54 PM
    AZBoatHauler
    So.Arizona
    For comfort - I run 38-40psi all around. Mine is a tiny bit heavier than your truck. Ideal wear is probably a little higher - 45-50 maybe.
    ATV25 and mountainpete like this.
  3. Jul 12, 2024 at 11:00 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Yeah I like 47-48psi
    ATV25 likes this.
  4. Jul 12, 2024 at 11:03 PM
    blenton
    blenton New Member
    Load range E? I can’t remember if those are one of the oddball sizes that come in a D or E rating.
  5. Jul 13, 2024 at 6:32 AM
    brkncly
    Oregon
    Yes
  6. Jul 13, 2024 at 8:27 AM
    blenton
    blenton New Member
  7. Jul 13, 2024 at 8:46 AM
    brkncly
    Oregon
    Do guys take readings cold?
  8. Jul 13, 2024 at 8:51 AM
    Dreaded_marauder
    Dreaded_marauder New Member
    2020 Tundra TRDOR 2018 4Runner TRDOR
    So how you do these calculations is finding what your tire placard says your tire pressures and tire size is. Mine was P275/65/18 at 30psi front 33psi rear. So we find the pressure those tires hold at 30 and 33. So for 30 it’s about 2400lbs and 33 it’s about 2550lbs. Now P rated tires on a truck or suv actually are d-rated 10 percent. So your 2400 lbs is actually 2181 lbs when you devide 2400 by 1.1 . So now we know that the tires need to hold 2181 lbs in the front and 2318lbs in the rear to meet the manufacturer max load of the vehicle. So now go to the load inflation chart and find what your new tires are and what pressure meets 2181 front and 2318 rear. For me and my 35/12.5/17 toyo RT trails I run 33 front and 36 rear and that meets the weight of the truck to the weight the tire can handle at those pressures. Now this d-rating P-rated tires is only done to P-rated. If your tire placard on the driver door sill does not say P before the tire size then you have a Eurometric tire and that does not get d-rated. Good luck!
    blenton likes this.
  9. Jul 13, 2024 at 8:52 AM
    blenton
    blenton New Member
    Yes. Doesn’t matter what it is hot - the tire is designed for the pressure increase from the tire heating up. Cold is the correct way to read and fill the tire.
    TheBeast and AZBoatHauler like this.
  10. Jul 13, 2024 at 8:58 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    OP I'd do the the chalk test to get a perfect number for your specific rig/tires.
    Chalk Test:
    1) Buy or find some sidewalk chalk
    2) Find a straight, level, smooth stretch of road (200m)
    3) Draw a 2" wide chalk line across the tread of 2 tires (1 front/1 rear)
    4) Drive a couple hundred yards and assess the wear based on what chalk residue remains.
    *Ideally the wear would be even across the tread width. If more chalk remains in the center, you're under inflated, if more chalk remains on the edges, you're overinflated. Repeat the test as many times as you need to find the right number, which will likely differ from the front tires to the rear by a couple PSI.
    reywcms likes this.
  11. Jul 13, 2024 at 11:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This
  12. Jul 13, 2024 at 11:28 AM
    AZBoatHauler
    So.Arizona
    My gripe with the chalk test - tire dynamics and shape are way different at 75-80mph than the 15-20mph that most people perform the test at.
    MEWaters and blenton like this.
  13. Jul 13, 2024 at 11:59 AM
    blenton
    blenton New Member
    This is true. Also, MFG's are starting to manipulate tire shapes a little. Look at the cooper AT3; the tread face is purposely crowned so it could very easily show a different chalk test.
  14. Jul 13, 2024 at 12:55 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Good point. Still not sure there's a better way to go about it though
  15. Jul 13, 2024 at 1:33 PM
    AZBoatHauler
    So.Arizona
    I’d argue the load table being referenced is a better tool. Post #6.
    blenton likes this.
