2015 Tundra Power Steering leak
Discussion in 'General Tundra Discussion' started by Ronnewtotundra, Jul 12, 2024.
  1. Jul 12, 2024 at 2:59 PM
    Ronnewtotundra
    Ronnewtotundra [OP] New Member
    2015 Tundra power steering leak
    I have a Tundra that started leaking power steering fluid. Took it to the shop to get checked out. They could not find where it was leaking from. I was told it will need to have the frame removed from the cab to see where it's leaking from. I was also told it may need a part that cost 2 - 3k just for the part. If that's it?? 600 for new lines and approx 8 to 10 hrs labor. Does this sound right. ?? I can't find any parts online for that cost. Any help would be great. Thanks so much
  2. Jul 12, 2024 at 6:21 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    First they say they can’t find where the leak is coming from but suggest a very expensive job I would get 2nd and 3rd opinions. My guess it’s an o ring or steering rack. The power steering system is high pressure, shouldn’t be too hard to find the leak
    on a scale of 1-10 how bad is the leak?
  3. Jul 12, 2024 at 6:27 PM
    Ronnewtotundra
    About a 9.. do u really need to drop the frame to get to anything? Is there a part that cost that much? Thanks for your help
  4. Jul 12, 2024 at 7:25 PM
    Orions Dad
    2007 Tundra 4.7L
    No. The most expensive part is the rack which can cost $350-600, never heard of dropping the frame but have heard of removing the front diff if you have 4x4. The entire job could cost $3k parts + labor
    There are some YouTube videos that would give you an idea about the job
    Is your trucks steering any different since the leaking started?
  5. Jul 12, 2024 at 7:31 PM
    Ronnewtotundra
    That's what I've been seeing. Around 600 plus core cost. Yes it's a 4x4. They said they have to have the wheels on the ground and cab in the air to find the leak. 8 to 10 hr job. Thanks for your info. Seemed very high to me.
