A/C just crapped out!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bmw345, Apr 27, 2023.
  1. Apr 27, 2023 at 9:43 AM
    bmw345
    bmw345 [OP] New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    2018 with 48k miles. Also appears to be leaking refrigerant oil onto my skid plate. Anyone else have their AC fail with such low mileage. Goes in tomorrow.
  2. Apr 27, 2023 at 9:57 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    The AC light on the dash was blinking on mine and no cold air, ended up just being the relay for the magnetic clutch. Having the AC go out is not fun.
    equin and MALIBU1794DC like this.
  3. Apr 27, 2023 at 10:12 AM
    bmw345
    CT
    No dash lights for me! Just no cold air out of the vents.
  4. Apr 27, 2023 at 10:19 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    Ya that sucks, I assume you have the dual climate control as well since you have the Platinum. Our Rav4 has that and it makes it harder to troubleshoot. Hopefully it ends up just being an easy leak and a not to expensive fix.
    bmw345[QUOTED][OP] likes this.
  5. Apr 27, 2023 at 10:28 AM
    bmw345
    CT
    Extended warranty, hopefully fully covered!
  6. Apr 27, 2023 at 8:33 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Usually what we see at the shop is a rock or small stone thru the condenser on something that young.
    Johnmatrix and batman900 like this.
  7. Apr 27, 2023 at 8:42 PM
    Hopefully covered under your extended warranty (it should).
    On a side note, really like the look of your platinum. Those Methods look great.
  8. Apr 27, 2023 at 8:45 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    My GMC did this and it was a cracked evap core.
    my Subaru was a bad compressor.
    Both failed within 30k miles.
    bmw345[OP] likes this.
  9. Apr 27, 2023 at 9:11 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Can you please give me a part number for that relay?
    For years my AC works 95% of the time.
    But something cuts the compressor off for anywhere from 5 seconds to 15 minutes and the AC blows warm air.
    If I hit a bump in the road the cold air kicks back in.
    Maybe it is that relay flaking out on me.
    The dealership can't fix it, because they can't replicate the problem.
    Thanks.
  10. Apr 27, 2023 at 11:20 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    No... I had the clutch seize up on the compressor on my '08 last year at around 245k. So, I ended up replacing the compressor and related parts. Crazy thing is that toward the end of summer it started blowing warm air again, but I was already out of warranty due to mileage on the repair. Did some quick troubleshooting at home and found the Schrader valve on the L pressure access port to be leaking. So, that was a pretty easy and cheap fix, but I had to pay for another round of freon since it had all leaked out.
    I hope they find the source of your trouble quickly and take care of it w/o too much headache though :thumbsup:
  11. Apr 28, 2023 at 5:30 AM
    bmw345
    CT
    Hope its not that, sounds like warranty would not cover that!
  12. Apr 29, 2023 at 7:48 AM
    bmw345
    CT
    O-ring on the condenser let go so they are replacing the condenser and O-ring under warranty. Second time the Extended warranty paid for itself!
    equin, Henry1jg, batman900 and 4 others like this.
  13. Apr 29, 2023 at 11:00 AM
    Tripleconpanna
    Good to hear that it's an easy fix and more importantly, that they are taking care of you!!!!!
  14. Apr 29, 2023 at 12:04 PM
    bmw345
    CT
    Yes they have, been cruising around in the RAV 4 hybrid the warranty provided for me. I put 100 miles on it and the gas gauge barely moved!
  15. May 29, 2023 at 5:10 AM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
    I've had that problem on tundras before. It turned out to be the relay. Simple fix
  16. May 29, 2023 at 7:08 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I replaced the relay, a few days ago.
    I don't think it has cut out since..:D
    MadMaxCanon likes this.
  17. May 29, 2023 at 8:15 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Mine stopped blowing cold. Discovered the ac line was rubbing on the suspension and got a hole. Those headlines run near the frame.
  18. May 29, 2023 at 2:02 PM
    bmw345
    CT
    Mine was fixed. Apparently an o-ring let go on the condenser. Replaced the whole condenser under extended warranty! Cost me 0.
    Henry1jg and ZappBrannigan like this.
  19. May 30, 2023 at 4:45 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    When I had my 2016 the condenser crapped out with 10k miles
  20. Jun 5, 2023 at 7:36 PM
    Jakopotamus
    Jakopotamus New Member
    Just got my 18 white crewman from the shop today. Had to add a pound of refrigerant. Also said there were 2 other in today with the same issue.
  21. Jul 12, 2024 at 11:24 AM
    GTthegreat
    GTthegreat New Member
    2018 Tundra 5.7 Crewmax
    I had the issue on my 2014 Tundra. The ac light was blinking. I replaced a relay, (I think HTR 50A) problem solved.
    Trying to do the same on my 2018 Tundra. There is on HTR 50A relay even though the fuse box cover shows one.
    Any ideas?
