2017 Platinum 4x4 MGM build
Discussion in '2.5 Gen Builds (2014-2021)' started by PaulROahu, May 19, 2017.
  1. Mar 9, 2022 at 10:35 PM
    #241
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    another mollie mount attachment: 48” flexible traction Mat, bag, Velcro straps with black metal zip lock with combination lock. Already used it once to help another non 4x4 truck out of the sand.
  2. Mar 14, 2022 at 2:44 PM
    #242
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Seven months of waiting with lost rims, manufacturing delays, shipping delays, COVID issues. Today dropped of my truck to complete the wicked rear traction bars, slotted and drilled new rotors, ceramic pads, stainless steel braided brake lines, new Rims and tires. This is the before pics. New pics once instal is completed
  3. Mar 17, 2022 at 10:19 PM
    #243
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Rims:20/10/-19, Tires:35/12.5/20. Still need to ceramic coat the rims and Dura coat the tires. Slotted & drilled rotors, ceramic pads & steel braided brake lines
    vanthesupreme likes this.
  4. Mar 18, 2022 at 10:19 PM
    #244
    PaulROahu
    Paul
    Kaneohe, Hawaii
    New: slotted/drilled rotors, ceramic pads, steel braided break lines, rims, tires, dura coated tires and dura nano coated rims
  5. Mar 19, 2022 at 4:36 PM
    #245
    PaulROahu
    Paul
    Kaneohe, Hawaii
    2017: new platinum
    2020: 3.5” RC lift, 33” tires plus tons of mods
    2022: 6” Vertex lift, 35” tires plus more mods
  6. Mar 24, 2022 at 9:26 PM
    #246
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Took it for a short drive, still breaking in the NEW: slotted/drilled rotors, ceramic pads, rims & tires.
    2014 Black tundra likes this.
  7. Apr 16, 2022 at 7:33 PM
    #247
    PaulROahu
    Paul
    Kaneohe, Hawaii
    When not in use….after cleaned and detailed, truck cover and tire/rim cover
  8. Jun 28, 2022 at 1:34 PM
    #248
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Cat shield top notch on quality. Protects all (4) cats, security bolt threads, 1/4” stainless steel and powder coated black, vents for heat displacement, company logo, design is one of the best out there. 11/10…very happy and can sleep better knowing it’s going to make it HARDER to take my cats off
    J&ATundra likes this.
  9. Aug 2, 2022 at 4:55 PM
    #249
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Nitro 4.88 gearings still break in period. Need them to turn my Hostile Rage 20/10/-19 rims & Arroyo Tamarock M/T 35/12.5/20 tires with RC 6” lift and Vertex coil overs
  10. Aug 2, 2022 at 8:40 PM
    #250
    PaulROahu
    Paul
    Kaneohe, Hawaii
    One of many AJT parts installed
    shawn3210 likes this.
  11. Aug 4, 2022 at 6:48 PM
    #251
    PaulROahu
    Paul
    Kaneohe, Hawaii
    This is my (4th) step bar. Finally they had them in stock. (1) factory running boards, (2) factory nerf bars, (3) Rough Country 2 step bar. (4) just delivered NFab 3 step bars 3” Matt’s black
  12. Aug 4, 2022 at 6:50 PM
    #252
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Another AJT parts….door handles and door panel trim. Now I have ALL there products
  13. Aug 24, 2022 at 3:46 AM
    #253
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Any issues installing this with the 6 in lift.
  14. Aug 24, 2022 at 3:51 AM
    #254
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Need a bracket to attach the front, I bent mine front to attach to the bottom of lift bracket which actually looks better
    Major[QUOTED] likes this.
  15. Aug 27, 2022 at 1:33 PM
    #255
    PaulROahu
    Paul
    Kaneohe, Hawaii
    After Nitro 4.88 gearing, went with 6”Vertex lift, 35” average 11.5 mpg city. New mpg 14.5, worth swapping gears
    RoniusMaximus likes this.
  16. Aug 30, 2022 at 1:50 PM
    #256
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Thanks for the info, I'm guess the bracket was fabbed by you? If you get under the truck again anytime would you mind snapping a pic of what you're referencing. Looking to go the same route. Tango Yankee.
  17. Feb 5, 2023 at 7:31 PM
    #257
    PaulROahu
    Paul
    Kaneohe, Hawaii
    powder coated black “WICKED CUSTOMS” rear traction bar for 6” lift
  18. Feb 7, 2023 at 6:02 PM
    #258
    PaulROahu
    Paul
    Kaneohe, Hawaii
    VIPER CUT front bumper. prior 3/4” bumper spacer. viper cut 2” on lower vertical, 1” on lower fog light, 6.25” on front bend and 5.5” on outer bend. used flat dremil then sanded for easier instal of fender trim later. cut lower inner fog lamp bracket with angle grinder, sand and paint. cut lower plastic inner fender drill hole for zip tie on lower inner plastic. removed outside fender mounting clip. cut center section off, then put back on newly cut fender end cap, measure bottom bracket, drill hole and drill another hole in the middle to add a crew to secure the 2pcs together. use factory (2)10mm bolt, push pin on body mount near coil revisor, (1) zip ties on inner lower fog lamp bracket with previous drilled hole for a total of 4 anchor points and no heating just push forward with a stock factory look. add fender trim on viper cut. over 6” clearance and over 5” at fill lock. ALL THIS TO CLEAR 37” tires
    be_unscared and TOYOTARIG like this.
  19. Feb 15, 2023 at 8:59 PM
    #259
    PaulROahu
    Paul
    Kaneohe, Hawaii
    the very last DE-chromed part of my Tundra. Bushwacker fender trim bolts. (4) coats matte black, (4) coats clear coat.
  20. Mar 1, 2023 at 11:50 AM
    #260
    PaulROahu
    Paul
    Kaneohe, Hawaii
    after researching viper cut fenders here is my mounting points as no one really shared how to properly secure the fenders, plastic trim while keeping the factory look/integrity.
    1. use (3) factory mounting points, 1 push pin on the frame near the coil over revisor, 2 outer fender clips had to cut out center pc and remount to make room for shorter fender length).
    2. drilled holes on fog lamp bracket and lower plastic liner for zip ties to pass through ( drilled hole on plastic to be close to where the brackets are for shorter zip tie lengths)
    3. secure zip tie to plastic liner and metal fog lamp brackets at 3 points equal distance for better stability while driving.
    4. 6 mounting point with zero play/flex and still keeping factory look and integrity
    SHAKA U F4KA likes this.
  21. Mar 4, 2023 at 2:30 PM
    #261
    PaulROahu
    Paul
    Kaneohe, Hawaii
    going from RC 2 step hoop nerf bars to just installed NFab 3 step hoop nerf bars
  22. Mar 4, 2023 at 3:08 PM
    #262
    PaulROahu
    Paul
    Kaneohe, Hawaii
    repping my “Veteran Badge” for my Time in the Army Infantry 11Hotel/TOW gunner
    Badderup likes this.
  23. Mar 7, 2023 at 4:25 PM
    #263
    PaulROahu
    Paul
    Kaneohe, Hawaii
    ICon delta joint UCA, Falken Wildpeak AT3W 37/12.5/20 installed. next off to alignment
  24. Mar 8, 2023 at 8:49 PM
    #264
    PaulROahu
    Paul
    Kaneohe, Hawaii
    had to swap out for SPC UCA to get alignment to specs. these 37” are a beast and makes my 6” lift look better
  25. Mar 10, 2023 at 10:05 PM
    #265
    PaulROahu
    Paul
    Kaneohe, Hawaii
    my last tires had Dura coat on my 35”. this time used Exoforma permashine tire coating on my new 37”. very similar as both has no sling and dry to the touch. only 2 coats on these after a very detailed cleaning before the coat.
  26. Mar 11, 2023 at 7:49 PM
    #266
    PaulROahu
    Paul
    Kaneohe, Hawaii
    finally Falken Wildpeaks AT3W 37” tires done the right way….RC 6” lift, SPC UCA, Coach builder bumper spacer & steering, DIY viper cut fender, SDHQ BMC & pinch weld, Hostile correct rim offset, Exoforma tire shine
  27. Mar 19, 2023 at 5:47 PM
    #267
    PaulROahu
    Paul
    Kaneohe, Hawaii
    current status:6” lift, 37”
  28. Mar 20, 2023 at 11:25 AM
    #268
    Badderup
    Badderup New Member
    A.J.
    Utah
    2019 Crew max
    Vent visors Side steps - wife and daughter are short
    Beautiful truck. Where did you get your grill logo from?
  29. Mar 20, 2023 at 6:21 PM
    #269
    PaulROahu
    Paul
    Kaneohe, Hawaii
    ordered custom it’s a “T” toyota truck
  30. Jul 12, 2024 at 6:41 AM
    #270
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    How are those 3W liners holdin up after all these years? Just saw an ad for them on IG n thought I'd see what's on the forum.
