Electrical issue due to water intrusion
Discussion in '3rd Gen Tundras (2022+)' started by FLO, Jul 3, 2024.
  1. Jul 8, 2024 at 4:22 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm still pissed off they told you $14K to get your truck running again..
    I'm glad you got it up and running...:thumbsup:
  2. Jul 8, 2024 at 5:13 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Glad it worked out.
    FLO[OP] likes this.
  3. Jul 8, 2024 at 5:33 PM
    SrgJigPog
    SrgJigPog New Member
    '23 Tundra Limited Trd Off Road
    glad to hear your truck is back running fine.
    I have my truck scheduled to get the two front side windows done on Monday. just wanting to make sure you only had your windshield done when this acted up? Not your side windows?
  4. Jul 8, 2024 at 5:39 PM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Windshield only. I don’t think there’s anything to worry about with the sides.
    SrgJigPog likes this.
  5. Jul 8, 2024 at 5:42 PM
    SrgJigPog
    Perfect thanks!
  6. Jul 8, 2024 at 6:07 PM
    c&wsinbad
    c&wsinbad Pay yourself FIRST!
    Clark
    Copperas Cove, Texas
    2024 Magnetic Gray Metallic 1794 w-Saddle interior
    BAKFlip MX4
    From a previous post, you stated the techs had cleaned and applied dielectric grease. Appears they weren't truthful with you in that instance based on your own observation and photo. First strike: Exorbitant quote they gave you initially to fix it. Second strike: Giving you a li9ne of BS regarding what they had done to miti9gate problem. Third strike: Up to you whether you even pitch to them again. I wouldn't! Call it a balk, but I would find another service department.
  7. Jul 8, 2024 at 6:50 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    As someone with almost 40 years as a Substation Electrician working on millions of dollar pieces of outdoor high voltage equipment, I would be laughing uncontrollably at the service person telling me they need to replace a harness for water intrusion and connector contamination…
    Especially in the Pacific Northwest where we see it a lot.
    Lots of small computer connections in today’s power grid equipment. Find the problem, treat the problem correctly.
    Put it back in service.
    Only when something melts and lets the smoke out do you need to replace or repair a harness. The actual computers or controllers, that is something else.
    Sean492, FLO[OP] and Tundrastruck91 like this.
  8. Jul 9, 2024 at 1:36 AM
    wing-2
    wing-2 New Member
    This would (seem to me) to be a simple warranty issue. Obviously water intrusion, and certainly corrosion could not have occurred within an hour. I would think you have dated documentation for the tinting. Good luck.
    FLO[QUOTED][OP] likes this.
  9. Jul 9, 2024 at 3:27 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Yeah I’m still in disbelief how they treated this whole situation. They were hell bent on screwing me over instead of treating a very simple issue. It’s been many years since I owned a new vehicle and had to deal with any dealership. Lots of lessons learned here. Fortunately there are other Toyota dealerships a bit further away next time I need service.
    Sean492 likes this.
  10. Jul 9, 2024 at 3:37 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    The parts department wanted 17 dollars for 1 pre-pinned repair wire. I got 6 connectors, pins and weather seals Ali express for that.
  11. Jul 9, 2024 at 3:42 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Here’s the icing on the cake. When they finally got my truck ready for me, they didn’t even notice this. I went to get in and drive off and noticed it myself and went back to the service manager. Accidents happen but after all the BS they put me through I was red hot! They (supposedly) ordered a new one so I’ll have to check up on it soon.
  12. Jul 9, 2024 at 3:55 AM
    balong48
    balong48 New Member
    2011 Classic Silver Metallic 4Runner Limited
    Better hope that water intrusion doesn’t corrode the connectors in there!!!
    Sorry, too soon??
  13. Jul 9, 2024 at 3:59 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Yeah I mentioned that and took the pic while it was there. They found the cover on the ground in the car wash all scratched up and put it back on. I checked it yesterday and everything looks ok. Mirror functions like it should. Multiple techs and service manager were around it after it came off and nobody noticed lol.
  14. Jul 9, 2024 at 6:00 AM
    c&wsinbad
    Clark
    BAKFlip MX4
    My closest Toyota dealership is about9 miles away. I drive right past it and continue for another 20 miles to get to the one that provides my service.
  15. Jul 9, 2024 at 6:27 AM
    Tom976
    Tom976 New Member
    Tom
    Sadly too many of use do the same thing.... I certainly do as well. I have a dealer maybe 3 miles away? Nope I go to one about 15 miles away just because of the better service.
    c&wsinbad[QUOTED] likes this.
  16. Jul 9, 2024 at 6:55 AM
    BoulderGT3
    Glen
    Good to have dealer choices.
    c&wsinbad likes this.
  17. Jul 10, 2024 at 6:18 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    You should post the dealer name so others can avoid.
