2005 humming noise between 40-50mph
Discussion in '1st Gen Tundras (2000-2006)' started by PSU1998, Jul 3, 2024.
  1. Jul 3, 2024 at 1:38 PM
    PSU1998
    PSU1998 [OP] New Member
    Andrew
    2005 Tundra 2wd 4.7 SR5
    3” front leveling kit
    Hey Guys,
    When I get close to 40mph I start to hear a significant loud humming noise.
    The intensity/pitch of the noise peaks just below 50mph then lessens over 60…
    Anyone with any thoughts?
    Wheel bearing?
    Rear differential?
    Transmission?
    It’s a 2005 2wd SR5 4.7 engine…177k miles
    I had to replace the drive shaft a few years back but haven’t done anything else non engine related
    Started in April
  2. Jul 3, 2024 at 1:56 PM
    Wheel bearings tend to have a wub-wub pulsing sound in my experience, similar to what I initially hear in the 1st one (had to throw in earbuds). Often droning at those speeds.
    I'm nos disputing it's a wheel bearing, but ... Have you checked your bearings with a push/pull, and spinning each wheel individually?
    Jack McCarthy likes this.
  3. Jul 3, 2024 at 2:01 PM
    PSU1998
    Andrew
  4. Jul 6, 2024 at 8:51 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Wheel bearings can be loud and obnoxious without any play what so ever with that method. That will always be play at 3 and 9. This is really a very rudimentary check.
    When you're cruising at 50 or so with the noise, pop the trans into neutral to see if noise remains.
    When you're cruising at 50 (either with throttle or without, as long as you're getting the hum) add a little side loading to the wheels by taking a route that has a slight turn to it. A nice gentle curve will do. Note if the hum changes at all - whether it goes away completely or gets louder...
    Both of these tests, if positive, point to wheel bearing (not diff).
    shifty` likes this.
  5. Jul 6, 2024 at 9:49 AM
    Sounds like a bad bearing when spinning, if the caliper isn't grabbing. You only had one wheel jacked at a time while doing that, right?
    The 3 and 9 action, you can get that in a few cases, including when you jack both wheels up while doing it, and if your rack bushings are bad. Be sure to look for other play when doing it to make sure it's not the rack, and it's not the LBJ. LBJ are a catastophic killer in these trucks.
    All that to say, I agree fully w/Noah, he's totally on-point.
  6. Jul 7, 2024 at 4:39 AM
    PSU1998
    Andrew
    When I put the truck in neutral the humming noise is unaffected…yesterday I drove on some windy roads and I really do not notice a change in the noise while turning left or right…it is very consistent from 40-50 mph…
  7. Jul 7, 2024 at 5:08 AM
    noahrexion
    Washington
    2005 4WD DC
    Do you have another set of wheels and tires you can try to swap over? What kind of tires (size/type/wear pattern on them) are you rolling?
  8. Jul 7, 2024 at 7:49 AM
    PSU1998
    Andrew
    So I got friend with the identical truck
    He is coming over in the morning and we are going to swap tires…thanks for the idea..
    The front tires are definitely wearing in the outside edge more. I’ll attach pictures…worth ruling out that it’s not tire noise…
    Those are the front tires the back tires are wearing evenly
    Thank you!
    I’ll post the results tomorrow
  9. Jul 8, 2024 at 8:00 AM
    PSU1998
    Andrew
    Thank you for the advice!
    I swapped the four tires out with my friends truck and the noise WAS 100% GONE….
    Definitely the tires…much better than the other possibilities
    I have a nice quiet ride again!
  10. Jul 8, 2024 at 9:56 AM
    Interesting. That said, I'm still suspicious of the play in that video. But without being there and being able to feel/see with my own hands ...
