2016 Crewmax - Driver's door won't unlock
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr_Wilbur, Jul 7, 2024.
  1. Jul 7, 2024 at 3:47 PM
    Mr_Wilbur
    Mr_Wilbur [OP] New Member
    Wil
    2016 Tundra TSS
    My 2016 Tundra Crewmax. driver's door will not unlock with key fob, door button or when putting vehicle into park. All other doors lock/unlock properly; the drivers door will lock properly, just not unlock, except manually with the key. I replaced the actuator, did not solve the problem. I assume it would not be a fuse since all other operations at the door are working. Any help appreciated.
    PS. Continuity between the actuator connector and connector behind the kickplate is good.
  2. Jul 7, 2024 at 5:25 PM
    Retired...finally
    I would go back in and disconnect the lock motor from the linkage and see it it works both ways. These used to be simple permanent magnet DC motors that reversed by swaping polarity. If the lock motor (actuator) has two wires it's the simple swap polarity type.
