  1. Jul 6, 2024 at 3:47 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    It's 2-3 plastic screw type connectors in those large round holes.
    FireFinder44[QUOTED] likes this.
  2. Jul 6, 2024 at 4:01 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Link?
    DPF88130 likes this.
  3. Jul 6, 2024 at 4:04 PM
    DPF88130
    DPF88130 New Member
    2018 1794 Edition CMSB
    8 inch lift 37x12.50/20 ARE topper
    Thanks - the wife kept insisting I needed a shop when we built the new house. So I built a 1500sqft shop 30x50x15 - she was right !
  4. Jul 6, 2024 at 4:11 PM
    Nice! I wish mine was like that. I could always use more room. What was your AFSC?
  5. Jul 6, 2024 at 4:28 PM
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
  6. Jul 6, 2024 at 4:33 PM
    easleycrawler
    Travis
  7. Jul 6, 2024 at 4:33 PM
    DPF88130
    DPF88130 New Member
    4N0X1- medic 22 years minus 4 years for BMTI duty 1985-1989
    HulkSmurf14 and Tripleconpanna like this.
  8. Jul 6, 2024 at 4:34 PM
    RobertD
    Robert
    DFW, Texas
    2 cents, you can buy the Revesol one for $25 more (yes, its not always in stock) but a lot of folks on the forum have had them for many years and they hold up well and are good quality.
  9. Jul 6, 2024 at 4:47 PM
    Nice. I was a jet engine mechanic. I was in from 1991-2015. I still remember my TI. Some things you never forget lol.
    DPF88130[QUOTED] likes this.
  10. Jul 6, 2024 at 4:54 PM
    DPF88130
    DPF88130 New Member
    Thank you for your service - and yes you are correct - ha lol
  11. Jul 6, 2024 at 5:17 PM
    koditten
    Kirk
    Midland of the Mitten
  12. Jul 6, 2024 at 5:25 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    That I did in the garage, and the Pro is high enough that I can get under it without jacking it up. My Ridgid 18v fan fits under the truck at the transmission/driveshaft location, so it honestly wasn't terrible. Now when I went to finish the wiring at the ass end of the truck, which was out in the 100F sun, that was toasty.
    I took a break in the middle of the job when the HVAC guy showed up to replace a blown capacitor in the heat pump. Pisses me off, that thing is just 2.5 years old, and the previous heat pump lasted 20+ years.
  13. Jul 6, 2024 at 5:39 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  14. Jul 6, 2024 at 5:41 PM
    BOSSARU
    Splendora, TX
    Pretty good, I was worried about the top stripe being straight but it's perfect. My only complaint could be that they didn't account for the thickness of the leather, which pushes the steering wheel controls in, which makes it tight to fit the airbag in. So the airbag rubs the control panels when you hit the horn. Not a big deal to me, since I usually flash my high beams and wave my fist out the window when someone mildly inconveniences me :D
  15. Jul 6, 2024 at 5:43 PM
    blanchard7684
    blanchard7684 New Member
    Transmission flush and coolant flush today.
    i have 44K miles.
    i didn’t put on a trans cooler on my 2019 until about 20K miles.
    The fluid told the story . It was very dark and almost brown.
    I have done transmission fluid changes on 5th gen 4 runners with more miles and the fluid looked brand new.
    the cooler works.
  16. Jul 6, 2024 at 7:10 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Put in new brake pads. Got a bit over 40k miles on the original oem pads that came on the truck when I got it new, only took me 7 years lol.
    Also rotated the 37s, little shimmy I was feeling seems to be gone now.
    bulldog93, CaptRussia253 and DPF88130 like this.
  17. Jul 6, 2024 at 7:20 PM
    Vahret832
    Vahret832 New Member
    Rick
  18. Jul 6, 2024 at 8:06 PM
    scraigb
    scraigb New Member
    Colorado Springs
    2014 Tundra
    Just got it
    I received my front kings today and ordered the rear. Will I get away with stock uca? I was thinking no problem since I am not going to lift it much, but I was not considering the resi hoses.
  19. Jul 6, 2024 at 8:12 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    My personal favorite UCA's Are:
    Camburg (recently acquired with massive price increase)
    Bilstein-no ball joint cap
    OME- dust cap blocks zerk
    JBA- Easiest service of the bunch.
  20. Jul 6, 2024 at 8:32 PM
    BOSSARU
    Splendora, TX
    You only need aftermarket UCAs if you ordered extended travel (ET) Kings. Whoever you bought them from should have informed you of the UCA requirement if you ordered them ET.
    ATV25 likes this.
  21. Jul 6, 2024 at 8:44 PM
    centex
    centex New Member
    Drove it to the movies and back. Spd exhaust is awesome. It got rained on.
    bulldog93 and RobertD like this.
  22. Jul 6, 2024 at 9:16 PM
    mrmahi
    mrmahi New Member
    2014 Tundra
    New meats...Firestone Destination MT2s (295 70 18)
  23. Jul 6, 2024 at 9:32 PM
    ikarus
    ikarus New Member
    2021 TRD Sport
    Ceramic tint - and I think it's time to work on debadging a little
  24. Jul 7, 2024 at 1:05 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went out for some testing and it’s unreal the difference in performance. My fast pace before over my whoop section I test and tune on was about 55-65.
    I ripped through the same section at 70+ and it felt like I was not even trying. The 3.0 custom valving is unreal. I didn’t even touch the bypass tubes at all.
    The additional spare in the rear also made a difference on how the rear acted. Now time to redo the rear shocks and see how far we can push a leaf spring setup. I had a sxs try and race me over another whoop section and I looked down as I was pulling away and saw 80. Overall blown away.
  25. Jul 7, 2024 at 1:11 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    New shifter came in.
  26. Jul 7, 2024 at 3:19 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Took off the EBC Yellowstuff pads. After 16.5k miles the fronts were done, down shy of 4mm and getting close, the rears looked fine, but I was ready to move on to my Akebono ACT1303 / ACT1304A set front and rear and enjoy the quiet, dust-free life. I can tell I lost a little initial bite in the braking power though, which isn't a huge deal, I'm not racing anyone over here.
  27. Jul 7, 2024 at 3:56 PM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    2016 Toyota Tundra SR5
    Just uploaded some startup images and display off images in my Tundra.
    The max I could upload to each was 3 images in each.
    Here are the 3 in Startup Images
    Here are the 3 in Display Off Images
    I have a file of 25 images total that I can use. So, I can swap them out when I want.
  28. Jul 7, 2024 at 4:13 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Tore a hamstring (pulled with blood bruise) so 90 days rest, that's what I got when pushing it on a sprint. Was warmed up too but noticed quads and hams were still 'good' sore and not fully recovered from a leg weight work-out 3 days prior, during warm-up mile run. Lesson learned.
    https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-3019#post-3507247
    So you didn't panic sell yet ? Rear diff still holding up ?
    bulldog93 and koditten like this.
  29. Jul 7, 2024 at 4:23 PM
    koditten
    Kirk
    You lucky you can do that. They locked that out for us '21 owners.
    I'm not an audio file, but am seriously leaning towards an after market head unit.
    I can't tell good sound from crap sound, but I can't here a great improvement in sound in this JBL unit vs my factory noise unit in my '08.
  30. Jul 7, 2024 at 4:31 PM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    @koditten the place I got my images from the guy told me These WILL NOT work on the 2020 model year and up Tundra's at this time. Toyota removed the ability to customize the startup image for those years.
    Not sure why they did that.
    Maybe it might work out if you change head unit.
    Here is where I got all my images from. View Tundra Screens by PottersWorkCo on Etsy
    I saw a few images under his Tacoma section. I asked if he could do them in Tundra. He told me yes. So, he is working on that now, will let me know when they are ready.
    koditten likes this.
