Horn goes off randomly
Discussion in 'General Tundra Discussion' started by Adonai Tsidkenu, Jul 6, 2024.
  1. Jul 6, 2024 at 7:51 AM
    Adonai Tsidkenu
    Adonai Tsidkenu [OP] New Member
    Mac
    2021 Tundra 1794
    Hello from the Texas Hill Country
    I bought another 1794 back in March, it is a 2021 with only 18K miles…beautiful truck.
    yet…
    At times, my alarm goes off in my driveway…I’ve taken it for a diagnostic at Toyota; of course they didn’t find anything…I mentioned that some folks who experience this bizarre issue might have narrowed it down to the glass-break sensor, and I told them to remove the relay rather than pull out the dash to chase a faulty wire. They ended up just turning off the sensor from the software center on their dongle.
    it doesn’t go off nearly as often, but it’s still happening 2-4 times each week. They want me to take it in again, but I don’t think they’re capable of problem solving when it comes to the small sample set of Tundra owners who are experiencing this seriously annoying problem.
    Has anyone figured it out? Should I turn off the auto lock lake Ranger84 ended up doing? The truck stays in my driveway 80% of the time anyway…I work from home…so I’m not opposed to turning off that feature if it means I don’t have to scramble for my fob at 1030 pm when it goes off (fysa, it typically goes off then turns off on its own within 5-10 sec).
  2. Jul 6, 2024 at 8:51 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    If you are comfortable with doing it, pull the dome fuse for a day or 2 and see if it still does it..
    Something may be shorting out causing your alarm to think the door has been opened..
    If that stops the issue, tell the dealership and it may give them something to go on.
    Also get your battery tested.
    I usually only get 3 or 4 years out of vehicle battery..
    I use this tester..
    Amazon.com: KONNWEI KW208 12V Car Battery Tester, 100-2000 CCA Load Tester Automotive Alternator Tester Digital Auto Battery Analyzer Charging Cranking System Tester for Truck Marine Motorcycle SUV Boat : Automotive
    “J” likes this.
  3. Jul 6, 2024 at 11:41 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Sounds like Tundra Tourette's Syndrome!
  4. Jul 7, 2024 at 6:59 PM
    Adonai Tsidkenu
    Mac
    2021 Tundra 1794
    Thanks Dada, I turned it in and included your feedback with the Toyota Advisor…along with other things they could look for.
    1lowlife likes this.
  5. Jul 7, 2024 at 7:00 PM
    Adonai Tsidkenu
    Mac
    2021 Tundra 1794
    Howdy Bakershack
    yeah, this is my fourth Tundra, I’ve never had an issue with the first three…this alarm thing is stupid
    Bakershack likes this.
  6. Aug 24, 2025 at 7:44 AM
    Spunkd13
    Spunkd13 New Member
    2020 tundra limited cement
    Was this ever resolved? My 2020 just did it for the first time. 34K miles but still has the original battery. Battery gives no hints of being bad yet, starts strong and charging looks good. Connections to battery are tight and clean.
