Interesting informed take on the Tundra Recall
Discussion in '3rd Gen Tundras (2022+)' started by cmiles97, Jun 26, 2024.
  1. Jul 4, 2024 at 5:14 AM
    #301
    Dirtdog
    Dirtdog New Member
    2023 Tundra SR5 TRD off road premium
    The cutoff date for the recall was 2/13/23. My truck was built on 2/14/23.
  2. Jul 4, 2024 at 5:23 AM
    #302
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    No wondering involved. If you do not have notification in the app or put your VIN in the NHTSA webpage https://www.nhtsa.gov/recalls and does not show up, your engine was assembled after the process change. The safety recall is based on engine serial number associated to your VIN.
  3. Jul 4, 2024 at 5:30 AM
    #303
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    I don’t want to kick a hornets nest but this makes me pretty curious why people are still ~afraid of the 2024s. Do they not believe the ‘improved procedures’ would have fixed the problem?
  4. Jul 4, 2024 at 5:58 AM
    #304
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    I am not. I bought one last week.
  5. Jul 4, 2024 at 6:17 AM
    #305
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I was wrong my truck was ordered in Feb 23 but built in early March 23 so it is not in the recall and should have the improved engine processing.
    thomez likes this.
  6. Jul 4, 2024 at 6:24 AM
    #306
    thomez
    thomez New Member
    NE Ohio
    I mean, same. ‍
    Tundrastruck91 likes this.
  7. Jul 4, 2024 at 6:42 AM
    #307
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Because there are confirmed 24 failures
    szabo101 and Retired...finally like this.
  8. Jul 4, 2024 at 6:43 AM
    #308
    VCheng
    VCheng New Member
    Upstate NY
    My truck is exceeding my initial expectations thus far, to be honest. Once fully dialed in, I expect a long and trouble free service life from it, just like all my previous Toyotas, the present overblown hoopla notwithstanding.
  9. Jul 4, 2024 at 6:45 AM
    #309
    thomez
    thomez New Member
    NE Ohio
    From the same underlying issue, though? Or different problems entirely?
  10. Jul 4, 2024 at 6:45 AM
    #310
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    You're carping about a 20 year old truck that you bought used that has been to the moon and back on a current gen forum?
    What am I missing?
    raylo and JLS in WA like this.
  11. Jul 4, 2024 at 7:11 AM
    #311
    blschaefer1
    blschaefer1 New Member
    Source?
  12. Jul 4, 2024 at 7:27 AM
    #312
    kirkb
    DFW
    I'm not going to go a search every thread again nor can I say with 100% positivity the failures are exactly the same.
    https://docs.google.com/spreadsheet...XpeUogyH5shM/edit?gid=780956012#gid=780956012
    Obviously that spreadsheet is a small sample of all failures. Also, a lot of information from other now deleted threads has vaporized when a member was ejected from these forums a while back
  13. Jul 4, 2024 at 7:29 AM
    #313
    Canman
    Canman New Member
    2007 Crewmax Limited
    You did miss the fact that I said I’m done here, and go to my build thread if you wanted to debate.
  14. Jul 4, 2024 at 7:31 AM
    #314
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I've asked for sources of confirmed '24 bearing failures a few times. Crickets.
  15. Jul 4, 2024 at 7:34 AM
    #315
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    So what does a owner do that has a perfectly good running truck and there is a engine recall? If Toyota does a short block would you go in and have it done?
  16. Jul 4, 2024 at 7:38 AM
    #316
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    This “cleaning” process will hopefully help the #1 and 4 bearings? Those other two bearings are not failing.
    :monocle:
  17. Jul 4, 2024 at 7:41 AM
    #317
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    From what people have posted. If you have a safety recall this is tagged on your vehicle. Meaning anyone who looks up your vehicle probably including insurance will still see this pending safety recall. Also selling your vehicle will show if the safety recall was rectified.
  18. Jul 4, 2024 at 7:52 AM
    #318
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Mine has been doing this from the beginning, right off the lot. Over a year and still waiting on the dealer to get all the parts to replace it.
  19. Jul 4, 2024 at 7:58 AM
    #319
    VCheng
    VCheng New Member
    Upstate NY
    If my 2024 truck has such a major repair, I would get it fixed by Toyota and then trade it in. Until and if that happens, I intend to use it as I would have anyway.
    Ruggybuggy[QUOTED] likes this.
  20. Jul 4, 2024 at 8:06 AM
    #320
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Same boat, but non-hybrid. Same year, mileage, fixes done, and 2/23 build date after 2/13/23 since not in recall. I try not to worry and just enjoy the truck (minus creaks, wind noise and other minor annoyances on an upper trim truck that are “common for the model” or “could not duplicate” by techs on multiple visits)…hasn’t let me down, yet, and if it does I’ll deal with the pearl clutching, then.
  21. Jul 4, 2024 at 8:51 AM
    #321
    40man
    40man New Member
    Read this thread, a guy claims his 24 had a short block replaced. The last comment from another poster claims his son's 24 has a blown engine from debris.
    https://www.reddit.com/r/ToyotaTundra/comments/1cz18k6/2024_engine_failure_update/
    One user here claimed a failure of a 24. Too bad the other threads got deleted:
    https://docs.google.com/spreadsheet...JKCX5E50vAXpeUogyH5shM/htmlview#gid=780956012
    Attached screenshot from May on the Tundra Reddit of a 24 with a shortblock replacement.
    I've seen a few other posts on 24 failures, but the above are ones I had saved.
    As I have said previously, it appears the # of failures has reduced as 24s have had fewer failures as 22s at the same age and mileage. It is a bit harder to deceipher the 23s as many users reporting failures did not report a failure date (see linked spread sheet linked here or the stickied engine failure thread), so it is unclear how many post recall 23s have failed.
    As I also said before, all car manufacturers have a very small # of engine failures in new models. And they always have. These could be from bad parts, or even with the revised block cleaning process it is possible thay debris could remain in a very small percentage.
    That is why dumping a post-recall Tundra at a big loss right now seems like a poor choice until more info comes out.
    Edit:
    Here is a 2024 Sequoia posted here today with an engine failure:
    https://www.tundras.com/threads/2024-sequoia-engine-failure.145023/
    raylo and kirkb like this.
  22. Jul 4, 2024 at 11:30 AM
    #322
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. I don't do Reddit, FB, or any other social media except this forum and a hunting forum, so I wasn't familiar with those '24 cases.
    What's frustrating to me is people rarely post the actual diagnosed reasons for their engine failures. The Reddit case you posted is an example. We really don't know if that was a bearing failure or some other problem. Same goes for your Sequoia link. Your second link gives me a 404 error.
    I just did the 4th oil change on my Gen 3 at 15K miles, today. I drained the oil into clear plastic jugs so I could inspect it closely. I didn't see a single spec of metal or anything glittery. I also cut the old oil filter open. Nothing abnormal in it, either. So, I'm confident my engine isn't shredding a bearing, and I won't hesitate to take off on my remote fly fishing trip in a few days.
    22whatwedo, 303Gen3 and thomez like this.
  23. Jul 4, 2024 at 11:47 AM
    #323
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  24. Jul 4, 2024 at 11:57 AM
    #324
    Matt2015Tundra
    2023 1794 CrewMax
    Again, none of those are confirmed bearing failures. Engines fail for all kinds of reasons. It seems some people here assume every reported engine failure is the bearing problem.
  25. Jul 4, 2024 at 12:02 PM
    #325
    Mytobytundra23
    Mytobytundra23 New Member
    2023 Tundra Platinum Hybrid
    Have any of these engine issues showed up on the 2023 Tundra Hybrid?
  26. Jul 4, 2024 at 12:04 PM
    #326
    jctmundra
    Northern VT
    Yes. The spreadsheet has a few hybrid entries. It's up to you to decide what "engine blew up" mean. Since we have not seen images of vented blocks which was the old school definition of "blown up" it appears most have simply seized.
    In true internet form, seldom see a post detailing the actual root cause. Only toyota knows.
    kirkb and Westerntowboss like this.
  27. Jul 4, 2024 at 12:37 PM
    #327
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Hybrid is running the exact same motor so it's not out of the potential bearing failure problem. The reason for not seeing as many is because there are less of them on the road.
  28. Jul 4, 2024 at 12:40 PM
    #328
    40man
    40man New Member
    Yep, but most people reporting failures have not reported build date, so unclear if these are pre cleaning procedures or post.
  29. Jul 4, 2024 at 12:52 PM
    #329
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    There has still been a number of reported failures of 2024s (of the exact same nature, spun main bearing #1) on this forum and on some other sites (Facebook, Reddit, etc). Therefore people have speculated that the improved cleaning processes didn't indeed solve the issue.
    Then you get into whether or not they (meaning Toyota) truly believes that they solved the issue or that they plan to extend the recall to 2024s later, and simply wanted to avoid having to issue a stop sale on all 2024 non-hybrids that were still on the lot when they issued the recall
    shorenetworks and thomez[QUOTED] like this.
  30. Jul 4, 2024 at 12:56 PM
    #330
    TRDoffroadPRO
    It maybe the same motor but it isn't the same block. The hybrid block is coded different. Not sure what the differences in the engine are a bolt hole here another coolant or oil passage there. Some of teh attachment points could be different the blocks are not teh same. The non hybrid ends is A and the hybrid an H
