ATF fluid check temp monitor mode
Discussion in '3rd Gen Tundras (2022+)' started by AccordULEV, Jun 30, 2024.
  1. Jun 30, 2024 at 2:17 PM
    AccordULEV
    AccordULEV [OP] New Member
    Travis
    2017 Tundra Flex-Fuel 5.7 V8
    Hi - working on a 2023 Capstone w/ 54K. I'm getting some fluid next weekend and would like to change the ATF myself. However, curious if the ATF fluid temp monitor mode is the same on the new gen Tundras as the last (jumper #4 and #13 pins of OBD port, shift between N and D rapidly to enable ATF temp monitor mode).
    Anyone know if it's the same procedure? If so, hopefully it will keep the engine running on the hybrid system.
    Also, does anyone know if there is a transmission fluid thermostat that has to be pinned open as well?
    I'm not going to use a heat temp gun because that's pretty inaccurate. Plus, I don't know what the specified temp range is anyhow.
    Thanks
  2. Jun 30, 2024 at 3:09 PM
    demfer
    demfer New Member
    Do yourself a favor. With the engine cold, drain what's in the pan and refill the same amount. Consider yourself done for another 20-30k miles.
  3. Jun 30, 2024 at 3:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Store your new ATF in the truck overnite so its the exact same temp/density as that in the tranny when you do the change.
  4. Jun 30, 2024 at 4:31 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    ^^^ that is the way the pre gen3 owers do it! Works fine! And as @demfer says just drain and fill cold = measure what you take out and put back the same. Repeat every week for two more weeks and call it good for another 30k.
  5. Jun 30, 2024 at 5:37 PM
    demfer
    demfer New Member
    My system is to do one exchange around 30k miles and then by 50k miles I’ll do it every other oil change or so which is 5k miles for all my trucks. Cheap insurance and I’ve kept trucks way beyond 400k miles doing this.
    be sure to post photos of the work when you get to it, might be a good reference for members depending on how much of the tranny configuration has changed since the previous gen.
    303Gen3[QUOTED] likes this.
  6. Jun 30, 2024 at 6:33 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I can say this method worked on my 15 Tacoma. I measured what came out cold. The fluid I put back in was the exact temperature it needed to be. I did it during the summer. My pan temp reading was 97 degrees. I started it up and pulled the check plug and drained out till it trickled.
  7. Jun 30, 2024 at 8:08 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    so then you,didn’t,just drain and fill?
  8. Jun 30, 2024 at 8:10 PM
    Oldandfat
    Cannuckastan
    I do this for my wife’s rav (and my tundra when it’s due). I never understood why the “get it up to temp and check the level”.
    drain 2 quarts, then add 2 quarts. (New fluid at same temp as vehicle)
    “But what if it was filled incorrectly at the factory???” Hmmm if I drove for 50k miles when I did this and it drove fine, then just drain and fill
    Tundrastruck91 likes this.
  9. Jun 30, 2024 at 10:38 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    To answer one of your original questions, Yes, it has a thermostat on the side exact same as the 3rd Gen Tacoma that needs to be pinned if doing the change by the book using temperature. I have not read or heard from anyone if the OBD bypass mode works on this truck. I kinda doubt it just because much of the OBD PIDs are different from any previous truck. (whole new ECU)
  10. Jul 1, 2024 at 3:17 AM
    Retired...finally
    Check to see if you have wires in those to places. My 2021 did not. I used my Scangauge to read pan temps but did find it's a very narrow window of time after your idle finally settles down and your pan temps increase out of range. The ability to use the jumper trick brings your idle down right away.
  11. Jul 1, 2024 at 6:36 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Drain and fill
  12. Jul 1, 2024 at 6:46 AM
    303Gen3
    Golden Colorado
    If you trust the oem fill to be correct then the drain and fill is fine. If you don't trust the oem fill then you need to have a level check done. I did not trust the oem on my Tacoma - had the dealer check it at first service and they said it was 1/2 qt low. I checked it afterwards and found their work was good. From then on I just did the drain and fill. Unfortunately, I'm not sure I would trust the dealer anymore based on what I see and hear. I'm going to make the leap of faith and say it came correct from the factory - it drives and shifts perfect even when towing. I'll be doing the drain and fill, but possibly once the level check procedure is verified for the Gen3 I may give it a try.
  13. Jul 1, 2024 at 9:41 AM
    Oldandfat
    Cannuckastan
    but you said you checked pan temperature, and drain valve until trickle?? That’s beyond a simple drain and fill, and essentially is the full procedure?
  14. Jul 1, 2024 at 9:44 AM
    Oldandfat
    Cannuckastan
    this is also my logic. I like to change out tranny, transfer, and differential fluids @50k. If I’ve been driving that long with zero shifting issues, I assume it’s the correct fill from the factory. Drain and fill = just fine.
  15. Jul 1, 2024 at 8:07 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've always disconnected a trans cooler line, fired up the engine via remote start and pumped half to full gallon out and then added the same back in....do that with like 11-12 qts and then let it warm up and follow oem level check process.
    Tunrod likes this.
  16. Jul 2, 2024 at 5:51 AM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Question, when doing the drain and fill, are you not changing the filter also?
  17. Jul 2, 2024 at 5:57 AM
    demfer
    demfer New Member
    Common misconception is that there is a filter element in the transmission pan area. It’s simply a mesh, there is absolutely no reason to disassemble the bolts holding the pan and changing that mesh. Is such absolute overkill and risks gasket misalignment, leaks or stripped bolts.
  18. Jul 2, 2024 at 7:37 AM
    eddiefromcali
    Eddie
    100% Stock
    nope
  19. Jul 2, 2024 at 8:28 AM
    Tiger Tundra
    Tiger Tundra New Member
    2015 Tundra TSS Off Road
    This is called a "drain and fill, among other things"
