Fuel Gauge Reads Empty
Discussion in '2nd Gen Tundras (2007-2013)' started by tluczkiw, Jun 28, 2024.
  1. Jun 28, 2024 at 1:17 PM
    tluczkiw
    tluczkiw [OP] New Member
    Greetings,
    I have a 2011 Flex Fuel with 180K. I have a fuel gauge that reads empty all the time. I suspect the fuel sending unit. Is there anyway to test the fuel gauge sending unit without actually dropping the tank and bench testing? Is there any other issue that could cause this? I am considering putting a new fuel pump in it is the fuel sending unit since there are are miles on the vehicle.
    Any input would be greatly appreciated. Thanks!
  2. Jul 1, 2024 at 5:44 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Toyotas Techstream software will tell you a lot. If you go into the combination meter ecu (cluster) you can see the fuel level under data list. There is a test than can be run to move the gauge from 0 to 1/4, 1/2, 3/4, Full. This will verify the gauge is working.
    The float arm in the tank is just a variable resistor that sends a resistance level based on tank level. That then moves the gauge depending on resistance value the cluster sees from the tank.
    If your fuel level in Techstream is 0 gallons could mean a bad sending unit or bad wiring connection.
    tluczkiw[OP] likes this.
  3. Jul 2, 2024 at 7:15 AM
    tluczkiw
    Thank you all for the feedback!
    Unfortunately I don't have techstream, I guess I should consider purchasing.
    Is there a way to access the fuel sending unit connector without dropping the tank to test? I will check the fuse and wiring as well, thank you!
