Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. May 8, 2024 at 1:26 PM
    #5311
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Black Wolf and Damie Street like this.
  2. May 12, 2024 at 8:48 AM
    #5312
    I grabbed a few small items I needed to refill, or wanted. 30% off. (Use THIRTY as the code)
    @Black Wolf
    Damie Street, Black Wolf and RobertD like this.
  3. May 12, 2024 at 9:22 AM
    #5313
    Kool beans:thumbsup:
    T-Rex266[QUOTED][OP] likes this.
  4. May 14, 2024 at 12:50 PM
    #5314
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    My 07 CM has developed a very small crack on the arm rest center console. It's right along the edge, maybe 2" long, but it hasn't really separated much yet. Is there a product out there that could repair something like this or is my only choice duct tape? Any help would be appreciated.
  5. May 14, 2024 at 3:49 PM
    #5315
    briarpatch
    briarpatch New Member
    Is this vinyl?
  6. May 14, 2024 at 5:40 PM
    #5316
    Azblue
    The Dirty T ( ^_^)_且
    I've used this. Not exactly pretty or perfect, but can be sanded smooth after curing and holds well. I used it after my pleather steering wheel cover started to break down after many years. It held for many months until I got around to putting another cover on.
    https://www.amazon.com/gp/product/B000PS6N4E?ie=UTF8
  7. May 14, 2024 at 11:31 PM
    #5317
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Yes it is vinyl. I'll have to try that Performix stuff and see what happens. I did watch a y/t video on how to do it, but although the guy did an outstanding job with the repair, he had obviously done this before it was way too involved for me to try it.
    Azblue likes this.
  8. May 15, 2024 at 7:03 PM
    #5318
    briarpatch
    Can you get a cover for it....for now...to keep it from getting worse? Any chance you could find one at a salvage yard and dye/paint it?
    cartage1 and Azblue like this.
  9. May 27, 2024 at 2:14 PM
    #5319
    What wheel cleaner does Tundras.com recommend for getting rid of brake dust?
  10. May 27, 2024 at 2:36 PM
    #5320
    This is my usual go-to. If it’s a sports wheel (lots of brake dust) I hit it with this
  11. May 28, 2024 at 4:19 PM
    #5321
    briarpatch
    Griots Garage has two very good wheel cleaners...one for normal dirt/brake dust......and a heavy duty one for worse cases. Once you get them clean....apply a wheel coating and you will only ever need soap and water. I've not (regularly) used a dedicated wheel cleaner in many years. Even if I have really dirty wheels, Bilt Hamber Surfex HD at 10:1 usually gets it done....same product at 5:1 if it doesn't.
    cartage1 likes this.
  12. May 31, 2024 at 6:58 PM
    #5322
    6 hours on correction alone on this one today
  13. May 31, 2024 at 8:24 PM
    #5323
    Azblue
    You missed a spot.
  14. May 31, 2024 at 8:26 PM
    #5324
    :p
    Azblue[QUOTED] likes this.
  15. Jun 27, 2024 at 9:59 AM
    #5325
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Wheel coating;
    Doing a brake job in the next week or so,ceramic pads.
    Want to coat TRD pro painted wheels while removed.
    Recommendations on cleaner safe on painted wheels but strong enough to get off brake dust and a coating to help keep black painted wheels cleaner overall.
    Budget is 100 and under, time isn’t on my side. I’ll have an hour to clean/ coat before I’m back on the road.
    eddiefromcali likes this.
  16. Jun 27, 2024 at 10:26 AM
    #5326
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Fotnot likes this.
  17. Jun 27, 2024 at 10:45 AM
    #5327
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I don’t remember if I posted this after asking my question about getting rid of the hazing on my paint but this stuff with the recommended yellow pad from griots worked perfect. I know this picture is in the garage but now in direct sunlight I am swirl free. It’s so rewarding to put in the time and effort and see good results. Not like the CG stuff I was using that resulted in terrible results. In their defence the products were likely too harsh for the seemingly soft paint on my tundra.
    War Machine, dondino and Fotnot like this.
  18. Jun 27, 2024 at 11:34 AM
    #5328
    briarpatch
    That is good stuff....and the Griots pads are on the less aggressive side. Do not make excuses for Chemical Guys paint correction products....they suck
    Azblue, Fotnot and eddiefromcali like this.
  19. Jun 27, 2024 at 11:37 AM
    #5329
    briarpatch
    Most wheel coatings have a longer cure time than that.....I saw in another post that CarPro Dlux was mentioned...which is a very good wheel coating...but the absolute minimum cure time would be one hour. Gyeon Rim, also very good, has a 24-hour cure time.
  20. Jun 27, 2024 at 11:38 AM
    #5330
    I would agree on this 100% for it to be effective, and in a temp/humid controlled environment.
  21. Jun 27, 2024 at 11:51 AM
    #5331
    eddiefromcali
    Eddie
    100% Stock
    oh shoot, i read it as only having 1hr to do the job...not 1hr to be back up and running. Dont think you can effectively do all 4 wheels in an hour...regardless of cure time
  22. Jul 2, 2024 at 4:46 AM
    #5332
    War Machine
    War Machine SSEM # 5 3MW
    That said, CG has some excellent how-to videos. Theirs is one of the videos I always recommend to people looking to learn how to do corrections. I just tell them to use their technique, but not their products.
  23. Jul 2, 2024 at 11:21 AM
    #5333
    briarpatch
    Good point....and they do have lots of videos
  24. Jul 12, 2024 at 10:00 AM
    #5334
    Quick question or two. Our 4r is the kid hauler and Starbucks gets spilled a lot…… usually sticky tea drinks; so I’m wondering what the best products or procedures I should use to clean the shifter select channel(PRND)
    And also the rear window roll down switch is super tight and sticky. I planned to pull the entire shifter console assembly and remove any switches and start hosing it down with water, and then use electrical contact cleaner on the sticky switches
    ToyoMafia and T-Rex266[OP] like this.
  25. Jul 12, 2024 at 10:05 AM
    #5335
    I would start with this and then move onto this if needed
  26. Jul 13, 2024 at 12:55 PM
    #5336
    Customer who I did the paint correction and ceramic for a few months ago came back for his free boost. He also added a full detail to it ($$). Adams Ceramic held up well based off of the beading
    coTony, Fotnot, RobertD and 1 other person like this.
  27. Jul 13, 2024 at 7:06 PM
    #5337
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I got some new tires coming soon and I'm doing raised white letters. Realizing I've never owned raised white letters, much less cleaned them....is there anything to use to clean it without ruining the white. I typically clean tires with carpro reset. Every once in a while (1-2 times a year), I'll use optimum power clean 1-1 ratio to clean the tires really well. I usually use Adam's Graphene tire shine.
    Keep doing what I'm doing and don't give it a 2nd thought or maybe change something?
    Anything appreciated
    RobertD and T-Rex266[OP] like this.
  28. Jul 13, 2024 at 7:38 PM
    #5338
    Maybe some economic all purpose cleaner or tire/rubber cleaner is what I would do
    RobertD and Fotnot[QUOTED] like this.
  29. Jul 13, 2024 at 9:03 PM
    #5339
    eddiefromcali
    Eddie
    100% Stock
    I love using Bleche Wite on white letter tires
    Fotnot likes this.
  30. Jul 22, 2024 at 8:10 AM
    #5340
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Any recs on getting these fingerprints off? Tried rubbing alcohol and plastic cleaner so far no luck.
