  1. Jul 1, 2024 at 1:32 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Hot damn, I'm way too excited for this.
    This is post power wash, dawn dish soap, detail brush.
    I may not be able to resist a flatbed build on top of a suspension build.
    How long is the truck going to be on jack stands?
    Winner gets a hand drawn spider.
    Weejub, oscardog86, bmf4069 and 7 others like this.
  2. Jul 1, 2024 at 1:36 PM
    I'd be tempted to replace that spare tire crank while the bed is off. Frame looks good!
    JakeJake likes this.
  3. Jul 1, 2024 at 1:42 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    bmf4069, BroHon and JakeJake[QUOTED] like this.
  4. Jul 1, 2024 at 2:12 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    you're gonna get the suspension knocked out today, take it off jackstands, and get a vid of dale bustin' wicked bedless donuts (but not on gravel unless you have some trailer fenders to tack on).
    edit: 2 days, because paint.
    bet i drove around a week like this waiting on a rainy day.
  5. Jul 1, 2024 at 3:42 PM
    JakeJake
    2000 Tundra AC 4X4
    That crossmember may be getting the chop chop.
    @Mr.bee I did whip a few shitties before I pulled back into the shop.
  6. Jul 1, 2024 at 4:18 PM
    You know you gotta LSPV delete while you're in there, right? I mean, it'll make everything look so clean.
  7. Jul 1, 2024 at 4:21 PM
    Openbaffle
    Openbaffle New Member
    Checked the power steering fluid this morning cold. Seems OK. Had a tasty IPA from Liquid State in Ithaca, NY.
    oscardog86, bmf4069, BroHon and 3 others like this.
  8. Jul 1, 2024 at 4:24 PM
    Did the plastic cup make it nastier?
    bmf4069 and Openbaffle[QUOTED] like this.
  9. Jul 1, 2024 at 4:26 PM
    Openbaffle
    It did not. I take it you don't like IPAs lolol.
  10. Jul 1, 2024 at 4:32 PM
    Hahaha I totally read that as nasty, not tasty……
    No I like IPAs I was just joshin you
    Openbaffle[QUOTED] likes this.
  11. Jul 1, 2024 at 4:33 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I also forgot...
    Some of the 2006 xB’s came with steering wheel controls, but all the 2006.5 xB’s did come with steering wheel controls AND an AUX port and an ipod port in the center console (under the E brake handle). I adapted a 2006.5 steering wheel controls and the audio ports into my 2005. It was NOT a fun task. It was around 8 years ago, and there was little to no documentation. It took me close to a week to sort all the individual wires out and not have any warning lights pop up in the speedometer display (and i even had the factory service manuals for both 2005 and 2006.5 to use as a reference). I had the whole darn dash removed from the xB, and wires were going every which way but loose. The wire harnesses were completely different between the the two years. I told myself i would never do that again. And that’s why i’ve been hesitant to even read through the tundra steering wheel controls sticky!
    I’ve had a handful of the xB’s. At one point i had a one 2005 and three 2006.5 Release Special 4.0 Maziora Torched Penny models...all at the same time! The Torched Penny paint was so expensive, that it cost me less money to just buy another RS 4.0 and swap individual body parts around. Back around 2015 a quart of that paint was an astounding $680! Plus it required a special primer and base coat. I would simply wait and find another Xb the same color on copart.
    The 1gen also didn’t come with a cruise control from the factory. It was a dealer add on. Rostra made the cruise control for all the scion dealers. You can also buy the exact same cruise control unit from Rostra now.
    Also look for the dealer add on center armrest support. It’s just a cheaply built plastic armrest that sits in a rear cup holder, but it makes all the difference in the world to have it, and most xBs don’t have one.
    The traction control kinda sucks on the 1st gen. It’s REALLY aggressive in a bad way. If one tire is spinning (such as gravel, ice, snow, ect) it will apply the brake on the opposite wheel. There is a TRAC OFF button, that will bypass that little problem, but is does NOT cancel out the yaw sensor!!! So if you’re drifting down a gravel road or going sideways in the snow or ice, the computer will automatically lock up all the tires and try to throw the vehicle into the ditch! From all my research, there’s no way to delete the yaw sensor (and keep the ABS). I ended up wiring in a bypass switch that turns both those systems off. I’d REALLY like to keep the ABS, but those two systems are intertwined.
    NUDRAT and FrenchToasty like this.
  12. Jul 1, 2024 at 4:34 PM
    Openbaffle
    Drove here too today. Haven't been on a road trip with the truck in a while. It's been nice.
    oscardog86, bmf4069, BroHon and 5 others like this.
  13. Jul 1, 2024 at 4:58 PM
    Is there any definitive way to distinguish a 2006.5 from a 2006, other than expecting pics of the steering wheel controls and potentially the aux/ipod ports?
  14. Jul 1, 2024 at 5:12 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Btw, you could get an xb thats alot of fun & gets 60mpg. But its air cooled.
  15. Jul 1, 2024 at 5:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    6 weeks
  16. Jul 1, 2024 at 5:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    But it looks fine
  17. Jul 1, 2024 at 5:17 PM
    Sounds strangely like a VW bug.
    Mr.bee[QUOTED] likes this.
  18. Jul 1, 2024 at 5:20 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
  19. Jul 1, 2024 at 5:22 PM
    It’s all about the humidity.
  20. Jul 1, 2024 at 5:23 PM
    VR6T
    Finally someone that understands that. Usually the humidity is fucking hellatious here
  21. Jul 1, 2024 at 5:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its not usually this humid here. All my purple sages have bloomed & we havent had rain all week.
  22. Jul 1, 2024 at 5:34 PM
    RealTruck
    RealTruck New Member Vendor
    Spectacular site!
  23. Jul 1, 2024 at 5:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. Jul 1, 2024 at 5:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Apparently it's getting worse for y'all.
    You think it's bad there now though, come to the coast.
  25. Jul 1, 2024 at 5:38 PM
    whodatschrome
    lots of dents
    No way to distinguish between the two, you just have to visually look for it. But in order to get the aux ports, you must have the steering wheel controls. There's also the factory scion/toyota plug in adapter that goes between your ipod and the port. Luckily mine was still in the glovebox when i bought the vehicle. I don't know if there's an aftermarket adapter available or not.
    shifty`[QUOTED] likes this.
  26. Jul 1, 2024 at 5:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    If mosquitos show up i'm packing up & heading west.
    Weejub, bmf4069, BroHon and 4 others like this.
  27. Jul 1, 2024 at 5:39 PM
    VR6T
    I grew up next to lake Erie and lived in Virginia beach for a long ass time. I know how bad it can get.
  28. Jul 1, 2024 at 5:40 PM
    We still get skeeters out here
    VR6T likes this.
  29. Jul 1, 2024 at 5:40 PM
    I have a Toyota 86 (BRZ) radio on-hand I'm likely to adapt into whatever I get the kids. It looks like Toyota didn't change much of anything connector-wise over the years, so I'm hoping pinout should be similar. If all it takes is 1 pin moved to work with a 1GT, I'm hoping Scion or Toyota of same year should be similar.
  30. Jul 1, 2024 at 5:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Our skeeters will carry my big boi off they're so thick here, I'd hate to leave my lil boi outside, he'd be gone :rofl:
    FrenchToasty and Jack McCarthy like this.
