Toyota Pre-Collision System Malfunction
Discussion in '3rd Gen Tundras (2022+)' started by Bailey1794, Jul 1, 2024.
  1. Jul 1, 2024 at 8:04 AM
    Bailey1794
    Bailey1794 [OP] New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Hello I am needing some help!
    Installed some lighting this weekend along with a power switch and now I have the PCS warning light on?
    Could this be caused by me leaving the door open while installing the items? How do I clear the error or will this just correct itself.
    I have already wiped down all sensors & cleaned the windshield. This is on 2023 Toyota Tundra Hybrid.
  2. Jul 1, 2024 at 8:12 AM
    Did you block the sensor at all?
  3. Jul 1, 2024 at 8:18 AM
    Bailey1794
    Houston
    Not that I can see. There's only two sensors for the PCS the one in the grill & cameras in the windshield.
    Added ditch lights and some wiring for the Power switch so not sure where it could have gone wrong besides leaving the doors open while install for over a period of time.
  4. Jul 1, 2024 at 8:23 AM
    You can try disconnecting the battery for a little while and see what happens. The Tundras have become very sensitive when it comes to electrical work/mods since 2014. It's best to disconnect the battery any time you are adding lighting, leds, or any type of wiring.
  5. Jul 1, 2024 at 8:25 AM
    Bailey1794
    Houston
    Yea it seems like its so sensitive in everyway in comparison to my old 3rd gen 4runner. Will the disconnection of the battery cause any custom settings to be removed? Just to remind others that this is on the Hybrid version of the tundra.
  6. Jul 1, 2024 at 8:47 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Where did you tap into for power?
    leaving doors open has nothing to do with the pre collision system.
  7. Jul 1, 2024 at 8:55 AM
    Bailey1794
    Houston
    upload_2024-7-1_10-54-33.png I used the 7.5 Tow fuse instead of the one in red box. Stole this picture from another post.
  8. Jul 1, 2024 at 9:18 AM
    Danman34
    Danman34 New Member
    Danny
    The towing system is looped in with the pre collision system. It’s quite possible it’s causing a power interruption on the circuit and triggering the fault. Remove the tap and see if the pre collision goes away.
  9. Jul 1, 2024 at 9:47 AM
    Bailey1794
    Houston
    Thanks for the suggestion. Ill go and swap the locations during lunch and see if it fixed the issue! Will report back shortly
  10. Jul 1, 2024 at 10:05 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I used the same tap location for my grille lights but maybe they aren't as demanding as a switch panel?
    I haven't had any issues with the PCS systems or sensors, and I have had the grille off twice so far.
  11. Jul 1, 2024 at 10:21 AM
    Bailey1794
    Houston
    I have the switch accessories wire tapped into it and the Back lighting for a Diode Dynamics Ditch Light which all 3 barely pulls any power really.
  12. Jul 1, 2024 at 11:28 AM
    Bailey1794
    Houston
    UPDATE: I had the fuse tap in the wrong location one under the TOW which threw the code. Quick swap and the error message was gone. Confirmed that both slots will power the ACC just needs to make sure a fuse is in the Tow slot or it will throw the PCS code.
    Thanks @Danman34
    Danman34[QUOTED] and Taikowaza like this.
  13. Jul 1, 2024 at 11:29 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Seems odd, did any of the plugs get dislodged? I ran my DD lightbar into my plug area next to the steering wheel and found a few extra active plugs tucked behind the blank plug covers, so I used one and made the switch install much easier.
    Next are some DD fogs if I can find them. :)
