08 wouldn't shift into gear...help
Discussion in '2nd Gen Tundras (2007-2013)' started by JBSTOY, Sep 19, 2017.
  1. Sep 19, 2017 at 5:59 PM
    JBSTOY
    JBSTOY [OP] Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    I was parked on a hill. I started my 08 5.7 4 wheel drive truck and shifted it into drive. Instead of getting a gear, I get a flashing 4lo idiot light and a beeping sound. The transmission and transfer case are in neutral but it is trying to acquire 4lo. The selector for the transfer case is still in 2wd at this point. I try to readjust the transmission selector from drive to neutral and back to drive. It finally goes back to normal. Has anyone ever had this happen? What causes this? Thanks. — looking for recommendations. I tried to see if there was anything in the Owner's Manual and I couldn't find anything.
  2. Sep 19, 2017 at 6:23 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Did you use the emergency brake?
  3. Sep 19, 2017 at 6:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Could ask @LOTSOFTOYS
    He's the resident yota whisperer
    GNTundra and T-Rex266 like this.
  4. Sep 19, 2017 at 6:27 PM
    JBSTOY
    Jack
    Unknown Origen
    Yes. The emergency brake was set. But then I released it.
  5. Sep 19, 2017 at 6:31 PM
    JBSTOY
    Jack
    Unknown Origen
    Will @LOTSOFTOYS automatically chime in?
  6. Sep 19, 2017 at 6:38 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    He'll be notified that he was tagged in this thread...so next time he's on he will presumably chime in.
    Others on here may have some answers as well.
  7. Sep 20, 2017 at 3:38 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Transmission fluid could be either low, or level changed due to gradient.
    Have you flushed or changed the fluid yet?
    If the tranny juice level is low, the vehicle will struggle in gear,/move/ engage.....My first clue
    Law323 likes this.
  8. Sep 20, 2017 at 4:57 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Like @Bob said, he'll be notified.
    Might take a couple of days. From what I see and understand, the guy keeps himself busy.
    Keep researching online until then, maybe you'll figure it out before then and see if @LOTSOFTOYS confirms your suspicions.
  9. Sep 20, 2017 at 7:20 AM
  10. Sep 20, 2017 at 11:08 AM
    JBSTOY
    Jack
    Unknown Origen
    I saw some stuff on Tundra crew I believe it was last night. It doesn't appear to be major. Thanks for the input though. Any help is welcome. Especially on a bizarre case like this one.
  11. Sep 24, 2017 at 9:19 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Seems like it was caught in limbo trying to shift into fqd or 4 lo? Not sure your intent.... they have a tough time shifting into 4lo when drive train is bound or moving. Flat ground in neutral works best. If u were going into 4 hi from 2hi, rolling going straight works best
    JBSTOY[OP] likes this.
  12. Sep 24, 2017 at 3:50 PM
    JBSTOY
    Jack
    Unknown Origen
    I finally narrowed it down. It is the actuator on the front axle. I climbed underneath and whacked it with a rubber mallet and turned the front driveshaft by hand. It is back in 2 hi. I've got the procedure to tear it down and rebuild or clean it so I think that is what I'm going to do. It acted up again and I did the same thing. I miss the mechanical stuff. It was easier and less of a headache. Thanks for your help though. I do appreciate it.
    k0diak8o8 likes this.
