Replacing rear brakes at 19,800 miles
Discussion in '3rd Gen Tundras (2022+)' started by Mezadgo, Jan 15, 2024.
  1. Jan 15, 2024 at 5:18 PM
    Mezadgo
    Mezadgo [OP] New Member
    Elias
    2022 Red SR5 Tundra
    Got my new 23 Tundra around 6 months ago. Zero miles.
    Im getting to 20,000 miles and come for oil change and alignment as part of maintenance. Once they are working on it they notice rear brakes are nearly gone. They tell me I need new brakes, to which I think they are being sleek trying to get me to buy new, but sure enough, brakes are gone. They look like they have been running for a very long time. Front brakes are ok. Any issues with brakes sticking or wearing out excessively? I have never had this issue with any of my previous vehicles, including my 22 lemon tundra!
  2. Jan 15, 2024 at 5:21 PM
    ElectricMan
    ElectricMan New Member
    I have not, but if I may ask, what kind of gas mileage were you getting during that 19,800 miles?
  3. Jan 15, 2024 at 6:05 PM
    Mezadgo
    Elias
    2022 Red SR5 Tundra
    I have been on 14.5 mpg since new the highest that i have seen it go up was 15 mpg.
    I do a lot of driving daily on both city and highway and its been stable around 14.5 mpgs
  4. Jan 15, 2024 at 6:10 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    There was another member here that had issue with a sticking caliper. Sounds like that maybe your issue. Was there any noticeably worn pad on one side?
    raylo and Breathing Borla like this.
  5. Jan 15, 2024 at 6:18 PM
    Mezadgo
    Elias
    2022 Red SR5 Tundra
    It looked clean, like a normal wear and tear!
    The only thing i have been noticing for a while, which I think might be the problem, would be my self stoping system. It is very twitchy. It has activated multiple times without need for it. Even while having fair distance between vehicles and without a fast speed at the moment of activation!
  6. Jan 15, 2024 at 7:19 PM
    ElectricMan
    with that kind of MPG, sounds like your brakes were sticking since day one. Sorry to hear but hopefully the dealer will fix it right for you.
    Hella Krusty and raylo like this.
  7. Jan 15, 2024 at 8:05 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I agree with that. @Eurodriver had the same problem, getting horrible mileage, then they caught his rear brakes dragging and worn out.
    ElectricMan[QUOTED] likes this.
  8. Jan 15, 2024 at 9:49 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    This is like the third or fourth person I've heard with this issue on a 3rd gen. Very strange and never really heard of any other new truck having this problem so soon. It sounds like maybe the auto braking, radar cruise, or the parking brake could be a cause. Warranty usually doesn't cover brakes but this soon and before the fronts wear out makes it an obvious defect.
    Can you (@Mezadgo) and anyone else (@Eurodriver) with this issue report back with your full ride specs or any mods like lift, wheels, bigger tires, etc? Maybe that could start to show a pattern of the cause.
  9. Jan 15, 2024 at 10:10 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Wouldn't you be able to hear some unusual noise if your rear brakes are sticking all time?
  10. Jan 16, 2024 at 3:33 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Not until it hits the wear sensors or goes full metal to metal. My GF had this problem with a 2009 Camry once upon a time and it was a mess. Before that I had never seen this problem in all my years... except on a motorcycle I kept outside under a cover with infrequent riding. The piston calipers on that bike developed a micro ring of corrosion where they entered the caliper so would never fully retract.
    You could check it for heat buildup after you drive a bit. The bad one will be way hotter than any of the other brakes and out or proportion to whatever braking you had done. That's how I discovered the issue on my motorcycle.
    Kap1[QUOTED] likes this.
  11. Jan 16, 2024 at 4:21 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Yikes! I just replaced the rear brakes on my '13 for the first time at 125K mi. Hopefully Toyota takes care of this for you as that's definitely a defect. I'd bet you're onto something with that auto-braking business.
  12. Jan 16, 2024 at 6:02 AM
    raylo
    Frederick, MD
    I NEVER replaced the rear brakes on my 2009 Tacoma in the 15 years and 135,000 miles I drove it. But drums. They still had maybe 40% left... because they just didn't do much.
  13. Jun 30, 2024 at 5:12 PM
    arosas85
    arosas85 New Member
    Andrew
    2022 Tundra Limited
    Was driving yesterday and felt a big jerk and had to push the pedal all the way down to even START to brake. I was like 2 min from my house and when I got there notice a big leak by the back tire. Turns out the caliper assembly SNAPPED OFF while I was driving. Bolts are still in place. I had already come to a lemon law agreement for fuel line leak and engine, turbos, and alternator replacement with Toyota and was supposed to turn the truck in on Tuesday in exchange for $40k. Safe to say I will be going for additional penalties now.
  14. Jun 30, 2024 at 5:22 PM
    Reissue
    Reissue New Member
    Do you use your cruise control a lot? I know with some other cars with adaptive cruise control it utilizes the rear brakes more when slowing you down with cruise activated, so I’m curious if this may be the same case with the Tundra.
    ColoradoTJ likes this.
  15. Jun 30, 2024 at 5:45 PM
    arosas85
    arosas85 New Member
    Andrew
    2022 Tundra Limited
    Negative. Only thing I started using recently but only a handful of times is the brake hold feature.
  16. Jun 30, 2024 at 5:54 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    [QUOTE="Jack Burton, post: 3454220,
    Pork chop express!!
  17. Jun 30, 2024 at 7:37 PM
    Racer57
    Racer57 New Member
    I would think you would smell the brakes if they were dragging.
  18. Jul 1, 2024 at 7:53 AM
    Wow. Talk about bad luck. Glad you got the truck stopped.
    Tundrastruck91 likes this.
  19. Jul 1, 2024 at 7:57 AM
    Interesting idea you have there. Makes me wonder as well. Subaru uses the rear brakes in turns for assistance (like cutting brake) and it wears the crap out of them. First vehicles I have ever owned where the rear brakes wore out first. Our first 2018 Subaru rear brakes were replaced at 35k and again at 70k along with the front brakes.
    22whatwedo likes this.
  20. Jul 1, 2024 at 8:20 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Do you know why cars with adaptive cruise utilizes the rear brakes more?
