Active spoiler arm removal
Discussion in '3rd Gen Tundras (2022+)' started by TRD_TUNDRA, Jun 22, 2024.
  1. Jun 22, 2024 at 8:14 AM
    TRD_TUNDRA
    TRD_TUNDRA [OP] New Member
    2024 Tundra TRD Off Road and 2024 Sequoia TRD Pro
    I’m trying to figure out how to remove the arm from the motor for the active spoiler. I’ve already removed the spoiler itself, but I want to remove the arm also since it hangs below the bumper when actuated. I’m keeping the motor mounted and plugged in to prevent a code.
    Has anyone removed the arm in addition to the spoiler? I tried removing the bolt that passes through, starting pulling out the guts but couldn’t get the actual arm out so I put it all back together.
  2. Jun 29, 2024 at 10:35 AM
    Anthony44
    Anthony44 New Member
    Just curious because I'm in the same boat. When you left the motor plugged in, did you get codes initially? I just had an aftermarket bumper installed and had to remove the air dam.
  3. Jun 29, 2024 at 12:04 PM
    TRD_TUNDRA
    No codes with the motor in place and plugged in.
  4. Jun 29, 2024 at 12:07 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
  5. Jun 29, 2024 at 5:28 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
  6. Jun 29, 2024 at 7:50 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Mine still has the spoiler. I’m probably gonna remove the spoiler at some point but probably just leave the motor like the instructions say.
  7. Jun 30, 2024 at 6:02 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Awesome, thank you. All I got to do is unplug it. No fuses to pull?
  8. Jun 30, 2024 at 6:07 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I’m not sure on that. According to the lift install instructions, the motor stays on and plugged in. You are just removing the spoiler so the motor is still there but doesn’t move anything. I have read a few post of people unplugging the motor and not getting any errors, but have also read a bunch of people getting errors.
    ARB1977[QUOTED] likes this.
  9. Jun 30, 2024 at 6:09 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Here are the pages for removing the spoiler
    ARB1977 likes this.
  10. Jun 30, 2024 at 8:35 AM
    Anthony44
    I think the technician left the motor but it is unplugged. I'm getting the "Parking Support Brake Malfunction" and Active Shudder error.
  11. Jul 6, 2024 at 5:04 PM
    timc74
    timc74 New Member
    When I unplugged the motor on my 2024 TRD Sport it gave a warning on the dash. So I removed spoiler and left motor in place and plugged in.
  12. Jul 6, 2024 at 7:07 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Which arm are you referring too? Thanks.
  13. Jul 7, 2024 at 7:36 PM
    TRD_TUNDRA
    I’ve watched a few full bumper install videos from C4 Fab. In their videos they remove the arm to cut it down and reinstall it. So it would seem the whole assembly should stay installed. I’m just going to cut mine down at some point.
  14. Jul 7, 2024 at 7:55 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Thanks for mentioning the video. Since the motor has to stay in place. I’ll just remove the dam from the motor and leave the arm.
