2013 toyota tundra no reverse
Discussion in 'General Tundra Discussion' started by Cesarion23, Jun 22, 2024.
  1. Jun 22, 2024 at 3:52 PM
    Cesarion23
    Cesarion23 [OP] New Member
    2013 black tundra 2wd
    My old tranny on my 2013 tundra went bad, I purchased another one exactly the same from another tundra that was wrecked with only 80k miles on it. I installed and drives perfectly fine all gears good but reverse when I put it on reverse it acts like if it was in neutral. Any ideas? Is a 2wd. Thank you!
  2. Jun 22, 2024 at 4:08 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Assuming this is an auto.
    Has it thrown any codes?
    Do your reverse lights come on?
    Did you re-use old torque converter?
    How did the fluid look in the replacement trans?
    Cesarion23[OP] likes this.
  3. Jun 22, 2024 at 4:16 PM
    Cesarion23
    Yes sir is in auto transmission, yes reverse lights go on, I use the torque converter that came with the tranny I bought and the oil came out clean do debris or anything bad.
  4. Jun 22, 2024 at 4:39 PM
    Windsor
    Homeless in Oregon
    Some.
    When in N, does it move forward?
    Did you follow the fill procedure?
  5. Jun 22, 2024 at 4:53 PM
    Cesarion23
    In N it acts normal as it should just when I put in reverse is like if it was in neutral.
  6. Jun 23, 2024 at 10:09 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Tundras (in the US) have only come with automatic transmissions.
    Pig Rig likes this.
  7. Jun 29, 2024 at 3:18 PM
    Cesarion23
    Any help would be greatly appreciated. Thanks.
