2007 Tundra Exhaust lLeak?
Discussion in 'Performance and Tuning' started by MXPCUS, Jun 27, 2024.
  1. Jun 27, 2024 at 5:08 PM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Is this the sound of a leak from the exhaust? There are no bad smells and it's always gotten bad mileage. I crawled under and can't see a leak, so it might be on top of the pipe. Is this something I need to address right away or can it wait?
    https://www.youtube.com/shorts/KHIfc6Xy6p8
  2. Jun 27, 2024 at 5:22 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Exhaust leak is easy to test. Soapy water near connection points (works better on a cooler exhaust) or you can use a smoke generator too. Sometimes you'll find soot near the area of the leak.
    If it is a leak, as loud as that is, I think you'll find the leak with a visual inspection.
  3. Jun 28, 2024 at 1:25 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It sounds like a leak. But there’s a ton of other things that could make that sound too.
    In the morning, when the truck is cool, get your shop vac on ‘blow’ and not ‘suck’ duct tape it to your tailpipe. Then use a squirt bottle with soapy water where you think the leak might be.
    if it’s a leak feel free to give a call for help with it. With over 20 years experience building tundra exhaust I’m happy to just give advice or design/engineer a brand new solution for you. 760-877-4234
    Dirtydeedsindustries.com
    2010SR5NIC likes this.
