Payload Capacity & Max Tongue Weight: Help me understand
Discussion in 'Towing & Hauling' started by fmscott2, Jan 19, 2022.
  1. Jan 19, 2022 at 5:50 PM
    fmscott2
    fmscott2 [OP] New Member
    First, let me be clear that this question is about my other vehicle, a non-Toyota family SUV. But the principles should still be the same and I know there are lots of great experts on here.
    I want to carry my dirt bike on my SUV via a trailer hitch-mounted motorcycle hauler. The kind that slides into the receiver tube and has a rail to carry the bike parallel to the back of the vehicle. But I don't know if the vehicle itself can carry the load...
    The vehicle's stated payload capacity is 1,173lb. To me this means the vehicle can carry a maximum of 1,173lb worth stuff which includes the people + any stuff you're carrying inside vehicle + anything that the trailer hitch is vertically supporting. The vehicle has a stated "maximum permissible static vertical load on the coupling device" of 500lb, so I assume that is referring to the max tongue weight the vehicle can carry?
    The trailer hitch itself has a max tongue weight rating of 500lb as well. My bike plus the hitch hauler is less than 500lb, so both the hitch itself and the vehicle's frame should be able to support that load.
    All together I've calculated a total payload I'd likely carry of 1,127lb, which is 46lb shy of the 1,173lb payload capacity of the vehicle. Is that too close to the razor edge limit to do so safely?
    Also, have I figured all this correctly (math-wise)?
  2. Jan 19, 2022 at 11:36 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    It will carry that with no problem . If ever in doubt have the vehicle weighed then you'll know exactly where you're at .
    WBW likes this.
  3. Jan 20, 2022 at 3:49 AM
    Retired...finally
    Well sort of. The distance of the bike to the end of your hitch receiver plays a part in this. I have seen a formula somewhere on the web to calculate this.
    2mchfun likes this.
  4. Jan 20, 2022 at 3:49 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    This. CAT scales are inexpensive and easier than doing damage, accelerated wear, or a dangerous road condition. This way you are not guessing.
    BTW, good on you for asking before running off half cocked.
    Retired...finally likes this.
  5. Jan 20, 2022 at 4:19 AM
    fmscott2
    I don’t understand the purpose of weighing the vehicle on a Cat scale. Would I weigh the car fully loaded or unloaded? What would the scale reading tell me (what number do I compare it to?)?
  6. Jan 20, 2022 at 4:25 AM
    WBW
    WBW Resident lurker
    Bruce
    Ah! Great question. You need both numbers to really know where you particular setup will affect you. Empty then fully loaded. This is the only way you can determine true tongue weight and axle weights. Ther are separate scales for front, rear, and trailer. My truck and trailer only fit on the 1st two scales.
    With my Tundra and trailer my truck actually gained capacity because it turned out to be lighter than declared by Toyota.
    Additionally, the CAT scales in my area,, Phoenix metro, you pay like $11 for the 1st weigh then $1 or $2 each weigh after on the same vehicle. That allows truckers to adjust their loads correctly.
  7. Jan 20, 2022 at 4:44 AM
    Retired...finally
    The further you bike is sticking out the more weight you'll remove from the front axle. This in effect puts more weight on the rear axle. The two CAT scale weighs will show you if your rear axle is overweight.
  8. Jan 20, 2022 at 4:44 AM
    fmscott2
    How can you gain more payload capacity than what the vehicle sticker states? I figured that payload capacity sticker is the absolute limit due to the structural strength of the vehicle chassis.
  9. Jan 20, 2022 at 4:45 AM
    fmscott2
    Would I compare the rear axle scale reading and make sure it is less than the vehicle’s stated rear GAWR?
  10. Jan 20, 2022 at 4:48 AM
    Retired...finally
    Yes sir.
  11. Jan 20, 2022 at 4:59 AM
    timsp8
    NY
    Payload = gvwr - actual weight.
    Doesn’t matter what the sticker says, you can’t go over the gvwr (usually 7200lb but there are some variations). You could remove stuff and payload will go up or add stuff and payload goes down. Even your hitch carrier will reduce payload. So you can weigh the truck empty and calculate how much you are putting in it or full and not guess.
    The hitch carrier and gawr is another calculation as mentioned above.
  12. Jan 20, 2022 at 5:06 AM
    WBW
    WBW Resident lurker
    Bruce
    The short answer is Toyota said my truck weighed about 40 pounds more than that it's empty weight on the scale read even after my accessory additions.
    @Retired...finally is correct about the cantilevered weight on the hitch. Basically it is the law of leverage. The longer the leverage arm the easier it is to move, hence a cheater bar on a wrench to break a stuck bolt or nut loose.
  13. Jan 20, 2022 at 5:17 AM
    2mchfun
    As said above the distance the weight is from the hitch plays a role in the forces applied. If you want to do this safely there is a way and I have done it. What I did was open the four doors and run ratchet straps around the door/roof support pillars leaving both ends of each on the roof with hardware covered with duct tape to prevent scratching. Then connect another strap from each to the rear of the carrier and tighten to distribute some of the load to the roof and door pillar structure vs having it all applied to the hitch. The weight is still on the hitch, but the forces applied to the hitch are significantly lowered using this method. Redneck Engineering 101!
  14. Jan 20, 2022 at 5:30 AM
    Retired...finally
    My Tundra uses a weight distribution hitch which moves the ball further away from the truck compared to a standard 2" hitch. No where in either my Toyota manuals or my WDH paperwork does it state anything about reducing tongue weight because of this. It is virtually impossible to get information like this from large companies but reading between the lines of the Toyota manual it states any trailer over xxxx weight should use WDH. (xxxx = I forgot the actual weight and am too lazy to look it up). Knowing this they've designed their hitch to accept a cantilever load to at least the extra distance of the WDH.
  15. Jan 20, 2022 at 5:49 AM
    WBW
    WBW Resident lurker
    Bruce
    My manual says over 5,000 lbs use a WDH.
  16. Jan 20, 2022 at 5:53 AM
    2mchfun
    /\/\ correct, the ball mount is basically a lever and the hitch receiver is the fulcrum. The more weight applied to the ball, the more force applied to the hitch. OP has a lever and fulcrum also, just the lever is likely a bit longer to allow for width of the motorcycle. The longer lever multiplies the force on the hitch, so the method I described above distributes a significant amount of that force over a large structurally sound area.
  17. Jan 20, 2022 at 8:08 AM
    Information overload:
    This is what you want to do and will cost you some money unless you know someone that has access to a scale. Fortunately for me, I have a CAT certified scale at work. High Five myself. Another way is pull into a DOT checkpoint, park, and then go in and ask nicely if you can use the scale to get some weight rating numbers. Do this empty, empty with trailer, and trailer loaded. If you have any questions a DOT officer should know (but not always). Do not try to disconnect at a DOT inspection station unless they say it is ok to do so.
    Before wasting a lot of time, energy, and money the vehicle owner should know some ballpark numbers. I will use my truck/trailer combo. Plug in your numbers as needed:
    -Gross Combined Vehicle Weight Rating 25300 lbs
    -Gross Vehicle Weight Rating 11500 lbs.
    -Vehicle Capacity Rating (payload) 3808 lbs. This will be inside the drivers door jam stickers.
    -Vehicle Hitch Rating and Load Distribution Hitch rating. 1200 lbs convention without LDH/1500 lbs with LDH. Owners manual/on hitch.
    -Gross Trailer Weight Rating 16000 lbs. On trailer faceplate. My truck is rated to pull 17200 lbs if everything in the load calculations work out.
    -Front/rear axle weight ratings. Rear 7050 lbs/front 5600 lbs. Owners Manual.
    For ease of things, I know my truck rear axle weight is 3200 lbs and front axle is 4400 lbs (I think my front axle is right. I would have to check my notes). So does this mean I can put 3850 lbs in my bed and be good? No. This is when checking the information in the drivers door jam is useful. Mine is 3808 lbs. There is a little fudge factor of course (42 lbs), but I like to use the lower number even though the capacity and actual weight says otherwise.
    Now, can my vehicle tow or load what I want to? If the answer is yes…continue.
    Take your vehicle to the scale. Now drive the front axle on the scale, record that number. This is your empty front axle weight. Now pull onto the scale. Record that number. This is your empty vehicle weight. Now pull the vehicle front axle off the scale. This is your rear axle empty weight.
    Now go get your trailer. For you camper guys, load the trailer up as if you were going camping. I know, PITA. Now go do it or no soup for you!
    As you are pulling on scales, record front axle weight. Then pull on the scale record that weight. When pulling off the scale stop short to get the rear axle weight loaded.
    Combined weight. Now I know what my truck and trailer weight together. This setup can legally tow 25300 lbs. I can put 12,870 lbs on my trailer/truck combo. 25300-12540=12870 lbs
    Next you want to get just the trailer weight. Pull forward to when the jacks are out down, the weight of the trailer are still on the scale. Having hydraulic jacks is nice. Just wanna toss that in there. :rofl:
    My trailer empty weight is 4600 lbs. This particular trailer has a 16000 lb rating. Can I just put 15000 lbs on this trailer with this truck? No. Get into that later.
    Without moving, hook the trailer back up. This is your empty hitch/pin weight.
    4600-3560=1040lbs empty pin. This number is important on figuring out tongue weight for conventional towing or pin weight for 5th wheel/gooseneck hitches. 4600x.225%=1035 lbs. Close enough. As most 5th wheel/GN trailers are set up, 22.5% of the trailers weight is transferred to the truck. This is why buying GN trailer for a 1/2 ton is not a good idea. Conventional trailers are 9-15% tongue weight normally, but not always. Now I also just added 1040 lbs to the axles. A small portion goes to the front and the majority is on the rear axle.
    For ease of this discussion, we can estimate 900 lbs went to the rear and 140 lbs went to the front. 4600+140=4740 lbs. 3200+900=4100 lbs. Good to go.
    Now you know what your empty weights are, time to go load up and repeat the process. This is when you can make adjustments to the load (positioning) within reason. This is also the time to see how a load distribution hitch is working. If the hitch hasn’t distributed enough weight, pull off scale, make adjustments, weigh again.
    So what do all these numbers mean? Let’s cover that.
    Gross Combined Vehicle Weight Rating GCVWR. As stated earlier, my truck is rated for 25300 lbs truck and trailer combination. Can I go over this with my setup? Absolutely. 11500+16000=27500 lbs. if I was in commerce, I would get fined even if I was under 25300 lbs. The officer goes off what the truck/trailer is rated for. If I were ever deemed in commerce/commercial, an overweight ticket could be issued. I have been ticketed before. I think it was for every 1000 lbs= 20.00. The commercial truck I was driving before putting anything on it was overweight by 2500 lbs from the get go. If I loaded up a couple transformers and three electric line poles the fines can add up quickly.
    Gross Vehicle Weight Rating. Mine is 11500 lbs. All this means is total loaded vehicle weight (trailer pin weight, all passengers, any vehicle mods, cargo, etc)
    Tongue weight/Hitch weight rating. Some manufactures do not put a "rating" on the vehicle. You need to find out what class hitch you have. Typically there is a rating. Mine is 1500 lbs. Some are different rated if using a LDH.
    Payload. Mine is 3808 lbs. This means I cannot exceed this due to tongue/pin weight and passengers. Let's say my family weighs in at 608 lbs with dog. That means I can load a pallet of concrete in the bed if it doesn't exceed 3200 lbs. Following this number also helps keep the axle/tire ratings under maximum. Remember earlier, my truck has a rear axle capacity of 7050 lbs. If I put 3808 lbs in the bed (including passengers). I already know my rear axle weight empty is 3200 lbs. So 3200+3808=7008 lbs. Now let's talk about tires for a second. Not all tires are created equal. A Load Range E tire has a pretty wide range depending on size and different air pressure ratings. We need to look at Load Index. For my truck, I require a Load Index of 124.
    Screen Shot 2022-01-20 at 8.08.32 AM.jpg Screen Shot 2022-01-20 at 8.09.10 AM.jpg
    So my tire ratings are 3527 lbs each. 3527x4=14108 lbs. Tires exceed GVWR of 11500 lbs. I should be good to go and have lots of extra capacity right? Not so fast. 3527x2=7054. Remember that rear axle rating of 7050 lbs? If I am even a few pounds overloaded I can exceed the tires maximum weight rating. This is why when members say "the Tundra is more of a 3/4 ton. It can handle a lot more than advertised" makes me shake my head. You sure about that? Can the AAM 11.5" rear axle take more weight than that? Yes it can in different applications. My tires are the limiting factor in this equation.
    https://www.discounttire.com/learn/load-range-load-index
    Gross trailer weight rating. This is a two part. You have a GCWR as well. So mine is 25300 lbs. I can safely tow 5th/GN 17200 lbs. My trailer is rated at 16000 lbs. Trailer weight is 4600 lbs. My pin weight is 22.5% of trailer weight. So if I maxed out the trailer of 16000 lbs, my pin weight will be ~3600 lbs. So I can put myself in the cab and better take a crap before I leave. Be cutting it really close on that one. Well how can I have a 17200 lb rating for a trailer. Well not all trailers are loaded at 22.5% pin weight and sometimes people pull doubles. Not suggesting that is a good idea. Now remember my truck is also rated at 11500 lbs. So 11500+16000=27500. So if my truck/trailer is ever at maximum capacity, I could be overloaded by a lot.
    My Tundra had a 16000 lb Combined rating and a 9000 lb tow rating. 7200 GVWR + 9000 lb trailer=16200 lbs (toyota reduced to 16000 lbs).
    Hope this helps a bit. I have to take the kiddo's to school, so I will clean this up a little later.
  18. Jan 20, 2022 at 8:16 AM
    Retired...finally
    Should be in a sticky somewhere. Excellent post.
    ColoradoTJ[QUOTED] and Dsptundra like this.
  19. Jan 20, 2022 at 8:25 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Awesome summary of how to do this and how the weights actually work. This should be pinned.
  20. Jan 20, 2022 at 9:20 AM
    Thanks fellas. I guess being at home on crutches has site benefits..:rofl:
    I will try and copy/move this to the stickied towing thread. Hope this helps people out with the what and why's.
    Dsptundra and 2mchfun like this.
  21. Jan 20, 2022 at 9:24 AM
    Dsptundra likes this.
  22. Jun 28, 2024 at 12:07 PM
    super_mech
    super_mech New Member
    Tundra '23 - 1794 OR
