  1. Jun 28, 2024 at 6:48 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Doing a once over, in preparation to start the ball joint upgrade, and I noticed something...interesting. Apparently, I have 3 SPC adjustment cams and 1 OEM o_O. I'm not even sure when or where this happened.
    Doubt I'll get to this as planned, today. Spent most of yesterday at the vet ER, figuring out that the ol boy has LarPar, or a paralyzed larynx. Long ass day and it zapped most of my motivation, plus a sore back carrying that 80+ lbs mfer around, lol.
    shifty` likes this.
  2. Jun 28, 2024 at 7:07 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Is that where their bark sounds like a cough? Best of luck with the good boy.
    oscardog86, metalpete and BroHon like this.
  3. Jun 28, 2024 at 9:03 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Hope all goes well with your friend man.
    oscardog86 and metalpete[QUOTED] like this.
  4. Jun 28, 2024 at 9:49 AM
    metalpete
    ID
    Appreciate it, fam.
    Yeah, like kennel cough, a goose like honk. He's a damn 14-16 year old lab/pit/mastiff, so I figured the louder breathing was mostly because of that. Which is partially true, as it's common in bigger framed dogs past the age of 10. It's the start of a bigger, neurological issue, unfortunately. Otherwise they said he's the picture of health.
    Just trying to make him comfortable for as long as possible.
  5. Jun 28, 2024 at 10:39 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Gave her a wash and wax, still shines up for a 24 year old pickup.
  6. Jun 28, 2024 at 11:27 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    That’s a ruff go Pete. Speedy recovery to your pal. Let’s hope his bark gets back to being worse than his bite.
    metalpete[QUOTED] and ToyotaDude like this.
  7. Jun 28, 2024 at 11:33 AM
    oscardog86
    oscardog86 New Member
    Southern California
    You sound like a good dog owner man. Its tough seeing them get older, but that age for a bigger pup is still really good. Mine is 16 now, hes a smaller terrier mix though and practically deaf and losing his eyesight too. Otherwise still in pretty good health.
    All you can do is keep them happy and comfortable as long as you can.
  8. Jun 28, 2024 at 11:40 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I humbly disagree
    NUDRAT and oscardog86 like this.
  9. Jun 28, 2024 at 11:44 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  10. Jun 28, 2024 at 11:51 AM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Nicely done, what paint did you use?
    JakeJake[QUOTED] likes this.
  11. Jun 28, 2024 at 11:58 AM
    VR6T
    The bling is real and makes me jellyfishin
  12. Jun 28, 2024 at 12:07 PM
    JakeJake
    2000 Tundra AC 4X4
    Rustoleum Alkyd Enamel "low gloss black" catalyzed and reduced with Acetone. 16:1:1 sprayed out of a HVLP with a 1.8 tip
  13. Jun 28, 2024 at 12:10 PM
    oscardog86
    Southern California
    Sounds pretty specific! I just use whatever comes out of the can. Seems like I can stand to learn a thing or two about painting
  14. Jun 28, 2024 at 12:25 PM
    JakeJake
    2000 Tundra AC 4X4
    Learning to use an HVLP spray gun is a real game changer. Highly recommend.
    NUDRAT, Hutcheson, ToyotaDude and 2 others like this.
  15. Jun 28, 2024 at 12:28 PM
    VR6T
    No h2o in the lines is always a good thing as well. How much did it cost you to get into that set up? If you don't mind sharing
    oscardog86 likes this.
  16. Jun 28, 2024 at 12:41 PM
    JakeJake
    2000 Tundra AC 4X4
    The most expensive part is the compressor, but you may already have something that would work. More volume would be better, but as small as a 5 ish gallons would work okay. You will have to wait for a smaller compressor to catch up.
    For a gun just grab one of these
    ToyotaDude likes this.
  17. Jun 28, 2024 at 12:42 PM
    VR6T
    I have a Huskey bottom feed, but it works hella good
  18. Jun 28, 2024 at 12:46 PM
    Those rusty exhaust manifolds need to go with ceramic coated shorties taking their place (or long tubes). Great job though.
  19. Jun 28, 2024 at 1:02 PM
    JakeJake
    2000 Tundra AC 4X4
    I'll build some long tubes someday.
    I do have the oem splash shields to put back in, so that will help hide the ugliness for now.
  20. Jun 28, 2024 at 1:08 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Great vids here by this guy takes the mystery out of autobody painting. He covers prep including fillers, sanding, guide coating and blocking panels, airflow during spraying, wet floor techniques, HVLP painting, as well as simple rattle can painting too with pro looking results.
    https://m.youtube.com/@PaintSociety
    IIRC for about $50 HF had a decent HVLP gun that coupled with a , , and disposable moisture filter connected at the sprayer ... along with a compressor that can push enough CFM (and a respirator) ... can lay down some good finishes after practice with two stage auto paint (adding hardener / catalyst and reducer). Think @JakeJake linked to looks similar to mine that's green (year's old). Paint Society actually demos the HF gun here.
    If don't have large enough compressor tank that causes pausing to catch up volume, paint can dry while laying it down and not come out "wet" looking. Smaller compressors can do ok for smaller jobs.
    Good to put an oil filter at the compressor before the hose too and can make a good water separator out of a coil of copper sitting in a bucket of water if want to go the full nine yards. Can build this installed right at the compressor before the hose. Bucket filled with cold water condenses the hot moisture filled air in the coils and separates it. Consider a hose for painting that is not used for air tools (especially where previously had an oiler installed before it).
  21. Jun 28, 2024 at 1:10 PM
    You have a machine to do the bends for long tubes? Impressive.
    Tundra2 likes this.
  22. Jun 28, 2024 at 1:22 PM
    Is that a nail, or just a rock stuck in the tread?
    NUDRAT and KNABORES like this.
  23. Jun 28, 2024 at 1:26 PM
    Gotta change that username dog
  24. Jun 28, 2024 at 1:30 PM
    JakeJake
    2000 Tundra AC 4X4
    #12 roofing screw. Must have picked it up last week.
    whodatschrome likes this.
  25. Jun 28, 2024 at 1:52 PM
    JakeJake
    2000 Tundra AC 4X4
    More than one way to skin a cat
  26. Jun 28, 2024 at 2:11 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Drove 200 miles home today from a long work trip. Unfortunately I think my 5100’s second clip with stock springs are too stiff. They are something I can deal with but pot holes and bridge or concrete transitions are driving me nuts. Damn I didn’t want to change those springs out
  27. Jun 28, 2024 at 2:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Another reason to SAS.
  28. Jun 28, 2024 at 4:39 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Dorman, works fine.
  29. Jun 28, 2024 at 5:20 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    With those headers I guess you don't need an x pipe
  30. Jun 28, 2024 at 5:22 PM
    I forgot they had a vinyl coat on them. Mine wore off 100k miles ago.
    The Black Mamba and Mr.bee like this.
