I don’t think I need 4x4
Discussion in 'General Automotive' started by helpmeout, Jun 26, 2024.
  1. Jun 26, 2024 at 2:16 PM
    helpmeout
    helpmeout [OP] New Member
    2012 tundra CM rock warrior
    I have a 4x4 tundra but I rarely use the 4x4 and when I do need it, it does miracles but again I rarely use it.
  2. Jun 26, 2024 at 2:19 PM
    centex
    centex New Member
    4wd is like condoms. Better to have it and not need it than need it and not have it.
  3. Jun 26, 2024 at 2:25 PM
    Mr Badwrench
    Mr Badwrench New Member
    Helps with resale, if you ever have to sell. You couldn't give a 4x2 away in my area.
    CringyDad, dondino, 87warrior and 3 others like this.
  4. Jun 26, 2024 at 2:25 PM
    No one needs a 4x4. Until they need a 4x4.
  5. Jun 26, 2024 at 4:28 PM
    2mchfun
    At the very least, cycle it monthly so it doesn't get stuck in 2wd. So much easier than repairs!
  6. Jun 26, 2024 at 4:31 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Get an AWD 4Runner or GX. AWD is better for most circumstances. Cheers.
  7. Jun 26, 2024 at 4:53 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Like replacing 1 tire?
    PolishedTRD and ZappBrannigan like this.
  8. Jun 26, 2024 at 4:55 PM
  9. Jun 26, 2024 at 5:18 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Eloquent at its brevity.
    blenton, Tundra2 and Patch999 like this.
  10. Jun 26, 2024 at 5:22 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    Also if you ever choose to launch a boat, you'll be very happy to have 4WD
  11. Jun 26, 2024 at 5:32 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Or drive on sand.
  12. Jun 26, 2024 at 5:33 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Thought the exact thing with my second Tundra. Then traded it in for a 4x4. Better resell. More capable. Rarely need it but would rather have it.
    des2mtn and ZappBrannigan like this.
  13. Jun 26, 2024 at 5:41 PM
    helpmeout
    I have used 4x4 and it does great. I’m just wondering what up keep I can do to make sure it doesn’t stop working other then cycling through it sometimes.
    Patch999 likes this.
  14. Jun 26, 2024 at 5:43 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    I think diff and transfer case fluid change around 60k but others may chime in. I’m sure most dont bother and keep rolling.
  15. Jun 26, 2024 at 5:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Jun 26, 2024 at 7:06 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    This, I did mine at 60k.
    Patch999[QUOTED] likes this.
  17. Jun 26, 2024 at 7:09 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    PolishedTRD and Cpl_Punishment like this.
  18. Jun 26, 2024 at 7:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I saw a puppy last night
  19. Jan 13, 2025 at 9:35 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Timely thread....
    Friend from Texas moved to WV. His Tundra is the 2WD. (drumroll) He got stuck last week!
    Now in his case, he probably would have gotten stuck in 4WD: backed into snowy ditch he didn't see. Depending on factors....4WD may not have mattered. No extra tow cost as a Good Samaritan pulled him out.
    I have found tire chains in a front wheel drive car to be much more effective than 4WD if the 4WD vehicle has the wrong tires. Lots of factors to consider.
    I advised him to put weight into the back and carry a trolley jack and tire chains or get mud+snow or studded tires. Weight, chains, and jack would be the cheaper option.
  20. Jan 13, 2025 at 9:42 PM
    Tundra family
    Tundra family New Member
    I have a 2wd tundra and have been stuck on wet grass.
    The Black Mamba and Tundra2 like this.
  21. Jan 14, 2025 at 12:47 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    So, yes you do?
    -Cycle once / month as others said.
    -Change differential and transfer case fluid. My OCI is 30k.
    GODZILLA likes this.
  22. Jan 14, 2025 at 2:19 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    The new Tacoma Limited has the Runner/GX full time 4WD system. If it’d been released a couple years earlier I’d be driving one. This new Tundra tows so effortlessly though… and you can’t get the Limited Tacoma without hybrid
  23. Jan 14, 2025 at 2:56 AM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    When I moved from FL to WV I had a 2wd F150, figured I would be fine. Not so much. That first year it snowed like a MF'er. I got a civic, bought a spare set of front wheels, and got studdies mounted on them, carried them in the trunk. I could swap wheels in a few minutes anywhere, and the little beast was amazing on snow or ice. Now my Tundra has been great the last few weeks in this shit, but it lacks that "fuck yea, lets take that turn harder and power out of it, fuck that black ice" attitude a studded civic has. Maybe cuz its alot more expensive to fix.
    Tundra family likes this.
  24. Jan 14, 2025 at 3:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been there friend, I will NEVER not have 4WD again
    Cpl_Punishment and KNABORES like this.
  25. Jan 14, 2025 at 4:31 AM
    I would own a 2wd truck. It would be for summer only and sport truck purposes only.
    Used 4wd at least 4 times last week and once yesterday.
    Cpl_Punishment likes this.
  26. Jan 14, 2025 at 4:34 AM
    I wouldn't be able to get my camper or boat out of the yard 6 months out of the year without it. But you can get by without it. My FIL did for 18 years with his 2wd chebby. Always said you don’t really need it. Then he bought a new F150 this year, in 4wd…..
    Cpl_Punishment and ColoradoTJ like this.
  27. Jan 14, 2025 at 4:55 AM
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    You CAN sell a 4x4 to someone who wants a 2wd. You CANNOT sell a 2wd to someone that wants a 4x4.
  28. Jan 14, 2025 at 4:57 AM
    Rain and muddy conditions?
  29. Jan 14, 2025 at 5:02 AM
    Tundra family
    On my 3rd 2wd drive truck and other than that one incident on an abandoned golf course I've never needed 4X4. I just can't justify the added cost/maintenance for my needs. Plus I like the bragging rights of taking it places people don't expect it to go. It's amazing what a good locker can do for a guy
  30. Jan 14, 2025 at 5:21 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Launching the boat is easy. It's the pulling it out part that has caused me anxiety.
    Cpl_Punishment and ZappBrannigan like this.
