Wheel stud question
Discussion in 'Wheels & Tires' started by 2010SR5NIC, Jun 17, 2024.
  1. Jun 17, 2024 at 8:02 PM
    2010SR5NIC
    2010SR5NIC [OP] New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    Are these wheel studs too short?
  2. Jun 17, 2024 at 8:15 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
  3. Jun 17, 2024 at 8:48 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
  4. Jun 17, 2024 at 9:04 PM
  5. Jun 18, 2024 at 5:38 AM
    2010SR5NIC
    The only ones I can find are 2” long. I’ll have to take the wheels off to see but I’m sure I have 2” ones so I’ll need extended ones?
  6. Jun 18, 2024 at 5:39 AM
    2010SR5NIC
    I thought so too but the only ones I can find are 2” long and that doesn’t seem that long.
  7. Jun 18, 2024 at 6:06 AM
    Are those at least ET lugs?
  8. Jun 18, 2024 at 6:11 AM
    2010SR5NIC
    you know, I have no clue. How do I check that?
  9. Jun 18, 2024 at 6:14 AM
    Take one off and look. ET lugs have an extended bore to reach into the wheel lug hole and grab onto more threads. Pic for reference, conical seat on the left, ET on the right. That extra skinny portion sticking up is the extended thread engagement area.
    des2mtn likes this.
  10. Jun 18, 2024 at 6:22 AM
    2010SR5NIC
    okay I’ll take one off later and look. At work now. Thanks! I’ll report my findings.
  11. Jun 19, 2024 at 3:28 PM
    2010SR5NIC
  12. Jun 19, 2024 at 4:10 PM
    2010SR5NIC
    What length are standard studs? I’m looking for some longer ones so I get more threads but am having no luck.
  13. Jun 19, 2024 at 4:11 PM
    2010SR5NIC
    This is what I found. Is 45mm stock? That’s not even 2”.
  14. Jun 19, 2024 at 5:46 PM
    Those are at least extended lugs
    1lowlife likes this.
  15. Jun 19, 2024 at 6:08 PM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I switched over to these with new lugs as well. 2.5 inches long - Dorman 9/16-18 studs with .65 knurl- P/N 610-471.
    Gorilla 2 inch black chrome wheel lugs - 26195BC - kit is a 32 piece set.
    These are OEM Ram studs but they worked great on my 2014 Tundra. Don't know if they would work on a 2007-2013. You will have to get a different size lug wrench to put in the truck.
  16. Jun 19, 2024 at 7:05 PM
    2010SR5NIC
    what are?
  17. Jun 19, 2024 at 7:07 PM
    2010SR5NIC
    So what lug nuts do I need with these?
  18. Jun 19, 2024 at 7:19 PM
    Extended lug nuts, not extended studs. They have the deep shank on them to engage more threads. I would still get longer studs as you have very little engagement with the current setup.
  19. Jun 19, 2024 at 7:21 PM
    2010SR5NIC
    yeah I’m going to get some ram 1500 extended ones that will fit and are 2.5” long. I just have to get different lug nuts but they don’t have et style lug nuts in 9/16”x18
  20. Jun 19, 2024 at 7:46 PM
    2010SR5NIC
    will these work?
  21. Jun 19, 2024 at 10:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Those won’t work arp doesn’t make a set that fits the tundra. Blackhawk Japan has some or some have used the eBay units and worked well. Search function has a ton of info this. We run the Blackhawk japans and work well in our extreme use case.
    1lowlife and CaptRussia253 like this.
  22. Jun 20, 2024 at 5:41 AM
    2010SR5NIC
    looks like I’ll be buying those ones from Japan then. Thanks for those measurements. Really helps me see how much longer they are. That’s what I need. Thanks again!
  23. Jun 20, 2024 at 5:41 AM
    2010SR5NIC
    those are the SBLC ones from Blackhawk right?
  24. Jun 20, 2024 at 6:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Correct and you’ll only need to do the fronts.
  25. Jun 20, 2024 at 6:48 AM
    2010SR5NIC
    why not the rear?
  26. Jun 20, 2024 at 6:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Not needed they for whatever reason engage more thread so we only swap the fronts
  27. Jun 20, 2024 at 6:54 AM
    2010SR5NIC
    But the space at the end of my lug nuts look to be the same all the way around so that would mean the same amount of thread is in the lug nut. I’ll have to check that out. Thanks!
  28. Jun 25, 2024 at 7:38 PM
    2010SR5NIC
    I’ll be doing the rear too because there is the same engagement on the rear as the front.
    reywcms[QUOTED] likes this.
