First time owner oil filter issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by MrSpkr, Jun 25, 2024.
  1. Jun 25, 2024 at 10:03 AM
    MrSpkr
    MrSpkr [OP] New Member
    2021 White Tundra 1794 Edition
    Hi. Just got a 2021 Tundra 1794 ed. I went under to change the oil and filter. Two questions.
    1) do I need to replace the drain plug gasket every time? Mine looks fine and I am not sure where to get a replacement.
    2) A gripe and a question. The gripe is that the drain plug on the filter cap _will not_ come off. I ended up having to remove the whole cap. My question- I the process of removing the cap,I dropped it and the metal assembly the filter fits onto came apart. I now have a spring, a small cap that went at the bottom of the center assembly, and a long metal tube.
    I cannot get the thing put back together. Should I just pony up for a new one, or is there a way to put it back together? I think the pair of double tabs at the bottom of the cap are supposed to hold it in place, but I cannot seem to make the core assembly fit.
  2. Jun 25, 2024 at 10:11 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    JMGmanAZ likes this.
  3. Jun 25, 2024 at 10:56 AM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    If it came apart that easily I agree I would get a new one. If you need it today you may have to get one from the dealer.
    as far as the drain plug and gasket. When you buy the oil filter it should come with 2 gaskets. One for the housing and the small one for the drain plug.
    I have to use a torque wrench and torque the drain plug to 9 ft pounds. If I over tighten it, the whole housing will turn.
  4. Jun 25, 2024 at 12:55 PM
    It should look like this.
  5. Jun 25, 2024 at 1:07 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    none of the tabs look bent/broken/twisted. if you dropped it, it seems like it just got shook loose. the center core comes out fairly easily (it has in all 3 of the 5.7's i've owned). it simply goes in with a push and twist....maybe slight angle slide. if it makes you feel more comfortable, buy a new one.
    as stated, the new filters come with the 2 o-rings.
    if the center drain doesn't come off easily, try to carefully hold the plastic housing, and put a 3/8" drive wrench on it to take it off. the first time i went to change the oil on my sequoia after the couple free ones, it was a b!tch to get off, and i had to put my housing in a vice with towels around it to hold it while i put a 3/8" wrench on it to get it off. at that point, i was upgrading to an aluminum oil filter housing anyway.
    i believe the torque on the small drain isn't but about 9#'s of torque. it doesn't take much. same with the oil filter housing
    BeauDacious likes this.
  6. Jun 25, 2024 at 1:21 PM
    Oil pan drain plug 30 ft lbs
    Oil filter housing 18 ft lbs
    Filter drain plug 9 ft lbs
    Doxiedad likes this.
  7. Jun 25, 2024 at 1:35 PM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    There is even a thread on swapping it to the aluminum one and having to remove and reuse the center tube.
    Fotnot[QUOTED] likes this.
  8. Jun 25, 2024 at 1:39 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    exactly
    BeauDacious[QUOTED] likes this.
  9. Jun 25, 2024 at 1:44 PM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    I would buy a new aluminum one. That's what I did. The first time I changed my filter it was super tight from the dealer and I thought it was only a matter of time before I cracked it
    Aluminum one is ~$25
  10. Jun 27, 2024 at 5:39 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I bought a new aluminum one in anticipation of the first oil change on my new (used) to me truck. Had to use a 1/2" drive long handle ratchet with a very nice filter socket I bought online to get the old plastic one off. Inspected it and it looked fine. Re-used it torqued properly and the next time it came off normally. Never used the aluminum one, saved it just in case. Yes, the metal tube inside was kinda floppy.
