  1. Jun 25, 2024 at 9:22 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    So this fucker is done. Now does any one know what size wrench the passenger side upstream uses?
    oscardog86 likes this.
  2. Jun 25, 2024 at 9:23 AM
    VR6T
    I love how the top but came right off no issues no blaster spray, just came off as it should.
    As soooooon as I went and put torque on the lower steam nut it just rounded the fuck off
    Weejub likes this.
  3. Jun 25, 2024 at 9:31 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Toasty, thanks for the offer! Ultimately I would like to market this part (among other things) to the 1GT community, so keep your secrets. :rofl:
  4. Jun 25, 2024 at 9:32 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If you make some of the plates, I'd be interested. Some of these kits on the market use grade 8 bolts.
    https://solomotorsports.com/shop/pa...a-parts/toyota-alignment-cam-tab-upgrade-kit/
  5. Jun 25, 2024 at 9:34 AM
    JakeJake
    2000 Tundra AC 4X4
    I saw similar reports of someones alignment tech mangling them too.
    455h0le_dachshund and bmf4069 like this.
  6. Jun 25, 2024 at 9:34 AM
    des2mtn
    SW
    Tonto cover
    Prior discussion..
  7. Jun 25, 2024 at 9:42 AM
    I mean if it’s for our peeps…… in a week or so, I’ll send you some specs. Getting prepared for a dale type adventure otherwise I’d send them now
  8. Jun 25, 2024 at 10:08 AM
    des2mtn
    SW
    Tonto cover
  9. Jun 25, 2024 at 10:30 AM
    Diagrams show it as p/n 90080-95022. It's cheaper thru Toyota, $10 if I pickup from my local stealership.
    Toyota: https://autoparts.toyota.com/products/product/plug-hole-9008095022
    fleaBay: https://www.ebay.com/itm/296439294196
    FrenchToasty[QUOTED] and des2mtn like this.
  10. Jun 25, 2024 at 10:34 AM
    Damn, post updated. It was only $10 at my local stealership.
  11. Jun 25, 2024 at 10:36 AM
    I might just look for another tundra with one of those hitch caps, and get a 2fer……..
    shifty`[QUOTED] and Mr.bee like this.
  12. Jun 25, 2024 at 10:44 AM
    Five finger discount. I know one member you can stalk down to get it :rofl:
  13. Jun 25, 2024 at 11:12 AM
    Well…… we’re waiting!
  14. Jun 25, 2024 at 4:21 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
  15. Jun 25, 2024 at 4:26 PM
    1/2” drive flex head extension socket wrench with O2 socket.
    VR6T[QUOTED] likes this.
  16. Jun 25, 2024 at 4:28 PM
    VR6T
    Thanks but I got it covered thanks to my neighbor. Luis is a life saver
    BroHon and Jack McCarthy[QUOTED] like this.
  17. Jun 25, 2024 at 4:45 PM
    Just don’t snap the bung hole off or it’ll get ugly. You need to massage that bung hole with penetrant.
    I can’t recall the last time I had to say that.
    Tundra2, bmf4069 and BroHon like this.
  18. Jun 25, 2024 at 5:25 PM
    VR6T
    Already started the penetrant soak today. Gonna hit it up for the next 2 days, before and after work, then I'm gonna give it the business
  19. Jun 25, 2024 at 6:07 PM
    Azblue
    The Dirty T ( ^_^)_且
  20. Jun 25, 2024 at 6:10 PM
    VR6T
    One must pamper the bunghole before giving it the business.
    Tundra2, bmf4069, BroHon and 2 others like this.
  21. Jun 25, 2024 at 6:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    How much slop is in the trucks ecu? What do you think it would say to gs400 manifolds, and h-piped true duals? They're probably great at a higher rpm, but i doubt they're doing much damage on the lower end. Hell, rolling around in 3rd might put me in the sweet spot.
    for science, havent found any new ones, but i'll keep looking.
  22. Jun 25, 2024 at 6:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    This is texas. Our bungholes are fine.
  23. Jun 25, 2024 at 6:15 PM
    VR6T
    You could always pick up a set of new stainless steel shorties and do the same thing.
    455h0le_dachshund likes this.
  24. Jun 25, 2024 at 6:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    But split tri-y's.
    455h0le_dachshund and VR6T like this.
  25. Jun 25, 2024 at 6:15 PM
    VR6T
    Not true, they must be drained to get the whiskey out
    Jack McCarthy and Azblue like this.
  26. Jun 25, 2024 at 6:16 PM
    VR6T
    If that's you're end goal then go for it. I was just floating another option
  27. Jun 25, 2024 at 6:17 PM
    Azblue
  28. Jun 25, 2024 at 6:24 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Do i need to buy a franchise to build a temple? For tax purposes. I'll make a new gif or meme every week to spread the gospel.
    https://youtube.com/shorts/TDzz-ZYkK1k?si=MWgVC4yNlycBN0Jj
    My zx6r had a large butthead sticker on the fairing.
    i also had nutsack blinkers, and a switch for flashers. Long burn because incandescent. I was rowdy back then, cant believe what i got away with.
    bmf4069, JakeJake, VR6T and 3 others like this.
  29. Jun 25, 2024 at 6:34 PM
    Azblue
    Welcome brother. No need to purchase anything, but if you could tithe a portion of your income so we may obtain beer, nachos, and TP, it would be appreciated.
    Tundra2, bmf4069, VR6T and 3 others like this.
  30. Jun 25, 2024 at 6:38 PM
    JakeJake
    2000 Tundra AC 4X4
    Long day at the ball crushing factory.
    Degreased, Wire wheeled, Ospho'd and painted the frame+crossmembers inside and out, from the front bumper to the back of the cab/spring hanger.
    Also torched out the oem bushings as prep for the new daystar poly bushings and did the same prep/paint process to them too.
    Tomorrow should be fun!
    Tundra2, NUDRAT, des2mtn and 14 others like this.
