3-3.5in lift options
Discussion in 'Suspension' started by spectrasoul, Jun 25, 2024.
  1. Jun 25, 2024 at 6:19 AM
    spectrasoul
    spectrasoul [OP] New Member
    Looking for a these 2 options and cant decide which way to go:
    1.Toytec Aluma Series Boss Suspension System with 2.5 Coilovers (07-21 Tundra) 2"-3" Lift
    2. 3.5in Rough Country lift with vertex adjustible coilovers.
    Both options cost around $2500. Just want to level my truck and put 295/70/18 setup with +20-25mm offset. Not planning to offroad. Any reccomendations?
  2. Jun 25, 2024 at 6:37 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Toytec based on those two options. toytec is better quality than RC.
    2 inch lift in front, like a stock PRO is plenty for 295s. Once you start approaching 3 inch lift, you will need new UCA for correct alignment so keep that in mind, extra cost and work.
    Eibach and OME also have some nice lift offerings in that price range or less.
  3. Jun 25, 2024 at 6:41 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Could try a lower suspension lift along with a medium body lift - less stress on suspension (may not need new UCAs) and the center of gravity is affected two-thirds less so better cornering at speed and just plain feels better all around - Luck.
  4. Jun 25, 2024 at 6:43 AM
    spectrasoul
    Toytec advertises that kit as 3in in front, so i have to add UCA anyway. Not to many reviews on Toytec though... From other side, RC with Vertex, have a lot of reviews + youtube videos...All ppl saying RC quality improved a lot...
