Does anybody know which fuses are ignition-switched?
Discussion in '3rd Gen Tundras (2022+)' started by ByeF150HelloTundra, Apr 8, 2022.
  1. Apr 8, 2022 at 5:30 AM
    ByeF150HelloTundra
    ByeF150HelloTundra [OP] New Member
    DFW
    2022 Tundra SR5
    Looking for both in the cab and under the hood (near the battery). Wanting to connect to a relay
  2. Apr 8, 2022 at 2:54 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Ended up answering my own question, but the Power Outlet No. 1 in the interior fuse box and the Seat Heater F/L in the engine passenger fuse box are both ignition switched in case anybody needs a quick reference 44528D2A-CDAB-4B43-84A2-9D004A4552A6.jpg 0089ECF3-AE66-4B90-9202-D3C9C57E9309.jpg
    Blang805 likes this.
  3. Apr 9, 2022 at 8:49 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Looks like a QR code in there on each cover, did you try scanning it to see what, if anything comes up?
  4. Apr 9, 2022 at 11:28 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Yeah I tried but some math equation popped up. No link or anything
    gmcguire7220 likes this.
  5. Apr 15, 2023 at 6:52 PM
    Ketterus
    Ketterus New Member
    Thank you, this was extremely helpful, and spot on too. :)
  6. Apr 16, 2023 at 6:20 AM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    I tapped into the usb1 fuse in the cab and no issues for my interior lighting. Comes on perfectly with ignition.
  7. Apr 16, 2023 at 6:25 AM
    Ketterus
    Ketterus New Member
    I needed an ignition siginal for the air compressor for the rear airbags. I ordered a fuse tap it install over the fuse to the heated seats which I don’t have on my truck. I do not like cutting or side tapping factory wires so it was important for me to find a solution. I will keep in mind should I need a siginal from interior in the future.
  8. Jun 24, 2024 at 8:54 AM
    Carguy28
    Carguy28 New Member
    Quick question can I put a Auxbeam BA80 fuse tap to that heated seat one or a different one cause I have these 18w lasfit lights I wanna hook up to this auxbeam but it does not turn off when the car is off and everything is hooked up near this engine passenger fuse box if you can help me which one would be the best iggnition fuse that would hold the ditch lights would help
  9. Jun 25, 2024 at 5:42 AM
    angrygiraffe
    angrygiraffe New Member
    '22 SR5 CrewCab 5.5'
    I used the fuse below for some grill lights. switches on when ignition is on, and off when the ignition is off.
