The tranny question again.
Discussion in '1st Gen Tundras (2000-2006)' started by Jkeller, Jun 24, 2024.
  1. Jun 24, 2024 at 7:43 PM
    Jkeller
    Jkeller [OP] New Member
    James
    Riverside, Ca
    2004 Tundra
    Lift kit
    So my Tundra is an 04 DC 2wd 4.7. I am replacing the tranny. the replacement is out of an 04 sequia. Bothe are 30-40LE but the second set of numbers to the right of the model # are different. First tag(original) 35000/ 34300
    Replacement says 35000/ 34270. I’m not sure if these numbers matter however, when I pick the tranny up, I was told that they are exactly the same. The one difference I see is that on the tail shaft housing of the replacement transmission, it has what looks to be a speed sensor and on my original one it does not have the sensor. Can I simply swap out the tail shaft housing and be OK or do I have the wrong transmission? I have confirmed through other posts that the replacement is out of an 042 Wheel Dr., but the second set of numbers help me puzzled as to why that sensor is there on one and not on the other
  2. Jun 25, 2024 at 4:14 AM
    If your replacement has a speed sensor in the tail shaft, that means your speedometer and mileage won't work. That trans uses a gear in there to send the signal to the cluster.
    However, that seems odd. Your 4 spd truck should have that sensor as well. The 5 spd trucks switched to the wheel speed sensors. Can you get pics of the tail housings on both trannies?
  3. Jun 25, 2024 at 6:10 AM
    Jkeller
    James
    Riverside, Ca
    2004 Tundra
    Lift kit
    Thanks for the reply,
    The first picture is the one currently in the truck. The second and third one are the replacement transmission. Both have the small plug on the bottom side. I guess you might say and then replacement transmission has the larger sensor as well. On the original transmission you can see where that would have gone, but that hole is plugged on the original transmission.
  4. Jun 25, 2024 at 6:54 AM
    So your replacement trans is definitely a 4spd gear driven trans. Unless they did something weird for the 04 model and went to the WSS, I don't think it will work. The sequoias were a year behind in tundras, so your equivalent model would be an 05 sequoia. I could be completely wrong on this though. I'd wait for a real expert to chime in. Maybe @empty_lord will make an appearance today.
  5. Jun 25, 2024 at 8:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I wonder if the Sequoia used wheel speed sensors due to the AWD aspect?
  6. Jun 25, 2024 at 12:02 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Not sure the difference. But there’s no harm in using the new transmission if it has extra bits. They just won’t be hooked up
  7. Jun 25, 2024 at 12:15 PM
    Jkeller
    James
    Riverside, Ca
    2004 Tundra
    Lift kit
    Thank you for the input. I thought that might be the case but I’m not a tranny person. Thank you and thank you all.
