  1. Jun 23, 2024 at 5:40 PM
    Mcdqpr
    Mcdqpr New Member
    Looks great. Are fog lights gone in this set up?
  2. Jun 23, 2024 at 5:56 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    For now, yes. I’ll toss in some amber fogs when funds permit
    Tripleconpanna likes this.
  3. Jun 23, 2024 at 6:27 PM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    When adding the Decked Drawer System do you have to remove the bed stiffeners.
  4. Jun 23, 2024 at 6:57 PM
    koditten
    Kirk
    Midland of the Mitten
    It wasn't very good. Reminded me of natural lite ice, but with less alcohol content.
    bflooks[QUOTED] likes this.
  5. Jun 23, 2024 at 7:01 PM
    koditten
    Kirk
    Swapped out blown air bags this weekend. Job kinda sucks, but when you buy a truck at auction, you do what must be done.
    The side curtain bags are the biggest pain in the ass of all the rest.
  6. Jun 23, 2024 at 7:05 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Love the headrest covers
  7. Jun 23, 2024 at 8:34 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Added a 7ft Kammok awning —I wanted it to be flush with the camper side, so I decided to make some 1/4"spacers and thru-bolt it instead of using the brackets it came with
  8. Jun 23, 2024 at 8:35 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    What does that set up run you?
  9. Jun 23, 2024 at 8:48 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    It was $850. I was able to get one of their outlet awnings that was "lightly used" but when it showed up everything but the box looked brand new to me
  10. Jun 23, 2024 at 10:03 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    (and @BreyTundy too)
    Here's what I did for those 2 driver's side PITAs...
    Took (2) of the large washers and (2) nuts down to a local welding shop and had them weld the nuts to washers; then weld a thin welding rod to each of those setups.... cost me $20 and save me a shit ton of time, frustration and busted knuckles trying to stuff my hand in that tiny ass channel.
    I was able to easily slide the set up into the frame channel and secure the bolts w/o too much heartache :thumbsup:
    I've also heard of guys loosening the straps to the gas tank and dropping it down slightly, but this other route seemed waaaaay easier to me...
    coldcanuk, sbxx312, junior and 3 others like this.
  11. Jun 23, 2024 at 10:13 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Friggin genius!
  12. Jun 23, 2024 at 10:20 PM
    Tripleconpanna
    I'd love to take credit for the idea, but when I was shopping around for sliders I saw an install video for WKOR (they were my 2nd choice) and apparently WKOR started including a set up like this w/their hardware kits to make it easier on their customers. I just figured I build my own..:thumbsup:
  13. Jun 24, 2024 at 3:45 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    That's the ticket right there! I was also going to try and put the nut in the closed side of a box end wrench with tape over the back to hold the nut in. I've had luck with that before when getting to hard to reach places.
    bulldog93 and Timberline like this.
  14. Jun 24, 2024 at 6:34 AM
    Tripleconpanna
    I gave that a brief effort w/some tape holding the nut in the wrench (once); then it was immediately parts in hand and off to welding shop a couple of miles from me... It's hard enough crawling my old ass under the truck to do that shit in the first place, but then add contortion of my arm, should and fingers while trying to make that work.... NOPE!!! I did give it an honest 5 minutes before going the other route... :D
  15. Jun 24, 2024 at 6:40 AM
    coTony
    Tony
    Montrose, CO
    White Knuckle Sliders came with those types of cheater nuts you made. They also had them on my gas tank armor. I forget which place I bought the gas tank armor from, I did not like RCI’s approach but bought everything else from RCI
    I held the nut to where the wire attached could be tucked away and used when removing/reassembling
  16. Jun 24, 2024 at 6:52 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Ooh, that actually gave me an idea to use some spare wire to wrap the nut and washer to get them into the frame. Thankfully I've got tons of old wire laying around with my kitchen remodel. Look at that, the forum provides yet again
  17. Jun 24, 2024 at 6:54 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Lol, at 30 I've still got the idea in my head that I'm capable of contortion that in reality I'm not. I generally have to learn my lessons the hard way
  18. Jun 24, 2024 at 7:04 AM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    Hm, interesting idea! - I might try this with JB Weld instead
  19. Jun 24, 2024 at 7:20 AM
    Tripleconpanna
    That would probably work well... :fistbump:
  20. Jun 24, 2024 at 8:16 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    Tape over the back of something to get a bolt/nut in place… I’m getting flashbacks to when I replaced the Front Valance Panel (plastic piece that will usually have the front license plate attached to it). The engineering genius at Toyota placed 6 nut and bolts in front of a metal bumper frame with about a 2-3 inch gap between it and the panel… that made it nearly impossible to replace the nuts. Using the power of tape, I stuck a nut between two fingers and taped it. By doing that, I was able snake my hand between the frame and panel and thread the bottom nuts back on. Awful, horrible, terrible experience that made an otherwise 10 minute job into a 3 hour one…
  21. Jun 24, 2024 at 9:35 AM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    I thought my 14 was low with 47K
    GLaDOS[QUOTED] likes this.
  22. Jun 24, 2024 at 10:09 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    I have to admit that I was spoiled since I lived in a big city for quite some time (6 out of the last 10 years), and everything was within walking distance.
    BeauDacious[QUOTED] likes this.
  23. Jun 24, 2024 at 10:14 AM
    BeauDacious
    14 DC 4x
    I work from home, and have a tiny all electric fiat to run errands with. I spent 8K on the electric garbage in 19. I will get all 8k worth of dollars from it.
  24. Jun 24, 2024 at 10:23 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    That’s funny that you bring up an electric vehicle because my girlfriend and I were just talking about them. She said it’d be more practical for me to drive one of those to see her instead of my garage queen that only gets 13mpg. However, when I looked at used “smart cars” they were asking north of $12k to $15k for a heavily used 2019. Ccrrraazzzyyy! That said, $8k sounds like a steal.
  25. Jun 24, 2024 at 10:26 AM
    BiiigTruck
    BiiigTruck New Member
    2016 TRD Off Road Limited
    ooo, a fellow MTBer! is there a Mountain Bikes and Tundras thread here?
    Sleeper16plat likes this.
  26. Jun 24, 2024 at 10:31 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    I don’t think so, because I was searching for one too! I was going to start one in the off topic forums, but can’t due to my post count being below 50. Oh well.
  27. Jun 24, 2024 at 10:32 AM
    GravityGear
    Aurora, CO
    There's a bikes and tundras thread. Nothing MTB specific, but there's a lot of mtb chat there.
  28. Jun 24, 2024 at 10:41 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    I did see that one, but I was hoping to see a thread specifically for all things MTB — bike recommendations for different budgets, product recommendations, reviews, trail experiences and general advice.
  29. Jun 24, 2024 at 10:51 AM
    BeauDacious
    14 DC 4x
    Yeah it was just before a serious price jack happened to them. I was almost tempted to sell it right after i bought it, but it was only 3K more, and the car was more useful at the time. I worked in office downtown. It has just enough range to go to and from with about 20% left on one charge, and let me get into the HOV lane. 8 months later, I started working at home... Since, it runs errands.
  30. Jun 24, 2024 at 10:51 AM
    GravityGear
    Aurora, CO
    Just post up in there. We do that stuff all the time. But yeah, it does go in different directions.
    BiiigTruck likes this.
