Front brake job on 2014 1794
Discussion in '2.5 Gen Tundras (2014-2021)' started by Paulskie, Aug 25, 2015.
  1. Aug 25, 2015 at 10:58 PM
    Paulskie
    Paulskie [OP] New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Well at 32k I my brakes were done. tango_face_surprise_a0af94cb2b2d992ebbcfd73478cb0925ec8d9492.png
    Unfortunately with many trip I had to reserve to this until I can order better pads. So Autozone Ceramic Quite Stop pads were installed.
    It may seem like the similar way to the rest of Tundra years: 2007-current, but it may be useful to others.
    Parts and tools used: 2 jacks, jack stand, torque wrench, big flat head screwdriver, flashlight (got dark too quick), C-clamp, brake cleaner, brake grease and of course new brake pads.
    Took about 30 mins to complete the job, but may comeback in the future to repaint the rotors, calipers - clean look tango_face_wink_ad3af12617f2bbc662b902559f9ad7fe7607dd0d.png
    Summary in pictures. ( by any means I am not mechanic, this evening I was limited on the tools I had with me and space to work with)
    20150823_195919.jpg 20150823_200000.jpg 20150823_200005.jpg 20150823_200641.jpg 20150823_200644.jpg 20150823_201213.jpg 20150823_201221.jpg 20150823_201239.jpg 20150823_201246.jpg 20150823_201520.jpg 20150823_201536.jpg
    equin, MotoTundra and brewster7 like this.
  2. Aug 26, 2015 at 5:18 AM
    I put on the same pads. They appear to be holding up pretty well. Not a lot of brake dust too. My rotors were both slightly warped, so they got replaced at the same time.
  3. Aug 26, 2015 at 8:26 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    How the hell did your factory tires outlast your brake pads? Do you drive with two feet?
  4. Aug 26, 2015 at 10:05 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    32 k on pads? Wait is this a GM board im on again?
    RustyShackle323 likes this.
  5. Aug 26, 2015 at 10:10 AM
    Paulskie
    Paul
    That's what I thought too but then again you know I'm driving tons of stop and go traffic. When I had a dealer inspect the truck there are two other trucks with 16 and 20 thousand on the clock with the exact same issue
  6. Aug 26, 2015 at 10:50 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Wow. 32k is way too early to need new pads. Do you tow a lot? In any case, I've had really good results from Power Stop products. Haven't tried the AutoZone pads you mentioned. Let us know how it goes.
  7. Aug 26, 2015 at 5:47 PM
    Paulskie
    Paul
  8. Nov 6, 2018 at 5:17 PM
    hunter35745
    hunter35745 New Member
    Keith
    Midlothian, Va
    2018 Tundra Platinum Super White
    Ionic 5" stainless tube steps, Weathertech vent visors front and rear,Weathertec all weather mats, Shorty antenna, TRD cold air intake,oil cap,radiator cap ,rear sway bar and dual exhaust,console safe, color match mirror caps,gloss black color match door handles, Tinted D&P front windows, Line X Premium spray in bed liner, TRD front swaybar
    Man, I got 130,000 out of the pads on my 2010 Tundra SR5, and they were not nearly as worn as yours when I changed them. And I towed a 34' travel trailer.
    coldcanuk likes this.
  9. Nov 6, 2018 at 5:56 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Just did mine also at 41000 miles. Old pads were about halfway.
    equin and TXRailRoadBandit73 like this.
  10. Nov 6, 2018 at 6:10 PM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    Need to look into doing mine
    brewster7 and jeremyd like this.
  11. Mar 27, 2019 at 4:59 AM
    brewster7
    brewster7 New Member
    2016 Bronze Tundra 1794 4X4
    Great post, very helpful to an old retired fart, and now I know I NEED to look. My truck has 42',000 and I got it used. THANK$!
  12. Mar 27, 2019 at 6:24 AM
    MiYota
    MiYota New Member
    evan
    2014 super white tundra
    I think its time for mine. My brake pedal is real soft and when I try a hard stop the truck has a slight shimmy to it. Mechanic said it might be a stuck caliper but I think it has original rotors on it and someone just replaced the pads. My truck is a 2014 and has 140,000 on it
  13. Mar 27, 2019 at 6:55 AM
    sundance
    sundance New Member
    So far, almost 70,000 on orginal pads. My penny. You can't do better than the OEM pads. Rotors. Yes. Pads.. No. Nothing feels better or stops better than the OEM pads.
  14. Jul 22, 2024 at 2:29 PM
    TRD_RTC
    TRD_RTC Overlander
    Robb
    2007 Toyota Tundra CM SR5 TRD Off-Road
    TRD Intake Tinted Windows Color Match Cap CB Radio Valentine 1
    Does anyone know if 2018 brake calipers fit a 2007?
  15. Jul 22, 2024 at 2:30 PM
    Should
  16. Jul 23, 2024 at 4:37 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I'd go to Rockauto.com and see.
  17. Jul 23, 2024 at 12:39 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    My guess is no. But it's just an assumption based off of rockauto.com
  18. Jul 23, 2024 at 4:13 PM
    TRD_RTC
    TRD_RTC Overlander
    Robb
    That’s my issue. I want the powder coat red ones but rock auto doesn’t have any
  19. Aug 15, 2025 at 11:19 AM
    jake_sully_92
    jake_sully_92 New Member
    Jake
    2011 Toyota Tundra 4.6L SR5 4X4
    Nothing that I can tell, someone put the TRD stickers on but there's no upgraded shocks or anything.
    I've had a 2011 4.6L SR5 TRD for just about a year now; I don't think the guy I got it from ever replaced them and it has 177k on it I don't know for sure but they definitely wobble and the pads are for sure at the end of their lives, it wouldn't surprise me if they are only the second set on her. I'm just laughing at 32k...that's rough. Any tips while I look for my own? I see OEM pads but are slotted/fancy rotors necessary for my pavement pickup?
  20. Aug 15, 2025 at 12:10 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I got OEM and am happy with them. Just don't get the economy line of brakes pads get the ones that come from the factory on it.
  21. Aug 18, 2025 at 3:07 PM
    agrestic1
    2016 CrewMax
    I did slotted rotors, the slots fill up after a while making them pointless, along with EBC pads. Many do the drilled and slotted. . I now have plain Advics rotors and Akebono pads. Put a few thousand miles on them, so far good...I'd look at Rockauto and buybrakes.com.
  22. Aug 18, 2025 at 3:25 PM
    jake_sully_92
    Jake
    10-4, Rubber Ducky, I'll check them out!
