  1. Jun 21, 2024 at 11:19 AM
    Mbril
    Mbril New Member
    I have a slight shudder when the trans is cold and I slowly accelerate, as it’s about to shift into 3rd or 4th. Doesn’t do it if I accelerate quickly. Is that consistent with what you had?
  2. Jun 21, 2024 at 11:57 AM
    Mountainmanjh
    Mountainmanjh New Member
    Northern Utah
    2012 Black Crewmax
    Eibach Protruck coilovers and shocks Total Chaos UCAs, bed stiffeners Deaver U748 leaf springs with Camburg shackles TRD sway bars, front and rear Gear Dominator wheels (18x9 18+) Cooper AT3 XLT (275/70r18) RCI engine, trans, and A-arm skids Transferflow 46-gal fuel tank Yakima Outpost bed rack Curt front hitch receiver SumoSprings (yellow) StartX remote start *coming soon* Auburn rear LSD RCI sliders, diff skid, cat guards Coastal offroad front bumper Badlands apex winch Kenwood DNX577S head unit
    I had something like that after a fluid change that was done improperly. A trip to the dealer for a good drain and fill solved it.
  3. Jun 21, 2024 at 2:35 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Y'all I need some advice/help.
    So I used a 50 ton press, lubed up everything and my bushings are stuck.
    During the install I first used an adapter and put it on the aluminum lip. It was 100% on there. All was going well and then the lip started to bend. You can see in the first photo where it bent and I bent it back into place.
    I then removed the ring and just used a flat piece of metal. The bushing then started to flatten almost to the point of bursting.
    The smaller bushings went in just fine, no issues.
    So what do yall recommend for me to seat these all the way? Do yall think that the grease is taking up volume within the sleeve which prevents it from moving?
  4. Jun 21, 2024 at 2:42 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Will it come back out? If so you could take it out and freeze the bushing before install.
    Long shot but do you have access to liquid nitrogen? Different application but have done liquid nitrogen bushing install before. Would want to try and apply the cold to bushing to get it to freeze at a faster rate.
  5. Jun 21, 2024 at 2:45 PM
    AstroDude
    Eddie
    We didn't try too hard with taking it out but I'm sure it can be done.
    I don't have liquid nitrogen, but I could try using dry ice.
    20GR8 Super[QUOTED] likes this.
  6. Jun 22, 2024 at 5:12 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    My initial shudder was at 25-30 mph; transmissions are pretty temperamental so flushing the fluid again might make it worse… you could pickup some Dr Tranny shudder stop and that probably will stop it
    I’d probably pickup Lubeguard platinum instead and put that in, I’ve heard really good things about it including actually fixing the shudder instead of just preventing it (has additives to help the pads on the tc become unglazed) I’m gonna put it in mine when everything is back together
  7. Jun 22, 2024 at 5:15 AM
    joseph_womack
    Joe
    Louisiana
    Just put the bushing and sleeve in the freezer for a couple days and then take it out and immediately press in, I would still lube it and use the cup to make sure it goes in straight
    07 Tundie and AstroDude[QUOTED] like this.
  8. Jun 22, 2024 at 5:17 AM
    joseph_womack
    Joe
    Louisiana
    I would make sure the transmission is actually full also
  9. Jun 22, 2024 at 5:25 AM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    Maybe warm the arm up a little while freezing the bushing.
  10. Jun 22, 2024 at 5:32 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Make sure that there aren't any impediments on the inside of the control arm eyelet, maybe give it a little polish with some emery paper as well as making certain the edges are clean.
  11. Jun 22, 2024 at 2:48 PM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    Did a front brake job for the first time on the Tundra.
    Akebono pads and Advics rotors from Rockauto.
    Everything was pretty straight forward. Most difficult part was the learning curve during it for the first time. OEM pads and rotors had 83k on them and probably had another 3 to 5k left but just wanted to get em done.
    Strange part and goes against everything I have learned over the past 50 plus years is with the Advics rotors there is a pamphlet telling you not to clean the rotors. With anything. Just put em on and do the brake in process. I followed it, we shall see.
    Otherwise a great combo and great stopping power.
    joseph_womack, omgboost and koditten like this.
  12. Jun 23, 2024 at 12:42 PM
    AstroDude
    Eddie
    Alrighttttt so I used a wire wheel and 1000 grit sandpaper to smooth the inside. It's super smooth and the bushings have been chilling for about 12+ hours.
    Later on today, when it not 100°F outside, I'm going to take them to Camp Pendleton to get them pressed in. I really hope this works. If it doesn't, then I'm screwed.
    After the bushings are installed, I'm going to coat the LCAs with some POR15.
  13. Jun 23, 2024 at 2:59 PM
    koditten
    Kirk
    Midland of the Mitten
    :popcorn:
    07 Tundie, OldGuy03 and Wynnded like this.
  14. Jun 23, 2024 at 3:40 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    For future reference, every time you use sandpaper you remove material. There's a reason these fit tight, mechanically
    expanding that opening is not a preferable solution. You'll be okay this time but for others, don't do that. Press fit is
    for a reason, getting them lined in perfectly is important. Some heat to the outer assembly immediately prior to
    pressing the bearing in is the only real option.
  15. Jun 23, 2024 at 4:40 PM
    AstroDude
    Eddie
    Yeah I should have asked yall about that before doing it.
    I wasn't able to get to the press shop so I'll have to try later this week.
  16. Jun 23, 2024 at 4:47 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Whoever is there where the press is should be able to give you a bit of guidance. Usually the fit is so tight even
    no room for lubrication. Patience.
  17. Jun 23, 2024 at 5:11 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Transmission Cooler:
    90301-19020 // Oil Cooler O-Ring // Qty: 2
    32971-34020 // Thermostat Transmission // Qty : 1
    I got the lines and clamps from either Amazon or O'Rielly. Got the Trans Cooler (Hayden) from Amazon. I'll look more and find out what the PN is for the bolts... I've ordered too much shit from different Toyota Parts dealers so I'm having a hard time finding them right now.
    EDIT: I love the Dirty Deedz Injectors! They definitely did not improve gas mileage... if anything, they've possibly created a negligible decrease in MPG's. But, I can say without a doubt that the truck does run more smoothly and power is there when I mash the pedal. For the price, I would say that it's a great upgrade!
  18. Jun 24, 2024 at 6:10 PM
    joseph_womack
    Joe
    Louisiana
    Thank you for the info! I just pulled the valve body so if this goes back together and works the cooler is next o_O
  19. Jun 27, 2024 at 11:09 PM
    Nemesis
    Nemesis New Member
    Got off my butt and finished installing USB ports on the center console for passengers in the back.
  20. Jun 29, 2024 at 4:44 PM
    AstroDude
    Eddie
    Holy mother of fuck balls. What a pain in the ass to install these bushings.
    Here's what I did/used
    1. Put them on dry ice for 24 hours (installed them as soon as I took them out)
    2. Heated the LCA with a blow torch
    3. Used a 50 ton press
    While I pressed in, I heated the LCA again and banged on the outside with a hammer.
    Even with alllll that bullshit, it still almost didn't go in. The aluminum lip was bending so I had to push on the entire bushing. The polyurethane bushing was flexing to its max.
    If the sleeve/lip was steel, anything harder than aluminum, it would have 100% easier to install.
    My Solid Offroad mounts came in today. Took about 6 weeks.
  21. Jun 29, 2024 at 5:11 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    I don’t understand, you had new oem assembled lowers but you chose to press in different bushing? For why
    IIonPilgrimg likes this.
  22. Jun 29, 2024 at 6:08 PM
    joseph_womack
    Joe
    Louisiana
    That’s one of the many reasons we don’t swap bushings anymore at the shop, we just quote the customer for a new LCA, they save money on not paying labor time lol, glad it went together though!
  23. Jun 29, 2024 at 6:08 PM
    joseph_womack
    Joe
    Louisiana
    Looks like to get some poly bushings on them instead of the regular oem bushings
    IIonPilgrimg and Tripleconpanna like this.
  24. Jun 29, 2024 at 6:15 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra SC'D AWD RCSB
    Supercharged All Wheel Drive Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Co-worker gave me a hard time about my third brake light not matching after rear taillights install.
    So, I couldn't let him win and installed a tinted third brake light this morning. Matched pretty well actually. Bummer is when I took the old one off my housing screw holes crumbled, worn plastic.
  25. Jun 29, 2024 at 6:47 PM
    AstroDude
    Eddie
    I've seen the differences between OEM and SuperPro so I wanted to test them out. There seems to be less restrictive movement in the LCAs compared to the rubber ones.
    Yeah we will see how they hold up.
    I just went through the three step process of POR15. From the factory, there was already small surface rust. So hopefully this stops any additional rust from forming. I have the entire frame of the truck coated in POR15 and it seems to be holding up after 2 years.
    07 Tundie, The Dude, omgboost and 2 others like this.
  26. Jun 30, 2024 at 10:12 AM
    NinjaSkull
    NinjaSkull New Member
    2008 Tundra SR5 5.7 Crew Max
    Out with the old and in with the new. Had a radiator leak so I upgraded to a Mishimoto radiator. Also replaced my tailgate handle that broke.
    schleinj, D4x4TRD, dondino and 13 others like this.
  27. Jun 30, 2024 at 10:12 AM
    koditten
    Kirk
    What did the rad run?
  28. Jun 30, 2024 at 10:37 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  29. Jun 30, 2024 at 1:31 PM
    AstroDude
    Eddie
    Do you monitor your temps? I'd be interested to know if the temp goes up, down or stays the same.
  30. Jun 30, 2024 at 2:02 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Finally got her back on her feet :D ( Sorry for 2.5 gen )
    Ricos, Filthyphil, The Dude and 7 others like this.
