2006 tundra body lift kit compatibility
Discussion in '1st Gen Tundras (2000-2006)' started by Gus19, Jun 23, 2024.
  1. Jun 23, 2024 at 10:26 AM
    Gus19
    Gus19 [OP] New Member
    2006 Tundra
    I’ve been searching everywhere for a body lift kit for the 2006 tundra and they are nowhere to be found. I can find a 2000 to 2002 but I don’t know if that would work. Does anyone know if it would be compatible? I have a 2006 limited crew cab
  2. Jun 23, 2024 at 10:51 AM
    Have you looked at the instructions for the 00-02 to see if it could potentially be modified to work with your truck? I might start there. I know the pickup cab body mounts (from energy suspension) only require minor modification to make them work but I don’t know about an actual body lift kit to see how it differs.
    des2mtn likes this.
  3. Jun 23, 2024 at 11:12 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    There's some variation between the cab bolt diameter, the DC uses a 12mm bolt on some of the mounts, so you might have to drill out the blocks depending on their ID.
    This website sells everything that should work and has a lot of good information. It looks like they might be able to send you the two most common sets of cab hardware and you use whatever fits.
    https://www.4crawler.com/4x4/ForSale/ToyotaTacoma.shtml
