Thermostat Housing and which FIPG to use?
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Jun 23, 2024.
  1. Jun 23, 2024 at 11:00 AM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    I just discovered a small amount of crust at the front passenger side water crossover gasket and planning to replace all four now. It looks like I have to remove the thermostat housing to get to these. When reassembling the FSM for the 2000 says to use PN 08826-00100 which is Seal Packing 1282B and is expensive AF (~$75). I've heard some people using Toyota brand FIPGs use PN 00295-00103 which is the 103 FIPG (~$15) and others using AISIN AB1207B which looks similar to 103 FIPG and costs about the same. I think I may have used the 103 when I did the TB a few years ago. Any recommendations from @Shifty' or one of the other experts? Thanks.
    AZBoatHauler likes this.
  2. Jun 23, 2024 at 11:30 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I used the AISIN AB1207B from RockAuto on my thermostat housing. RockAuto lists it as an OEM interchange with 00296-00103. 1282B is supposedly compatible with Toyota pink super long life and red coolant. I believe the 103 FIPG is compatible with just only red coolant (vs SLL pink), but I could be wrong.
    https://www.rockauto.com/en/moreinfo.php?pk=11835301&cc=0&pt=1000166&jsn=280
    ToyotaDude, hammeron and FrenchToasty like this.
  3. Jun 23, 2024 at 1:05 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    des2mtn likes this.
  4. Jun 23, 2024 at 1:33 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I use Permatex "the right stuff" 90 minute grey for everything.
    I think @FishNinja used a Harbor freight red flavor :rofl:
    terrward, FishNinja and shifty` like this.
  5. Jun 23, 2024 at 2:52 PM
    AZBoatHauler
    So.Arizona
    I did the Toyota black at the insistence of their service department guy stating they’ve never used the $80 version and never had one come back with a leak…
    FrenchToasty, des2mtn and ToyotaDude like this.
  6. Jun 24, 2024 at 12:15 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    the fact that you know this is impressive. But yea. HF red lol still going strong
  7. Jun 24, 2024 at 1:09 PM
    JakeJake
    2000 Tundra AC 4X4
    Some of that full metal spectrum going on. I saw your post a while back about it and thought to myself "I too like to disregard the rules".
    FishNinja[QUOTED] likes this.
