After market radio not turning on
Discussion in 'Audio & Video' started by 1st Tun, Jun 21, 2024.
  1. Jun 21, 2024 at 4:16 PM
    1st Tun
    1st Tun [OP] New Member
    2019 Gray Tundra
    Having issues on my 2019, radio is not turning on. I do have power to lower plugs, I’ll be tearing into it in a few days just wanted to ask if anyone has encountered this issue. I’m thinking an issue with the maestro harness. Please share any input or suggestions. TIA
  2. Jun 21, 2024 at 6:05 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I don't think I would suspect the Maestro harness first. I would check fuses and grounds. What kind of head unit is it?
    1lowlife likes this.
  3. Jun 21, 2024 at 7:01 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you install it or did a shop do it?
    Did it ever turn on and work properly?
  4. Jun 21, 2024 at 8:27 PM
    1st Tun
    2019 Gray Tundra
    I should’ve given more info, I installed it about two yrs ago. Everything worked fine, did start noticing that radio once in a while would turn on and off during vehicle start up, for this reason and still having power to lower plugs I’m thinking bad maestro. I seen somewhere radio and plugs share same power, I believe radio is a Pioneer NEX 1500.
  5. Jun 21, 2024 at 9:05 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably the fuse? Some are in the back of the unit. Others are in the lines.
    Oolypoolay and 1lowlife like this.
  6. Jun 21, 2024 at 9:07 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  7. Jun 21, 2024 at 9:14 PM
    1st Tun
    2019 Gray Tundra
    I’ll check the fuse and let y’all know. Thanks
    blackdemon_tt and 1lowlife like this.
  8. Jun 21, 2024 at 9:17 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    You've got 2 power leads, BATT and ACC.
    Make sure they have a good connection..
    130DM1500 (crutchfieldonline.com)
  9. Jun 21, 2024 at 9:22 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    You also have a RADIO fuse in the driver's side under-dash fuse box..
  10. Jun 21, 2024 at 9:39 PM
    1st Tun
    2019 Gray Tundra
    Thank you 1LL.
  11. Jun 22, 2024 at 11:45 AM
    1st Tun
    2019 Gray Tundra
    Well I couldn't take driving around with any music / Bluetooth and just had to dig into it. As I suspected, have power to the maestro and nothing out. I pulled it and tried to flash it several times and it was undetectable. Will reach out to Maestro for support and possibly have to purchase a new one. Thanks for the input.
    panicman and Toyotoholic like this.
